Need Help With Outlook Pst File Recovery
My Outlook PST file became corrupted after a sudden shutdown, and now I can’t open important emails, contacts, or old messages. I need help with Outlook PST file recovery and the safest way to repair the file without losing data.
I ran into this once after cleaning out old folders, and Outlook threw the lovely “file cannot be found” message. In my case, the missing file was a PST I had deleted without noticing. If this happened to you, stop messing around on the PC for now. Every file write gives Windows more chances to reuse the space where the old PST was sitting. Once that space gets reused, recovery gets uglier fast.
What I’d do first
Start with the boring checks. They save time.
1. Check the easy places
Open the Recycle Bin. A normal delete often leaves the PST there. If you used Shift+Delete, then yeah, it skipped the bin.
After that, check any sync or backup service tied to your user folders. If Documents was syncing to OneDrive, Dropbox, or something similar, log in through the web panel and look at deleted files or version history. I’ve seen OneDrive save people from their own cleanup sessions more than once.
2. Try Windows previous versions
If File History, shadow copies, or restore points were active, Windows might still have an older folder snapshot.
The usual PST location is:
C:\Users\YourName\Documents\Outlook Files
Right-click the folder, pick “Restore previous versions,” and check dates from before the PST vanished. If you find one, open it and copy the PST somewhere safe first. Don’t restore over the whole folder right away. I’d copy out the file and keep the original setup untouched until I knew what worked.
3. Run recovery software
If the file is gone from the bin and Windows shows no earlier versions, then recovery software is the next move.
Disk Drill gets mentioned a lot for deleted file recovery, and for good reason. It scans past what File Explorer shows you. One thing matters here, don’t install it onto the same drive where the PST was deleted if you have another option.
This is the order I’d follow:
Install the recovery app to another disk, external drive, or even a USB stick if you’ve got one.
Scan your Windows drive, usually C:.
Filter or search for .pst files.
Pay attention to file size. A blank replacement PST might be tiny, sometimes only a few hundred KB. Your real mail archive is often hundreds of MB, sometimes multiple GB.
Recover the larger PST to a different location, not back onto the same drive sector you’re trying to save.
4. Watch for Outlook making a fake fresh start
This part confused me the first time. Outlook often reacts to a missing PST by making a new empty one. So Outlook opens, looks normal-ish, and all your old folders are gone. It feels worse than a crash because it looks clean and empty.
If you recover the old PST, load it by hand:
File > Open & Export > Open Outlook Data File
Pick the recovered PST. If the recovery worked, your old folders should show up in the left pane. Once you confirm the messages are there, go into Account Settings and point Outlook back to the recovered PST as the default data file.
5. If your account used IMAP, your mail might still be online
This part matters. If the account was IMAP, the inbox and synced folders often still live on the mail server. When you re-add the account, Outlook creates a new OST and pulls mail back down.
The stuff I’d worry about is local-only data. Old archives, imported folders, mail moved into personal folders, and anything stored outside synced server folders. Those items often lived only inside the deleted PST. If you had years of saved mail in local archives, that recovery scan is the main event.
After you get it back
Once the PST is recovered, make a backup right away. I keep a copy on an external drive now because I learned this the dumb way. Adding it to cloud backup helps too. PST files are easy to forget until Outlook breaks and you realize your mail history was sitting in one file the whole time.
If your scan turns up a large PST, start with that one. Small PSTs are often the empty replacement files Outlook made after the original went missing.
Stop opening Outlook for now. Every failed launch writes temp data and sometimes makes the damaged Outlook email archive file worse.
I’d take a different path than @mikeappsreviewer. Their deleted-file angle is useful if the file vanished. Your case sounds more like corruption after a crash, not deletion. Different fix.
Do this first.
