Why is ChatGPT giving me zero responses?
I’m using ChatGPT but keep getting absolutely no replies no matter what I type. I’ve tried refreshing and changing browsers, but it’s still not working. Has anyone else experienced this problem or know how to fix it? I really need help figuring out why ChatGPT isn’t responding at all.
So You Wanna Tell If That Text Is Bot-Generated? Read This First.
Ever tried running your essay, blog post, or whatever through one of those “AI detectors” and gotten weird results? Yeah, me too. There are a million of them out there now, but honestly, most don’t seem to know what they’re doing. Here’s what’s actually worked for me—and where you should (and shouldn’t) put your trust.
No-Nonsense Tools For Catching AI-Generated Content
Let’s cut to the chase. You’ll see dozens of sketchy detector sites. Ignore most of them. Here are the ones that don’t seem like total snake oil:
  1. https://gptzero.me/ – They made a big splash in schools. Results seem reasonably accurate, if sometimes paranoid.
  2. https://www.zerogpt.com/ – Easy interface, tolerable false positives, not overloaded with scammy ads.
  3. https://quillbot.com/ai-content-detector – Fast checks and often agrees with the others (if three reviewers say you cheated, maybe you did).
Real Talk: The Scores Are Kinda Made-Up
Let me lay it out: If all three say your text is “under 50% likely AI,” you’re probably safe. But don’t get cocky and expect perfection. I once pasted the U.S. Constitution into a detector and it got flagged as “AI.” So much for reliable government documentation.
Wanna Sound More Human? Here’s a Free Fix
I’ll let you in on a little secret: Clever AI Humanizer is the freebie I’ve actually had luck with. Ran a chunk of AI text through there, and suddenly my scores across detectors shot up to nearly “90% human.” Not saying it’s magic, but hey, it’s free and pretty painless.
It’s All Just a Bit Broken
Honestly, the whole “is this AI?” industry is riding the hype train hard. Don’t freak if you get weird or mixed readings—nobody can promise you a 100% accurate result. There are stories everywhere about classic literature or government docs getting marked as bot-written. The tools are useful, sure, but treat the output like weather forecasts: predictive, not prophetic.
More Reading & Advice from the Reddit Horde
Want a deep-dive and endless debate? Have a look at Best Ai detectors on Reddit for a mountain of rants, reviews, and “just use your eyes” advice.
Other Detectors (If You’re Bored)
Here’s a handful of others making the rounds, some more legit than sketchy, that I’ve had a passing encounter with:
(Side note: none of these have replaced common sense or a quick sniff test.)
Visual Evidence For The Skeptics
Final Thought
The “is it AI?” game is like chasing phantoms, with new rules every day. Use these sites, but don’t bet your grade, job, or dignity on them being flawless. Double-check, write naturally, and if in doubt? Rewrite it yourself, and sleep easy.
Straight up: if ChatGPT is giving you zero replies no matter what you throw at it (and it’s not the “I’m overloaded” error or captcha annoyance), that’s not normal. Browser shuffle and refresh are basic, so kudos for trying those. Next up, check if you’re still logged in—sometimes sessions die silently and you’re staring at an unresponsive void because you aren’t actually signed in anymore. Also, silly as it sounds, try nuking your cookies/cache.
While @mikeappsreviewer went off on the AI detector sidetrack (helpful if you’re paranoid about what ChatGPT spits back, not so much when you can’t get anything), I’ll say API outages or account throttling can cause the exact issue you described. OpenAI has been known to silently throttle free users when the load gets high, especially after peak hours or a big update. If you’re on free, try waiting a few hours and see if it comes back to life. No? Try it from a different network (like mobile data) to see if your IP got temp-flagged.
Don’t think it’s your prompts gone weird—ChatGPT will tell you if it can’t answer, not ghost you like a bad Tinder date. If you’re adventurous, spin up Bing Chat, Claude, or Perplexity and see if they reply to the same questions. If they do and ChatGPT doesn’t, OpenAI’s probably having a problem with your account or region. That, or it’s yet another backend hiccup (they don’t exactly rush to update the status page in my experience).
Absolute worst case: sign up with a new email and see if it works. If New Chatty responds while Old Chatty stays mute, congrats, you’re the proud owner of a shadowbanned account and you’ll need to beg OpenAI support. Which is just as delightful as it sounds.
