Need help with the Vidmate app not working properly
Is anyone else having issues with the Vidmate app not loading videos or downloading content lately? It used to work fine, but now it keeps buffering, crashes often, and some features don’t respond at all. I’ve tried reinstalling, clearing cache, and checking my internet connection, but nothing seems to fix it. Can someone explain what might be causing this and suggest any real working solutions so I can use the Vidmate app normally again?
Yeah, a bunch of people are having issues with Vidmate lately. It looks like a mix of app bugs and video site changes.
Stuff you can try that often helps:
  1. Clear cache and data
    • Android Settings
    • Apps
    • Vidmate
    • Storage
    • Clear cache, then Clear data
    You will lose app settings, so note them first.
  2. Check version and source
    • Make sure you use the latest version from the official site, not random mirrors.
    • Old versions often break when Youtube or other sites change their code.
    • If you already have latest, try rolling back one version if you can find it. New releases sometimes break more than they fix.
  3. Turn off battery and data limits
    • Settings
    • Apps
    • Vidmate
    • Disable “Battery optimization” for Vidmate.
    • Allow background data and unrestricted data.
    This helps with random buffering and crashes when you switch apps.
  4. Change download settings
    In Vidmate settings:
    • Turn off “Fast download” or multi thread download.
    • Reduce resolution for test, like 480p.
    • Switch download path to internal storage instead of SD card. SD cards fail a lot and cause crashes.
  5. Check network
    • Try on Wi‑Fi and on mobile data, compare behavior.
    • Test speed with something like fast.com.
    If your ping is high or speed jumps a lot, buffering gets worse.
    DNS change sometimes helps. Example: set 1.1.1.1 or 8.8.8.8 in your Wi‑Fi DNS.
  6. Disable VPN or adblock for test
    Some VPNs or DNS adblockers break video loading.
    Turn them off, restart the app, test again.
  7. Storage space
    • Keep at least 10 percent of internal storage free.
    • If storage is almost full, downloads fail and the app freezes.
  8. Reinstall clean
    • Uninstall Vidmate.
    • Reboot phone.
    • Download latest APK from official site and reinstall.
    Do not restore old backups of the app data.
If after all that the app still buffers and crashes, it is likely a server or compatibility problem on their side. Then your options are:
• Wait for next update.
• Try an alternative like SnapTube, YTD Video Downloader, or NewPipe from F‑Droid. NewPipe is lighter and works better on older phones, but has fewer fancy features.
I had similar issues last month on a Xiaomi phone. Clearing data and disabling “Fast download” fixed the crashes. Rolling back one version stopped the random freezing on some videos.
Yeah, you’re not the only one, Vidmate’s been kinda janky lately.
@himmelsjager covered most of the “normal” fixes, so I’ll skip the whole clear-cache / reinstall checklist and add a few angles that people usually miss:
  1. Check if it’s specific sites breaking
    If it hangs mostly on YouTube or a couple of other sites but works fine on others, that’s usually because those sites changed their code and Vidmate hasn’t caught up. That’s not something you can fix on your side, no matter how many times you reinstall. In that case, you’re basically waiting for an update or using another app for that one site.
  2. Try older Android WebView
    Vidmate depends a lot on Android System WebView. If WebView or Chrome just updated, some apps that embed it start crashing or getting super laggy.
    Go to:
    Settings → Apps → Android System WebView
    • Try uninstalling updates (or rolling back)
    • Or update it if it’s old
    Then reboot and test Vidmate again.
    I’ve seen this help more than any cache-clearing nonsense.
  3. Turn off any “smart” system cleaners
    Some OEM “security/optimizer” apps silently kill background tasks or block file writes, which breaks downloads mid way and makes apps look buggy.
    • Turn off automatic “cleaner” / “booster” / “RAM optimizer”
    • Add Vidmate to their whitelist/ignore list
    If you notice crashes only after a while or when the screen is off, this is very likely the cause.
