I’m locked out of a few important accounts after switching phones because my Microsoft Authenticator App codes and backups didn’t transfer correctly. I can’t approve sign-ins or recover the accounts, and I’m not sure what recovery options I have left. Can anyone walk me through how to restore access or safely reset the app without losing my accounts
Been there. Microsoft Authenticator plus a new phone is a mess if backup was not set up right.
Here is what usually works, step by step.
Figure out if your Microsoft account has Authenticator backup
- On the new phone, install Microsoft Authenticator.
- Sign in at the top with your personal Microsoft account.
- If a backup exists, it will prompt you to restore from cloud.
- If you do not see a backup, then your old phone never had backup toggled on.
If you still have the old phone
- Connect it to Wi‑Fi.
- Open Authenticator.
- Go to Settings, turn on Cloud backup or iCloud backup, wait a minute.
- On the new phone Authenticator, sign in with the same Microsoft account, restore again.
- Once accounts show up, try a login to one site to confirm codes work.
If you lost the old phone or wiped it
Recovery depends on each site. You have to do this for every account that used the app.For Microsoft accounts (Outlook, OneDrive, Xbox, etc):
- Go to https://account.live.com/proofs/manage
- Choose “I do not have any of these” when it asks for the Authenticator.
- Use email or SMS fallback if you had one.
- If you see “account recovery form”, fill it with:
• Old passwords.
• Subject lines of recent emails.
• Contacts you emailed.
• Xbox Gamertag if you have one.
Microsoft often locks recovery for 24 hours or up to 30 days while they verify.
For work or school Microsoft 365 accounts:
- If your account is from a job or school, IT controls it.
- Contact your IT helpdesk or admin.
- Ask them to reset your MFA and re-register your Authenticator.
There is no way around admins for those.
For other services that used Authenticator (Google, Facebook, etc)
- Go to each site’s login page.
- Choose “Trouble with two step verification” or similar.
- Use backup codes if you saved them.
- If not, use their account recovery route. Often they ask for ID or previous data.
- Once in, turn off old 2FA, then set it up again with the new phone. Save backup codes this time.
For the future, when you get back in
- Turn on Authenticator cloud backup on iOS or Android.
- Save every site’s backup codes in a safe place.
- Add at least one extra method on each account: SMS, email, or a second device.
- For critical accounts like email, set recovery email and phone and make sure they work.
Harsh truth: if an account has no backup methods, no recovery info, and no admin, support might refuse to unlock it. That is by design for security, even though it feels awful when you are locked out.
Start with Microsoft account recovery and your work or school IT. That usually gets the main stuff back. Then go one service at a time.
Couple of extra angles to try that @byteguru didn’t cover, in case you’re still stuck:
Check if you actually need the app, or just a code
Some Microsoft prompts look like “approve in the app,” but you can often switch to a code-based method:- On the sign‑in screen, look for “I can’t use my Microsoft Authenticator app right now”, “Sign in another way”, or tiny text links at the bottom.
- Sometimes it will then offer SMS, email, or a different authenticator code option that people miss because the UI is sneaky.
Browser & device tricks
If you were logged in on any browser or device before the phone switch:- Check if that session is still active. Don’t log out.
- From there, go to the account security page and add another sign‑in method (SMS, alternate email, a second authenticator like Google Authenticator, hardware key, etc.).
- For work/school accounts, check if Outlook desktop, Teams, or OneDrive desktop is still signed in. Sometimes you can reach the Security Info page through those.
If Authenticator restore “worked” but codes still fail
This happens after phone migrations sometimes:- On the restored account list, tap one Microsoft account that is failing.
- Remove it from Authenticator, then go to the account’s “Security info” page in a browser and re‑add it by scanning a fresh QR code.
- For non‑Microsoft services, same idea: log in using any available backup method, delete the old 2FA device, and set it up again.
Outlook / Xbox / OneDrive specific tip
If you’re stuck on a Microsoft personal account and the recovery form keeps rejecting you:- Wait the full 24 hours or 72 hours if they tell you to. Retrying too often resets the clock.
- Use a different browser and IP when you retry (home network instead of work VPN, for example). Sometimes their risk engine is less paranoid that way.
- When they ask for info, don’t half‑fill it. Dump as much accurate detail as possible in one go. Multiple weak attempts can hurt more than one very complete one.
Work/school twist: SSPR & combined registration
For org accounts, @byteguru is right that IT is king, but check this too:- If your org has self‑service password reset (SSPR) or combined security registration enabled, you may be able to reset MFA yourself by going to:
https://aka.ms/ssprorhttps://aka.ms/mysecurityinfo
- Sometimes there is a “I can’t access my Authenticator app” or “I forgot my password” path that lets you verify via phone call, SMS, or a backup method you set months ago and forgot about.
