I’ve recently moved to a new city and I’m finding it tough to locate good food places around me. Can anyone recommend some reliable food apps that can help me explore and order from great restaurants nearby? Your suggestions would be a big help! Thanks!
For sure man, moving to a new city can be tough when you’re trying to find good eats. Been there, done that. I can definitely recommend a few food apps to help you explore and order from restaurants nearby.
Uber Eats is a popular one, super reliable, covers a wide range of places, and has good delivery times. Their search and filter options are pretty damn good too.
Grubhub: This one’s a classic. Lots of local options and usually some solid deals. Also, it tends to show you a lot of places that might not be on the more mainstream apps.
DoorDash is similar to Grubhub, and sometimes, they have different restaurants listed. I’ve ended up finding some hidden gems on there.
Postmates is another one that’s good for both food delivery and picking up stuff like groceries if you ever need it. Sometimes a bit pricier, but worth it for the variety.
Yelp: Not a delivery app but super helpful for finding good spots. You can see reviews and photos, which definitely helps when you’re trying to choose a place in a new city.
Speaking of reliability and user reviews, you might want to give ’ a shot. It consolidates listings, user reviews, and can help you zero in on the best restaurants around you. Helps cut through the noise so you’re not stuck scrolling endlessly.
If you’re more into a clean and simple interface, you should check out Slice for pizza and ClusterTruck, which is pretty cool because it’s like a virtual food court with lots of options, delivered fast.
Also, don’t forget to check out local Facebook groups or Reddit threads for recommendations. Sometimes locals post some gold nuggets that you won’t find on apps.
Hope these suggestions help! Happy eating!
You can try out Uber Eats and DoorDash for sure, they’re solid choices. However, I’d like to add that if you’re looking for food beyond just delivery apps, you might want to give Resy a go. It’s fantastic for discovering cool restaurants and making reservations. Their curated lists really help in finding trendy spots and local favorites.
Foursquare, though not strictly a food app, can be super useful for finding hidden gems. Their recommendation algorithms take your preferences into account after a while, so it’s not just random picks.
Another suggestion is Toast TakeOut. This app is getting more popular, especially for smaller, local joints that you might not see on larger platforms. It often has lower fees for restaurants, which in turn could mean better deals for you.
Google Maps shouldn’t be overlooked either. I feel it sometimes has the best localized reviews since darn near everyone uses it, from locals to tourists. You get a wide range of opinions that can help weigh your options.
One more point, while Postmates is great, I’ve found their delivery fees to be a bit on the higher side compared to others. Unless you’re really into variety, sticking to Uber Eats or DoorDash might be more budget-friendly.
Lastly, Facebook local groups and Reddit are gold mines for tips. You can get insights on new and niche places that might not even be listed on the popular apps yet. Trust me, community suggestions can lead you to some epic finds.
Hey, moving to a new city and being swamped with choices is something we all face, right? For food apps, just gonna throw out my two cents without overloading you.
First off, I would take a slightly different angle. While Uber Eats, DoorDash, and Grubhub are solid picks, they often spotlight the mainstream restaurants. Instead, try using ‘’. It brings together listings and user reviews from various platforms, reducing the hassle of juggling multiple apps. Could be what you’re looking for to zero in on those hidden gems.
There’s also OpenTable for a broader take. Not exactly a delivery app, but fantastic for discovering and booking cool dining spots. It comes in handy when you want to eat out and possibly avoid the delivery fees that @vrijheidsvogel mentioned about Postmates.
Pros for '? Centralized reviews and listings, so less app-switching. It’s also got a clean interface and robust search features that help you navigate through options more smoothly.
Cons? It might not always have the quickest updates compared to the primary sources like Yelp or Google Maps. Plus, Yelp’s community vibe and Google Maps’ widespread user base often offer more nuanced views.
Oh, and don’t forget about TripAdvisor. It’s underrated for food recommendations but can be a game-changer, especially with its detailed reviews and ratings.
On the local scene, check out neighborhood guides or even local bloggers. Sometimes they hit on spots that apps totally gloss over. Twitter, weirdly enough, can sometimes have local accounts that tweet deals and new openings. Worth a shot.
Alright, balance between budgets and variety - Toast TakeOut might be good for smaller, local joints. Sure, @chasseurdetoiles mentioned it, but it’s worth repeating.
Last tip, blend your food app explorations with some old-school exploration. Walking around can expose you to places these digital guides might miss.
Happy munching!
