Which is better for productivity: iPad Pro or MacBook Air?
I’m stuck between getting an iPad Pro or a MacBook Air. I need it mainly for productivity tasks like word processing, spreadsheets, and maybe some light photo editing. Portability is important, but so is performance. Has anyone used both and can share their experience or recommend one over the other?
MacBook Air. Hands down. I’ve used both and trust me, if you’re focused on productivity, it’s the way to go. Let’s break it down:
  1. Keyboard & Trackpad:
    The iPad Pro’s Magic Keyboard is good, but it doesn’t match the MacBook Air’s built-in keyboard. Typing on a laptop keyboard, especially for extended periods, feels more natural and efficient. Plus, the MacBook’s trackpad is superb – it makes navigation seamless.
  2. Apps and Software:
    While the iPad Pro has a lot of apps, the MacBook Air runs full desktop applications. For word processing or spreadsheets, you’ll appreciate the more robust features in the desktop versions of Word or Excel.
  3. Portability:
    Both are portable, yes. But the iPad Pro, with its detachable keyboard, might seem more versatile. However, the MacBook Air is incredibly light and slim. You’re not losing out on much portability there.
  4. Multi-tasking:
    macOS handles multiple windows and apps better than iPadOS. While iPadOS has improved multitasking with Split View and Slide Over, it still doesn’t beat the convenience of a desktop operating system. Dragging and dropping between windows, running multiple applications smoothly – it’s just better on the MacBook Air.
  5. Photo Editing:
    Light photo editing can be done on both, but the MacBook Air provides the option of more powerful software like Photoshop. The iPad has apps like Affinity Photo, which are good but not as feature-rich as their desktop counterparts.
  6. Battery Life:
    Both have excellent battery life, but the MacBook Air seems to edge out slightly in real-world usage, especially when running more intensive tasks.
  7. Price:
    The cost can be comparable, but once you add the Magic Keyboard and maybe even the Apple Pencil to the iPad Pro, you’re looking at a price that’s close to, if not more than, a MacBook Air.
In conclusion, for pure productivity – word processing, spreadsheets, light photo editing – the MacBook Air is generally better suited. The iPad Pro has its strengths, especially in portability and touch-based interactions, but for the tasks you mentioned, go for the MacBook Air.
Actually, I kinda disagree with @sognonotturno on a couple of points. While the MacBook Air is an amazing device, the iPad Pro can be equally compelling depending on how you plan to use it.
First off, portability: the iPad Pro with the Magic Keyboard might be a bit heavier than you’d expect, but it’s still a tad more versatile. You can detach the keyboard for a pure tablet experience, which is incredibly handy for reading or sketching. The touch screen plus Pencil support can be a game-changer for light photo editing – tap & retouch feels pretty intuitive.
About apps and performance, sure, macOS has more powerful applications. But iPadOS is catching up super fast. For what you mentioned – word processing, spreadsheets, light photo editing – apps like Microsoft Word, Excel, and Affinity Photo are sooo close to their desktop counterparts now. Plus, the A-series chips in the iPad Pro are absolute beasts in terms of performance.
Multitasking on iPadOS has improved leaps and bounds too. True, it’s not macOS level, but Split View, Slide Over, and the new stage manager feature make a strong case for the iPad. And let’s not forget, using a touch interface to manage windows and apps feels pretty modern and efficient once you get the hang of it.
Battery life is another debate. The iPad Pro tends to stretch a bit longer in my experience, especially during light usage. You can almost use it all day without scrambling for a plug.
Now, the keyboard situation. Yeah, the MacBook’s built-in keyboard is fabulous, especially with Apple’s latest iterations, but I wouldn’t dismiss the Magic Keyboard for iPad. The typing experience is smooth, and the built-in trackpad is surprisingly impressive. It might not beat the MacBook’s but it’s not far behind.
Talking about cost, if you factor in all the accessories for the iPad, the pricing can indeed get very close to the MacBook Air. But here’s the thing: The iPad Pro is like a Swiss Army knife – it’s a tablet, a laptop, and a digital canvas in one device.
So, if you appreciate flexibility, touch interface, and plan to use the iPad for more than just productivity tasks, it might actually be the better option. If your focus is strictly productivity and traditional work setup, the MacBook Air is probably your best bet.
Make sure you understand your workflow and personal preference before deciding. That should guide you to the right choice.
Alright, let’s dive in a bit. I lean more towards @cazadordeestrellas’ viewpoint, but @sognonotturno also brings valid arguments.
To add a different angle:
Software Ecosystem:
The versatility of macOS is indeed a big plus. macOS offers a consistent and mature environment for productivity tasks. Apps like Final Cut Pro, Xcode, and even Logic Pro can be game-changers if you ever venture beyond light editing. The iPad Pro has an increasing range of apps, but they often are simplified compared to their desktop versions.
Portability:
Yes, both are portable, but it’s not just about weight. It’s about how you use it on the go. An iPad Pro with a Magic Keyboard might be heavier but more versatile and can function in tablet mode which can be quite an advantage for reading, annotating documents, or sketching.
User Experience:
iPadOS offers a very different user experience with its touch interface and Apple Pencil support which some users find significantly increases productivity for certain tasks. The tactile interaction can make tasks like photo editing more intuitive and creative.
Display:
The Liquid Retina display with ProMotion on the iPad Pro is arguably superior for content consumption and visual tasks compared to the MacBook Air’s Retina display. The touch interface adds a layer of interactivity that macOS just doesn’t match.
Price to Performance:
One point to note, adding accessories makes the iPad Pro expensive but consider what you’re getting. It combines the utility of a tablet and a laptop plus the creative capabilities with the Pencil. MacBook Air gives you a straightforward, powerful package but lacks the touch interface.
Battery Life:
While battery life is similar, I’ve found the iPad Pro to outlast during regular use like browsing, video playback, and basic tasks. The MacBook Air might edge out in more intensive scenarios.
Multitasking:
macOS undoubtedly handles multitasking better, but iPadOS is catching up. The introduction of Stage Manager has significantly improved productivity on the iPad. However, for robust multitasking, macOS is still ahead.
Durability:
iPads generally have a more rugged build compared to MacBook Airs, which can be a bit more prone to damage due to their clamshell design. Plus, the iPad’s lack of moving parts can be advantageous.
To sum it up, both have their unique strengths. For pure productivity and a more traditional computing experience, the MacBook Air is the way to go. But if you value versatility, touch interactions, and the convenience of a tablet-laptop hybrid, the iPad Pro might be your better choice. Don’t forget to consider which ecosystem fits more seamlessly into your current tech setup too!
Your take covers software breadth, touch workflow, display, price with accessories, battery, multitasking, durability. For word processing, sheets, light photo edits, MacBook Air fits most needs. iPad Pro suits pencil input and reading heavy days.
Simpler path. Run a timed, at home shootout using store returns. Buy both. Two days. Same files. Tasks: 1,000 word doc, 100 row sheet with SUM and VLOOKUP, 20 RAW edits. Record time, battery drop, errors. MacBook Air targets 15 hours web, iPad Pro about 10. Keep teh winner. Return the other within 14 days. Done.