For sites that only used TOTP codes and nothing else
If a site used the app just as a 6‑digit code generator (no push notifications):- Check if you exported the QR code or secret key when you first set it up. Some people save a screenshot or write it down. If you have that, you can re‑enter it into any TOTP app.
- If you don’t have the secret and there is no backup method, you are literally proving why 2FA is secure. Many sites will not unlock that account at all without ID or very strong proof.
For the future, slightly different strategy than pure cloud backup
I actually disagree a bit with relying only on the Authenticator cloud backup like @byteguru suggested: it’s helpful, but it gives a false sense of safety. I’d do:- For every critical account, save the emergency backup codes offline.
- Prefer at least two types of MFA per account:
- An authenticator app
- And either SMS, FIDO2 security key, or another device
- Consider using a password manager that stores 2FA secrets as an extra backup layer, if you’re comfortable with that.
If you list which services you’re locked out of (Microsoft personal, Microsoft 365 work/school, banks, socials, etc.), people here can probably give you more targeted “click this exact link, then that option” type steps.
Skip the panic and start by mapping your situation, not just poking random recovery links.
List exactly what you lost access to
Separate into buckets:- Personal Microsoft stuff (Outlook, OneDrive, Xbox)
- Work / school Microsoft 365
- Other services that used Microsoft Authenticator codes (banks, socials, dev tools)
This helps because each bucket has a completely different recovery path and time frame.
Check for any “still logged in” session you might be forgetting
@nachtschatten and @byteguru already walked through backups and standard recovery. I would first hunt for existing sessions:- Any browser where Outlook / Office is already open
- Desktop apps: Outlook, OneDrive sync client, Teams, Xbox app
If you find one that still works, do not sign out. From there, go straight to the account’s security settings and add: - A second authenticator app
- SMS / phone
- A hardware key if you have one
This is often the one loophole that avoids the whole recovery-form pain.
Do not over-retry recovery forms
I actually disagree a bit with the “keep trying” instinct. With Microsoft’s risk system, too many failed recovery attempts can make the system more suspicious and stretch out the lock. Instead:- Prepare your best possible recovery attempt offline first (email subjects, contacts, billing info).
- Submit once, fully and carefully.
- Then wait the delay they specify rather than hammering it.
Check if your org has stricter conditional access rules
For work/school accounts, everyone says “contact IT,” which is true, but ask them specific things:- Do they have Conditional Access policies that only allow push approvals on Microsoft Authenticator? If yes, they may have to temporarily relax that or add SMS / another method for you.
- Ask if they support FIDO2 security keys or Temporary Access Pass. Both can bypass the missing phone problem when set up by IT.
For non‑Microsoft sites that used the Authenticator TOTP codes
Many sites label it “Microsoft Authenticator” but really it is just any TOTP app. If recovery is failing and you are considering giving up:- Before abandoning an account, open their help or support pages and search for “reset 2FA” or “lost authenticator device.” Some services hide a secondary workflow behind support tickets or ID verification that is not obvious from the login page.
- If the site is less critical and recovery looks impossible, accept that you might have to create a new account rather than burning time on something they intentionally locked down.
About relying on Authenticator backups
Both @nachtschatten and @byteguru covered backups well, but I would not treat Microsoft’s cloud backup as your only safety net. It is convenient, but:- It can silently fail if you switch phones/platforms at the wrong moment.
- Restored entries for third‑party sites can look fine while codes are actually invalid, because the secret changed.
So once you regain access, do a slow audit:
- One account at a time, log in, remove the old 2FA device, and re‑enroll your current device.
- Store each site’s backup codes somewhere offline and boring, not just in the Authenticator ecosystem.
Pros & cons of sticking with Microsoft Authenticator long‑term
- Tight integration with Microsoft accounts and passwordless sign‑in.
- Push approvals are fast and nicer than typing codes.
- Built‑in backup feature when configured correctly.
- Very Microsoft‑centric; recovery can be rigid.
- Phone‑centric model means losing the handset hits hard.
- Not as flexible for exporting TOTP secrets or moving to other tools.
Some people combine it with a general TOTP manager in a password manager, but that is a trade‑off between convenience and putting more eggs in one basket.
What I would do next, practically
- Spend 10 to 15 minutes checking every device you own for any live Microsoft or other account sessions.
- If you find none, prioritize recovering your main personal Microsoft account first, since that often controls backup email for other services.
- Only after that, work down your list service by service, treating each as a separate recovery project.
If you list which specific services are failing (for example: “personal Outlook + work 365 + bank X”), people here can probably outline exact clicks and the realistic odds of getting each one back.
