I just started using Dippy Ai and I’m confused about how to get accurate, useful responses for my projects. Sometimes it gives vague answers or misses key details I need. Can anyone explain best practices, settings, or prompt tips to get more precise and reliable results from Dippy Ai?
I had the same problem with Dippy Ai at the start. What helped:
- Be stupidly specific in your prompt
Instead of
“Explain X for my project”
try
“I am doing a project on [topic]. I need:
• 3 main points
• 2 concrete examples with numbers or sources
• Output in bullet points
• Keep it under 400 words
• Focus on [audience: devs, managers, students, etc].”
The more constraints you give, the less vague it gets.
- Tell it what you know and what you want
Example:
“I already know the basics of REST APIs. I need help with:
• Choosing auth method
• Tradeoffs between OAuth2 and API keys
• Example request and response.
Do not explain what an API is.”
You reduce fluff and force it to hit the gaps.
- Ask it to think step by step
End the prompt with stuff like:
“Reason step by step.
Explain assumptions.
If something is unclear, list questions you need to ask me before answering.”
This stops it from jumping to a generic answer.
- Use “persona” instructions
Tell it who it should act as. Examples:
“Act as a senior backend engineer with 10 years experience.
Use clear language.
No marketing speak.
Short sentences.
Give tradeoffs, not only pros.”
Or for research:
“Act as a researcher.
List sources and dates.
Separate facts from guesses.
If you are not sure, say so.”
- Force structure in the output
Tell it exactly how to format:
“Output sections:
- Summary
- Detailed steps
- Risks
- Next actions”
If structure is vague, answers drift.
- Use follow ups aggressively
Treat the first answer as a draft. Then:
• “Make this 50 percent shorter.”
• “Give 2 more examples, tech related.”
• “Turn this into a checklist.”
• “Highlight any missing risks.”
You get closer to what you need in 2 to 3 turns.
- For accuracy, ask it to show work
For anything factual or numeric:
“Show calculations.
List assumptions.
If data is older than 2024, say so.
Flag anything that looks like a guess.”
Then you can sanity check instead of trusting blindly.
- Set style rules once, reuse them
Make a “default style” you paste into new chats, like:
“General rules:
• Short, direct sentences.
• No fluff.
• Use examples with numbers.
• Prefer lists over long paragraphs.
• If you are unsure, say ‘unsure’ and offer options.”
Helps a ton for consistency.
- When it misses the mark, correct it hard
Example:
“This missed what I asked. You:
• Spent time on background I said I know.
• Did not include step by step instructions.
Try again, focus only on implementation steps, numbered.”
Clear feedback trains the session.
If you share one exact prompt you used and what you wanted from it, folks here can probably rewrite it and show you the diff. That helped me see how “good” prompts look compared to my first ones.
Couple of extra angles to add on top of what @cacadordeestrelas said, without just repeating “be specific” another 20 times:
- Use “pinpoint prompts” instead of giant blobs
If you throw a whole project description + 10 questions into one prompt, Dippy will often blur everything together and give a generic blob back.
Try splitting it:
- Turn 1: “Summarize this project in 5 bullets, then list the top 5 unknowns / risks.”
- Turn 2: “Focus only on unknown #2. Give me options, tradeoffs, and a concrete recommendation.”
- Turn 3: “Turn that recommendation into an implementation checklist.”
So you’re moving the convo like tasks in a kanban board instead of 1 mega request.
- Use “compare” prompts for clarity
Dippy is way less vague when you make it choose:
- “Compare option A vs option B for my use case: [1 sentence]. Use a table: columns = pros, cons, when to use, rough complexity.”
- “Act as a critic. What is wrong or risky about this idea: [idea]. Don’t be nice, be harsh.”
When it has to judge or contrast, it tends to get more concrete.
- Force it to commit, then sanity check
If answers feel hand-wavy, ask for a bet:
- “Give a specific recommendation and treat it as if you had to bet $1000 on it being the best option. Then list 3 reasons why you might be wrong.”
