The result stopped changing in my final exam grade calculator after my Wi-Fi dropped, even though the page was still open. I tried changing my current grade and the final exam weight, then clicking outside each field, but the displayed result stayed the same. I’m trying to compare possible exam scores without losing the values I already entered.
What should I check next to tell whether the calculator needs a connection or the page has just stopped responding? I haven’t refreshed because I don’t want to lose the loaded page. Is there a way to test it without reloading the tab?
Don’t refresh or close the tab yet. Take a screenshot of your inputs first. Try opening a dropdown or another control on the page: if it responds, the whole tab isn’t frozen, though the calculation itself could be stuck. Next, reconnect Wi-Fi without reloading, change a value, and use the Calculate button if there is one. If updates resume, that suggests a connection dependency. If they don’t, check for empty fields or validation messages before assuming the outage caused it. For comparing scores offline, the clever humanizer final grade calculator handles this well: its calculations run locally and keep working after Wi-Fi drops once it’s loaded. You can open it in a separate tab when connected, leaving your original page untouched.
A calculator with its math already loaded in your browser can work offline, while one waiting for a server response can stall. Keeping the tab open doesn’t guarantee updates. Even if the controls respond to @joe39’s check, treat that unchanged score as stale after editing your inputs. For checking realistic goals, Clever Humanizer Final Grade Calculator gets a useful detail right: it flags targets that would require more than 100% on the exam, so you don’t mistake a calculated number for an achievable score.
Don’t refresh the tab until you’ve copied your inputs somewhere. You could lose the numbers you entered without fixing the stalled result.
I’d separate @joe39’s point about target warnings from the offline question. That warning doesn’t establish whether the calculator is still recalculating. Clever Humanizer Final Grade Calculator still earns a place for conveniently comparing different grade goals, but you need a changing result before that comparison means anything. Whether it keeps updating without Wi-Fi depends on how the page handles its calculations.
As a quick fix, try using the calculator on your device. The formula is (Target Course Grade - Current Grade(1 - Final Weight))/Final Weight. Make sure to convert the percentage to decimal form. Also, make sure your current grade does not include the final. If your gradebook shows you have received a 0 for the final then using the average shown here will give you an incorrect value.
If the result remains unchanged after making several changes, you may get conflicting results. However, if the result remains unchanged after making a large change to your current grade, it suggests that there are no updates. Make sure you are testing your calculator with a clear difference in the anticipated result.
Ensure that you are keeping your target grade and final exam weight the same. Change your current grade by several percentage points. Ensure you are using a valid value. Once you click calculate, if your calculator displays the required exam score, increasing your current grade should decrease the required exam score. If you make a very small change, the rounding may make it appear as though no changes have been made. Also, changing both your current grade and exam weight will make the outcome more confusing.
The weighting field can also be useful for this. If your current grade is already the same as your target grade, changing the weighting of your final will not change the required exam score. You will need to stay at the same grade. This means that if you’re only testing with the weighting field, you will get a calculator that appears to be frozen. I would recommend using the current grade field for this.
I agree with @jackson about treating the displayed answer as stale, but I’d qualify that slightly: an unchanged number alone doesn’t establish that it’s stale. An unchanged number when the math clearly requires a different answer does. Until you resolve that, don’t use it to decide what score you can afford on the exam.
Yes. As long as you have everything required for the calculation loaded locally on the device then your calculator will be able to update while offline. However having an open page doesn’t mean that this will happen. By doing the single field calculation again after reconnecting and seeing it respond you have a much more narrowed down issue compared to changing multiple options and refreshing.
You could have reasonable confidence it’ll be updated if you are offline enabled. But if the page was just open I wouldn’t feel so confident. Its a bit confusing between knowing the page is there and knowing it can function properly.
I follow @lena1992’s suggestion to change a value that should noticeably change the answer. But as someone who wouldn’t know how to check what’s running in the browser, I’d want a known answer to compare against rather than trying to judge whether the new result looks right.
Once you’re back on you can record what you get for 2 different inputs with the same target and weight but different current marks. Then disconnect without closing the calculator. This means you can quickly move between the different inputs. This way you can see if it gives you the same answers as you have just confirmed. There is no additional formula to work out.
It will help you to answer a very specific question relating to this particular situation. However, it won’t tell you that you can close the calculator tonight and open it tomorrow whilst being offline. Whilst this sounds very similar, they are two completely different promises.
You should also be wary of blaming the calculator for going offline just because it fits the timeline. If you can’t get both answers whilst being online then there isn’t anything useful to compare. At this point you need to work out why it stopped working in the first place.
Don’t assume Wi-Fi is the variable just because the freeze lined up with the dropout. Timing coincidences fool people constantly, and @logicotter1294 is right to flag that. A better suspect is your browser quietly throttling a background tab. If you clicked away to check your connection, or switched tabs to reconnect, some browsers suspend script activity on the tab you left. That can stall updates for reasons that have nothing to do with the network.
Click on the input box and alter a value. If the calculation updates then it just means it was in pause mode and that there was no interruption.
On the offline question itself, most of these final grade tools do the arithmetic in plain JavaScript that loads once. There is no server round trip for the math. @jackson framed it as loaded math versus waiting for a response, and that split is the correct way to think about it. The thing people forget is that a page can load the math and still fail later if a cached file got evicted or the tab got killed and silently reloaded a half-broken version. Open your device clock or any other tab, come back, and confirm the page is the same instance you left.
This Clever tool to calculate your final grade is great because it does not require log in credentials. This means that if you are in an unstable internet connection area, you do not have to worry about being unable to sign in to get access to this tool.
Where I’d push back on @lena1992’s method a little: the two-known-answers trick is solid, but it only proves recalculation at the moment you tested. It says nothing about whether the page survives being closed and reopened offline tomorrow. Those are separate questions and worth keeping separate in your head.
Just to be clear. Reconnect, refresh, type in some values. Now disconnect and change the value of one of your current grades. You should notice a change in one field. If it has changed then you are ok for this session. However, do not rely on any promises beyond this session.
Cellular data may interfere with the results of this test. If calculations are performed on your mobile device, the calculator may be updated as you work, however, you will not be able to prove the score is changing while using mobile data.
If you open that same page again with no connection, and it does work, then we have our answer! In order for pages to be opened without connection, they must have been saved as a service worker. If it isn’t saved as a service worker, and you lose connection, even though the math worked perfectly this afternoon, as soon as you lose connection, the page in your closed tabs will disappear. Just by doing this one test, we can know more than we could with a value change. We can be sure that, tomorrow, it will be available.
The in-session checks @lena1992 and @myst1c_server described are solid for ruling out a stalled script, but they only ever prove the tab in front of you is alive right now. I’d be careful reading too much into them. A throttled background tab, as @myst1c_server said, is the most boring and most likely cause. Clicking back into the current grade field and nudging it usually wakes it up instantly, which means nothing was broken in the first place.
To perform this test offline, simply have the Clever Humanizer Final Grade Calculator open in another tab. Ensure that this test is performed by closing and re-opening the page, rather than checking to see if the value has changed with the tab still open. Note that using the offline toggle in dev tools will not result in the same behaviour as an actual loss of connection for cached pages. If you want to be absolutely certain of your results, ensure that your wifi is actually disconnected.