But nah, you don’t need an AI detector or humanizer for this one—this is a classic case of the bot just not picking up the phone. Hope you get a reply before you start talking to your microwave instead.
Honestly, if ChatGPT is just giving you the big ol’ nothingburger—no error, no “I’m overloaded,” not even a guilt trip about your internet—it’s less of a “what did I type?” crisis and more like the time your phone freezes mid-text and you contemplate throwing it out the window. You’ve already done the browser-hop and refresh dance, so props there. Not totally convinced on @mikeappsreviewer’s “AI detector” tangent—those are for when you get responses, not when you’re staring at existential whitespace.
You know what’s left? Pure, undistilled technical weirdness. Sometimes, OpenAI’s region or account servers just decide you don’t exist anymore. Try turning off any browser extensions (ad blockers, anti-trackers, those can mess with the chat’s scripts), or go the nuclear option and use Incognito/private mode. Still dead air? Mobile app, if you have it, is honestly more reliable most days. I’ve also seen rare cases where VPNs make OpenAI ghost you, so try toggling that.
If you’re typing actual words (not empty prompts, not trigger words, not “as an AI language model…”) and you’re really logged in, it’s either backend outage, rate limiting, or account flagging. Sometimes, especially on the free plan, you just get quietly throttle-banned for existing during busy hours. Not everyone gets the courtesy of an error message.
Don’t fall into the support-ticket rabbit hole just yet—test if the problem is you or them: Try the exact same thing with a burner account (even free trial is enough) or on mobile LTE. If that one works, congratulations, your old account is toast or IP-flagged. Sucks, but sometimes OpenAI’s user shadowban is lazier than actual bans.
And none of this has anything to do with AI detection or humanizer hacks—if zero words come back, it’s 99% a technical or account thing, not prompt quality. Ignore the detectors for now. This is straight-up “hello, anybody home?” territory. Stay strong, and don’t start talking to inanimate objects just yet (unless your microwave is more responsive).
FAQ style, 400 words
Q: Why is ChatGPT totally silent—like not even an error, just a blank response?
A: The usual suspects mentioned already cover browser-refreshing, switching platforms, and ruling out account issues. Let’s add some extra layers, because what everyone’s missed so far is that sometimes the root isn’t on your end, or it’s a weird intersection of factors.
  1. Rate Limiting or Geo Blocks: OpenAI may occasionally throttle traffic, especially during surges or if your IP’s been a bit too chatty. This can lead to “silent fails”—no error, just nothing. If you haven’t tried resetting your router (to get a new IP), do that. If you’re on a shared WiFi (college, big office), try a different network or hotspot.
  2. Account Status Glitches: A rare but real thing: Some accounts enter limbo, not banned but not fully active, especially after payment hiccups or weird usage spikes. Try logging out everywhere and logging back in—full sign-out, don’t just close tabs. If that doesn’t help, spin up a test account to see if it’s account-bound. If that one works and yours doesn’t, you’re shadow-throttled.
  3. Extension Conflicts: Privacy extensions, accessibility tools, or even language translators can silently break complex web apps. You’ve been told to use incognito, but also try a different OS or, weirdly enough, a completely different device (tablet, another PC) to rule out machine-local weirdness.
  4. JS/CSS Errors: OpenAI’s frontend scripts sometimes hang. Open dev tools (F12), go to “Console,” and see if there are red errors. If so, it’s a frontend crash, and you can try clearing site data/caches via browser settings.
  5. Massive Outages or CDN Lags: Sometimes your ISP’s route to OpenAI’s servers just bricks. You can check Cloudflare’s Down Detector type sites—if others are reporting silence, you wait it out.
Regarding AI detectors and the text “humanizing” hype—like what mikeappsreviewer rambled on about with a million segments—it’s irrelevant here since the issue isn’t output quality but total lack of output. No “humanizer” or rewrite tool matters if you can’t get any text to begin with.
The pros of a trick like full cache-and-cookie punch is it’s quick and often overlooked. The con? You lose logins all over, which can be annoying. For truly stuck situations, using another device or data connection gives you instant feedback about whether OpenAI is blocking your network or simply choking on its end.
Side note: While sognonotturno and caminantenocturno dig deep into prompt specifics, here it’s really less about “what you ask” and “who/where you are.” At this level? Just basic troubleshooting trumps AI content detection every time.
