I just finished building a small app and I’m unsure if my review process is solid enough before I publish it. I want to make sure I’m not missing any important usability, security, or performance checks. What steps or checklist should I follow to properly review and polish my app before release?
Here is a quick checklist you can run before you ship.
USABILITY
- Test onboarding
• New user flow from install to first success.
• Remove any “dead ends” with no clear next step. - Click and tap paths
• Every main action reachable in 3 to 4 taps at most.
• Labels: short, clear verbs. Avoid icons with no text unless they are obvious. - Error states
• Show clear error messages, no raw error codes.
• Explain what went wrong and what the user should do. - Different devices
• Test on small phone, big phone, tablet if it applies.
• Check font sizes and hit areas. Buttons at least ~44x44 pt. - Accessibility
• Test with large text enabled in OS.
• Check color contrast. No text on pure bright images.
• Support keyboard navigation if it is a web or desktop app.
SECURITY
- Data in transit
• Use HTTPS everywhere. No HTTP fallbacks.
• HSTS on web. - Data at rest
• Do not store passwords in plain text anywhere.
• Use salted hash for passwords on backend.
• Only store what you need, avoid extra PII. - Auth flows
• Protect any “admin” or “settings” endpoints.
• Lock actions that change data behind auth.
• Add logout and token expiry. - Input validation
• Validate on backend, not only frontend.
• Sanitize input, avoid SQL injection and XSS. Use parameterized queries. - Secrets
• No API keys in frontend code or public repos.
• Use env vars or a secret manager on server.
PERFORMANCE
- App start time
• Measure cold start. Aim low, around 1 to 3 seconds for mobile.
• Lazy load non critical screens. - Network use
• Cache responses where it makes sense.
• Avoid fetching the same data again and again. - Images and assets
• Compress images.
• Use webp or avif on web. - JS and bundles for web
• Split bundles. Remove unused libraries.
• Turn on gzip or brotli on server. - Low end device test
• Run on older phone or throttled browser.
• Look for jank during scroll or animations.
STABILITY
- Crash logging
• Set up Sentry, Firebase Crashlytics, or similar.
• Trigger a few known errors and see if they log. - Basic load test
• Use something like k6, Locust, or JMeter.
• Simulate at least 10 to 50 concurrent users and watch CPU, RAM, DB. - Offline and bad network
• Turn on airplane mode, then flaky network, see what breaks.
• Show clear messages when network fails.
APP STORE / PLAY STORE / WEB LAUNCH
- Permissions
• Request only the permissions you need.
• Explain why in the permission prompt if the platform allows. - Privacy policy
• Have a simple privacy policy page.
• Link it in app and in store listing. - Analytics
• Track only the key events that help you improve UX.
• Avoid dumping every tap into analytics.
PRE RELEASE TESTING
- Friends test
• Give it to 5 to 10 people who never saw it.
• Watch them use it without helping. Take notes. - Bug list
• Log everything in one place.
• Mark each bug as must fix or nice to fix before launch.
If you share what stack you used and what type of app it is, people here can poke at more specific spots that tend to break.
You’re already ahead by even having a review process. A lot of folks just hit “publish and pray.”
@mikeappsreviewer covered the classic checklist stuff, so I’ll skip repeating that and poke at a few blind spots people usually miss:
Feature kill test
Temporarily disable or hide one “non essential” feature and see if the app still makes sense.
If the core value of your app is not obvious without that extra thing, your core flow probably isn’t tight enough yet. -
Expectation mismatch check
- Compare your app name, icon, and first screenshot / hero section to what the app actually does on first open.
- If a new user would expect something slightly different, you’ll get installs and fast uninstalls, which looks bad in stores and analytics.
Angry user scenario
Pretend you’re a pissed off user:- Something failed. Can you quickly undo, retry, or contact support from inside the app?
- Is there one obvious place to report an issue? Even a simple “Email us” prefilled with debug info can save you.
Security “assume compromise” pass
Instead of just checking tech (HTTPS, no keys in frontend etc, which you should already have from @mikeappsreviewer), ask:- If someone got access to my database, what’s the worst thing they could learn or abuse?
- Can I reduce stored data, anonymize more, or separate critical tables so the impact is smaller?
This mindset is often more useful than only ticking crypto / TLS boxes.
Permission & trust sanity check
- For every permission or piece of PII you collect, write one sentence explaining “why this is needed” in plain language.
- If you feel even slightly awkward writing it, your users will feel worse reading it. Reconsider or make it optional.
Performance from the user’s feel side
Not just metrics like cold start time:- Are there any spins / loaders > 1.5–2 seconds with no skeletons or progress feedback?
- Anywhere you can fake speed with optimistic UI: show changes in the UI immediately, then sync in background and rollback only on error.
Apps that “feel” snappy often just hide waiting better.