  1. Copy the damaged .pst to another folder or external drive.
  2. Work only on the copy.
  3. Check file size. If it dropped to 0 KB or a tiny size, repair tools won’t help much.
Next, run Microsoft’s Inbox Repair Tool, scanpst.exe. It ships with Outlook. Common path is under Program Files\Microsoft Office\root\OfficeXX. Run it 2 or 3 times if needed. First pass often fixes the index, second pass cleans more errors. Annoying, but true.
If ScanPST fails or hangs, use Outlook in safe mode, outlook.exe /safe, then create a new profile from Control Panel, Mail, Show Profiles. Open the repaired file from there. Sometimes the profile is busted, not the data file. Peeople miss this a lot.
For severe corruption, a recovery app helps. Disk Drill is better for file recovery if the Outlook data file is missing, renamed, or partly lost after disk issues. If the drive itself has bad sectors, recover the file off the disk first, then attempt repair.
Also check whether your mail account was IMAP or Exchange. If yes, email may resync from server. Contacts, calendar, and old local archive folders are the big risk.
This explains what an Outlook email archive file is in plain English:
what an Outlook PST archive file stores and why it matters
One more thing. Do not compact the file. Do not import it yet. Repair first, then open it. That avoids extra mess.
I’d split this into two separate problems, because people mix them up all the time: corrupted PST vs missing PST. @mikeappsreviewer leaned more into recovery if the file disappeared, and @techchizkid covered ScanPST, which is the obvious first move. I slightly disagree with the “run it 2 or 3 times no matter what” advice though. If the drive is unstable, repeated repair attempts can be a bad idea. Clone or copy first, then test.
A couple things I’d add:
  1. Check Event Viewer
    Windows Logs > Application. Look for Outlook, disk, or NTFS errors around the shutdown time. If you see disk warnings, stop focusing only on Outlook. The storage may be the real issue.
  2. Test the PST from a different machine
    Copy the PST to another PC with Outlook installed and try opening it there. That helps separate “bad PST” from “broken Outlook profile / Office install.”
  3. Use SCANPST logs
    A lot of ppl run ScanPST and just click through. It creates logs. Read them. If it reports header damage or truncated structure, that tells you whether the file is salvageable or just partly recoverable.
  4. Export what opens first
    If the PST mounts even partially, don’t wait. Drag out critical folders or export immediately. Start with Contacts and any old archive folders.
  5. If the file won’t copy cleanly
    That’s where Disk Drill becomes more relevant, not just for deleted PSTs but when the drive has read issues and you need to recover the Outlook data file before more sectors go bad. Save recovered data to another drive, obviosuly.
Also, if you want a better sense of user feedback before trying it, read real Disk Drill user reviews for Outlook PST recovery.
One more caution: don’t mount the damaged PST directly from a flaky external drive or network share. Copy local first. Outlook gets weird and makes a bad situation worse, lol.
I’d add one angle the others only hinted at: verify whether the PST is actually encrypted or just “password protected.” Some crash-damaged PSTs throw misleading corruption errors when the header is damaged. If you have another Windows account or another Outlook install, try attaching the copied PST there before doing anything destructive. That separates file damage from a weird local Outlook config issue, which @techchizkid and @himmelsjager both touched on indirectly.
Also, I would not rush into importing the file even after it opens. Open it as a secondary data file first, then copy out the most important folders. Import can reshuffle folder structure and duplicate items, which is a pain during recovery.
If ScanPST gets nowhere and the drive itself is acting flaky, that’s where Disk Drill makes sense. Not as a magic PST fixer, but as a way to pull a readable copy off unstable storage before the file gets worse.
Pros for Disk Drill:
  • good if the PST is missing, unreadable from disk errors, or was replaced
  • easy to filter by file type and size
  • useful when Windows can still see the drive but not the file properly
  • not really a true PST repair tool
  • deep scans can take forever
  • recovered files may still need Outlook-side repair afterward
So my order would be: preserve the file, test on another machine, attach instead of import, then use Disk Drill only if storage issues or file disappearance are part of the problem. @mikeappsreviewer leaned more into deletion recovery, which is valid, but for straight corruption I’d treat disk health as the tie-breaker.