  4. Test in a fresh user profile
    If you’re on Android, create a new user or guest profile, install only Vidmate there, and try it:
    • If it works fine in the fresh profile, something in your main profile (another app, permissions mess, some system tweak) is interfering.
    • If it’s broken even there, it’s either Vidmate itself or OS-level stuff.
  5. Check for “draw over other apps” conflicts
    Some floating apps (bubble messengers, screen filters, overlays, even some adblock UIs) can mess with video views and click areas inside Vidmate. You get buttons not responding or the player freezing.
    Try disabling:
    • Screen dimmer / blue light filter
    • Floating messengers / bubble apps
    • System-wide adblock overlays
    Then reopen Vidmate and test the same video.
  6. Storage filesystem issues
    If your phone has been hard-crashing or you pulled the SD card without unmounting, the file system can get corrupt enough that big writes fail. Vidmate then half-starts a download and dies.
    • Run any built in storage check if your phone has it
    • Temporarily set download folder to a different internal path, not just “internal storage root”
    If downloads suddenly start working from a new folder, the original path might be messed up.
  7. Don’t overtrust “fast download” myths
    Here I’ll slightly disagree with the general advice: in some ROMs, multi-thread download actually works fine and the real issue is the number of simultaneous tasks.
    Try:
    • Keep fast / multi-thread on
    • But set “max downloads” to 1
    When I had similar issues, limiting it to a single active download made things stable without killing speed.
  8. Check OS-level background restrictions globally
    Not just per app. Some phones have a global “data saver” or “ultra power save” that hits all non-system apps. If you toggled something like that recently, video apps are usually the first to break. Turn that off completely as a test.
At the end of the day, if:
• Multiple sites fail the same way
• The app crashes even on good WiFi
• And a clean install on a fresh user profile is still busted
…then it’s almost certainly on Vidmate’s side. In that case, best move is:
• Keep an older version backed up if you find one that works
• Use a backup app like NewPipe / SnapTube / whatever in parallel until Vidmate catches up
You’ve already tried reinstalling, so I’d focus on WebView, background killers, and testing a fresh profile next.
Short version: if Vidmate suddenly went from “fine” to “barely usable,” there is a good chance it is not just your device, but there are still a few angles left that @vrijheidsvogel and @himmelsjager did not fully cover.
1. Check if your region is being throttled or blocked
Some ISPs started quietly throttling or partially blocking video grabber apps. Signs:
  • Other streaming apps are OK, but Vidmate is super slow or times out.
  • Same on Wi‑Fi and mobile with the same provider.
What to try:
  • Test Vidmate on a completely different network and provider (friend’s Wi‑Fi, work, public hotspot).
  • If it suddenly works, the issue is probably your ISP shaping traffic related to video downloads.
If that is the case, constant buffering and failed downloads will continue until you:
  • Use a different provider or
  • Route traffic differently with a proper VPN profile that actually changes routing, not just DNS.
2. Permissions audit inside Android
Vidmate looks like it is running even if it cannot write or read where it wants to. Go to App info → Permissions and triple check:
  • Storage / Files and media: must be allowed.
  • “Manage all files” (on newer Android versions): if your system offers this, turn it on for Vidmate.
  • If you recently denied a permission popup in a hurry, some features will silently half‑work and crash.
Sometimes people reinstall the app but forget they picked more restrictive permissions the second time.
3. OS upgrades & ROM quirks
If your phone recently:
  • Got an Android major update
  • Switched to a custom ROM
  • Installed a big OEM update
then older Vidmate builds can become flaky:
  • Hardware acceleration may fail
  • Video decoder paths change
  • Scoped storage rules break the old download logic
In that situation:
  • Try a version of Vidmate that was released after your OS update, not older.
  • If you use any custom kernel / Magisk modules that touch networking or I/O, disable them temporarily. Things like custom TCP tweaks, aggressive I/O schedulers, or “performance” modules can corrupt large file writes and cause random crash bugs.