Version 1 churn trap
Before launch, decide:- What are the one or two metrics you’ll watch for the first 2 weeks? Example: Day 1 retention and completion rate of the main action.
- Set a “panic threshold.” For example, “If less than 30% of new users reach X in their first session, I pause marketing and fix onboarding.”
Most people ship, then drown in random analytics without a plan.
Your own “rage test”
Use only your app for its purpose for 3 days. No cheats, no console hacks, no bypassing flows.
Every point where you silently think “ugh this is annoying but I know why it’s like that” is exactly where a real user will bounce. Fix those even if they’re not “bugs.” -
Release strategy
Instead of one big drop:- Soft launch to a very small audience (country, group, or web: just share link with 20 people).
- Collect 5 specific things: one confusion point, one thing they loved, one broken thing, one missing thing, one thing they would delete the app over.
Don’t try to fix everything. Fix just the recurring ones.
Don’t over-polish v1
Slight disagreement with the heavy checklist approach: if this is a small app and not handling payments or serious PII, you do not need to pass a full enterprise-grade review cycle before launch.
It’s usually better to:
- Hit the most critical security and crash issues.
- Make onboarding clear enough.
- Ship, then iterate fast with real users instead of endlessly polishing alone.
If you share what stack you used and whether this is mobile, web, or desktop, people can dig in on more stack-specific failure points (like local storage vs keychain, specific frameworks, etc). Right now, you’re probably closer to “ready” than it feels.
Skip the generic checklist stuff since @sternenwanderer and @mikeappsreviewer already nailed that. Here are the higher‑level review steps I’d add before you ship:
Define “ship criteria” in writing
- List 3 categories:
• Must-have for launch (e.g., no data loss, no blocking crashes, onboarding path works).
• Nice-to-have (micro animations, tiny layout glitches, rare edge-case bugs).
• Post-launch ideas (new features, A/B tests). - If something pops up, force yourself to put it in one of those buckets. This stops you from endless tweaking.
Map a “one-session story”
- Write the exact narrative of a first-time user:
“Install → understand what this app does in 5 seconds → do main action → see a win → know what to do next.” - Now test if your UI actually matches that story in one uninterrupted session.
- If the story breaks at any point (confusing screen, unclear result), fix that before more technical polish. Confusion kills faster than a slow API.
Test “edge emotions,” not just edge cases
Everyone checks edge logic (weird inputs, lost network). You should also check edge emotions:- Very rushed user: can they complete the primary action in under 30 seconds, tapping quickly without reading everything?
- Very cautious user: will they find enough explanation, help, and confirmation to feel safe doing the thing?
If either group gets stuck, you will see churn, even if your flows are correct.
Reality check on your scope
Here I slightly disagree with the “don’t over-polish v1” idea. It depends on what your app touches:- If you handle money, health info, or anything with legal risk, your “v1” needs stricter security and data review than an average side project.
- If it is a casual utility or a toy, bias to shipping earlier and watching real behavior.
Use risk level, not version number, to decide how far you go with your review process.
Compare “what you promise” vs “what you measure”
- Look at your store description and main tagline. If you say “Plan your day in under a minute” but do not track “time to first completed plan,” you are blind to your main claim.
- Add only 3 to 5 metrics that directly trace the promise: time to first success, completion rate of core task, return rate in 24 hours.
Your review process is solid when each promise has at least one metric.
Plan the first hotfix before launch
- Decide now what your 1.0.1 or first patch will target: crashes, a specific confusing screen, or slow API call.
- Set up your release pipeline so you can ship that patch fast (within 24–72 hours).
A strong process is not only “what you check pre-launch,” but also “how fast you correct mistakes.”
Do a “docs & expectations” pass
- In‑app help, FAQ, or even a short “How it works” screen.
- One clear place for users to reach you (feedback, bug report, or contact).
- Short explanation of data usage in plain language.
This is boring but massively affects trust and review scores.
About the empty product title you mentioned, here is a quick pros / cons structure you can adapt for your eventual launch material:
Pros for “”:
- Simple to market if the name clearly reflects the app’s main outcome.
- Easy to build a focused app review process because you can align tests with the core promise.
- Lightweight enough that you can iterate quickly post‑launch.
Cons for “”:
- Generic or unclear naming can hurt first‑impression metrics if users cannot guess what it does.
- If the scope grows later, the original name and early review checklist may not cover new risk areas.
Finally, quick note on the others:
- @sternenwanderer brought in a more strategic angle: expectations, permission justification, soft launch tactics. That is great for long‑term retention.
- @mikeappsreviewer delivered a very thorough checklist across usability, security, performance, and stability. Strong baseline, but it can feel heavy for a small low‑risk app.
Use their lists as foundations, then run the “story,” “emotion,” and “promise vs metric” checks above. That combination gives you a review process that is not only safe and fast, but also tightly aligned with what your users actually experience.
