My GT73 Pro started having problems out of nowhere, and I’m not sure what caused it. I’ve already tried a few basic fixes, but nothing has worked so far. I need help figuring out what’s wrong and the best way to get it running properly again.
GT73 Pro issues tend to fall into 4 buckets. Power, thermals, storage, or GPU.
Start with the easy stuff.
- Do a full EC reset. Shut it down. Unplug charger. Hold power button 30 seconds. Plug back in and test.
- Boot into BIOS. If it freezes there, this is likely hardware, not Windows.
- Check temps in BIOS or with HWInfo if it still boots. GT73 units often act weird when the fans clog up or paste dries out.
- Reseat RAM and SSDs. Bad contact causes random crashes, black screens, boot loops.
- Run memtest. One bad stick will ruin your day fast.
- Check the power brick wattage and LED. Weak adapter, bad charge port, or a dying battery causes random shutdowns.
If your symptoms showed up ‘out of nowhere’, I would look hard at heat and storage first. Old MSI laptops do this a lot. If the HDD or SSD has SMART errors, replace it. If temps spike over 95C under load, clean it and repaste.
Post the exact symptoms. No boot, black screen, freezes, BSOD, fan spin, battery issue, artifacting, all of thsoe point to different parts. Without that, people are gueesing.
I’d add one angle @himmelsjager didn’t really hit: firmware and GPU mode weirdness. On the GT73 Pro, a bad BIOS/EC state or broken Nvidia driver stack can look exactly like “dead hardware” when it’s not.
A few things I’d try that are different:
- If it still reaches Windows sometimes, boot into Safe Mode and completely remove Nvidia drivers with DDU, then reinstall a known stable version. Not the newest one by default. Older MSI laptops can get real picky.
- In BIOS, check if graphics mode changed, or if there’s any option tied to discrete graphics only. Sometimes it gets stuck acting dumb after an update or crash.
- If you recently updated Windows, roll back chipset / Intel ME / GPU drivers before doing anything extreme.
- Test with an external monitor. If laptop screen is black but external works, that points more at panel, cable, or mux-related jank than a dead board.
- Pull any USB devices, SD cards, dongles, extra monitors, all of it. I’ve seen one flaky USB device cause endless boot nonsense. Stupid, but real.
- If the system powers on but is unstable only under load, don’t assume thermals first. I kinda disagree with going straight there every time. On these, VRM or GPU power delivery can also start failing and it looks similar.
Most useful thing now is symptom pattern:
- instant shutdown = power
- boots then black screen when driver loads = GPU/driver
- freezes only while gaming = GPU/power/VRM
- super slow, stuttery, disk at 100% = dying drive or Windows corruption
- no image, keyboard lights on = display path or GPU
Post exactly what it does when you press power. Fan spin? keyboard lights? MSI logo? beeps? That narrows it down fast.
I’d go one level more basic than @himmelsjager and the GPU/firmware angle: verify the power path before chasing software too hard.
For a GT73 Pro, the charger and DC jack are common enough suspects. These machines pull serious wattage, and a weak adapter can make them act haunted. Charge light behavior matters a lot here. If battery percentage drops while plugged in, or it only crashes when the GPU should wake up, I’d test with another known-good MSI adapter first.
Also check RAM the old-school way:
- remove both sticks
- test one stick at a time
- swap slots
Bad RAM on these can cause black screen, boot loop, random freezing, or no POST with lights/fans still working.
Storage is another big one. If it hangs at logo, takes forever to boot, or keeps “repairing” Windows, disconnect the main drive and see if BIOS becomes stable. A dying SSD can make the whole laptop look dead.
If you already opened it, inspect for:
- burnt smell near power components
- swollen battery
- dust mat blocking heatsinks
- fan that twitches but does not spin right
I slightly disagree with not prioritizing thermals early. On older GT73 Pro units, dried paste and clogged fins are extremely common, and thermal shutdown can look like motherboard failure.
Pros for the ‘’: can improve readability if you’re organizing your troubleshooting notes. Cons for the ‘’: not really relevant unless you’re documenting fixes.
Post whether it reaches BIOS reliably. That’s the fork in the road.