4. Conflict with security apps & parental filters
Unlike what many people expect, the culprit is often:
  • “Security” suites
  • Content filters
  • Built‑in parental controls
They might:
  • Block specific video host domains used by Vidmate
  • Kill / sandbox the download process
  • Interfere with SSL inspection
Steps:
  • Temporarily disable those apps or filters.
  • If you have any system‑wide “safe browsing” or “kid mode” turned on, turn it off just to test Vidmate.
  • Some antivirus tools inspect large downloads and slow them to the point it looks like buffering. Try whitelisting Vidmate in those tools.
5. In‑app behavior tweaks (not just fast download)
The “fast download” toggle was covered already, but Vidmate has other subtle things that affect stability:
  • Turn off auto‑play of recommendations.
  • Disable in‑app “browser ad block” if there is such a toggle; the built‑in adblock layer sometimes breaks page scripts that Vidmate relies on to detect the video.
  • In settings, look for a “simple player” or “system player” option and use that. Hardware‑accelerated custom players can crash on certain codecs, while the system player often just works.
Here I slightly disagree with the “always reduce resolution” pattern: if the issue is decoding or codec support, lower resolutions might not help. Sometimes changing the format (for example, downloading MP4 instead of WebM or vice versa) matters more than resolution.
6. Check if video hosts are returning errors, not just buffering
Open the same link:
  • In Vidmate
  • In a normal browser
If:
  • Browser plays fine, but Vidmate fails every time for that site only, then the extractor logic for that host is broken in Vidmate.
  • Browser itself also keeps stalling, but other streaming sites work, then that single host or CDN node is sick.
In those cases:
  • Use Vidmate only for the hosts that still work cleanly.
  • For the problem host, use an alternative app or direct streaming until Vidmate updates.
7. Long‑session problems
Some builds of Vidmate have memory leaks:
  • Works fine after you open it
  • Gets slower, more buffering, then crashes after you have been browsing and queuing stuff for a while
Mitigation:
  • After a few downloads or a long browsing session, fully close Vidmate from recent apps and reopen.
  • Avoid keeping the player in PiP or background for hours; that seems to trigger leaks on some phones.
8. When to just switch apps
If you have:
  • Reinstalled
  • Checked WebView and Chrome
  • Tested another network
  • Verified permissions
  • Killed security / cleaner / parental blockers
and it is still a crash fest, then it is likely a Vidmate‑side issue affecting the current release.
In that situation, it is practical to:
  • Keep Vidmate only for the few sites that still behave.
  • In parallel, use one of the competitors already mentioned in this thread like NewPipe, SnapTube or similar tools while waiting for a fixed Vidmate build.
Pros of sticking with Vidmate app:
  • Familiar interface and workflow.
  • Handles multiple sites in one place.
  • Has integrated browsing and batch downloads that are very convenient when working.
Cons of relying on Vidmate app right now:
  • Breaks every time big video sites change layout.
  • Sensitive to ROM updates, WebView changes and OEM “optimizations.”
  • Bugfix cadence can lag behind the changes on major hosts, so you end up in cycles of things working, then not, then working again.
@vrijheidsvogel and @himmelsjager already nailed most standard fixes. If your issue survives their list plus the extra checks above, odds are good that it is either your ISP shaping this type of traffic or a temporary compatibility problem in Vidmate itself. At that point, switching apps for a bit is usually less painful than endlessly tweaking settings.
Try one simple fix, remove power throttling.
Phones kill background downloads, which looks like buffering or crashes.
Do this:
  • Settings, Apps, Vidmate, Battery, Unrestricted.
  • Settings, Apps, Special access, Ignore battery optimizations, allow Vidmate.
  • Data usage, Backgroud data on for Vidmate.
    Keep teh screen on or plug into power for big files.
    Optional, in Vidmate settings, pick System Download Manager for downloads. This avoids stalled writes on some ROMs.
    If it helps, dont forget to reenable other stuff later.