You’ll see both the “best guess” and the uncertainty, which is actually more useful than fake confidence.
- Use “iterative refinement” explicitly
Tell it the workflow instead of hoping it guesses:
- “Step 1: You ask me up to 5 clarifying questions.
Step 2: Propose a rough solution in bullets.
Step 3: I’ll pick one direction.
Step 4: You turn that into detailed steps.”
If Dippy skips a step, call it out:
“You skipped Step 1. Start over and ONLY ask clarifying questions now.”
- Control scope, not just style
Sometimes vagueness is just scope creep. Examples:
Bad:
“Help me with my whole SaaS idea from design to launch.”
Better:
“In this message, focus ONLY on: database schema for the user & subscription part. Output:
- Entities
- Fields with types
- 2–3 example queries”
You can do “chapters” of the project over multiple prompts.
- Use drafts you already have
Dippy is much sharper when you feed it something concrete:
- “Here’s my current outline / code / spec: [paste].
- Point out specific gaps or contradictions.
- Suggest 3 improvements.
- Rewrite only the [section name] with those fixes.”
Now it’s editing instead of hallucinating from zero.
- Calibrate creativity level
Vague answers sometimes come from it being too “creative.”
For factual / technical stuff:
“Be low creativity. Prefer boring but correct answers. If you’re not sure, say ‘not sure’ and suggest what info I should look up.” -
For brainstorming:
“Be high creativity. I want 10 weird ideas. Don’t worry about feasibility yet.”
You can literally say “low creativity” or “high creativity” to steer tone and risk-taking.
- Use “red team” mode for detail
If it’s glossing over edge cases:
- “Act as a QA engineer trying to break this. List:
• 10 edge cases
• 5 failure scenarios
• What logs/metrics I should add.”
This pulls out the stuff that usually gets skipped.
- Settings / habits that actually matter
Not platform-specific here, but generally helpful habits:
- New chat per subtopic if the conversation drifts. Long chats accumulate context and make the model guess what you really care about.
- Paste only what’s needed. Don’t dump entire project history if you’re asking about one function.
- When something is crucial, literally tag it:
“CRITICAL REQUIREMENTS:
• Works offline
• Must support 10k users
• Budget: small, no paid APIs”
Then refer back:
“Evaluate your answer against the CRITICAL REQUIREMENTS and highlight any conflicts.”
- When it’s vague, dissect why and say it
Instead of “this is vague,” try:
“You missed what I need because:
- You restated the problem instead of answering it.
- You gave theory, not steps.
- You didn’t reference the constraints I listed.
Try again, focusing ONLY on: [concrete thing].”
You’re teaching the session how you like answers, kinda like live fine-tuning.
If you want, drop one of your actual prompts + what you wish the answer looked like (even roughly). People here can re-write that prompt and you’ll see in 10 seconds why Dippy kept drifting.
Gonna zoom in on angles that weren’t really covered by @viaggiatoresolare and @cacadordeestrelas, especially how to debug Dippy Ai when it keeps going vague.
1. Treat each reply like “model output you’re testing”
Instead of “this answer sucks,” think:
- Did it:
- Ignore a constraint?
- Miss a subquestion?
- Add fluff?
- Then respond like a test failure:
“You missed X and Y. Do not do Z again. Re-answer only part B in ≤150 words, no background.”
You’re not just asking again, you’re narrowing the “allowed behavior.”
2. Use “anchor examples” in your prompt
Both of them talked about structure and personas. One thing they did not push hard enough: giving Dippy Ai a mini example of what “good” looks like.
Example:
“Here’s the style I want (short sample):
- Bullet points
- Concrete numbers
- Brief intro, no conclusion paragraph
Now answer my question in that style.”
Or:
“Bad answer example: long theory, no steps.
Good answer example: 5 bullets, each starts with a verb + has 1 concrete detail.Follow the ‘good answer’ pattern.”
Models latch onto patterns much better than abstract instructions.
3. Make Dippy Ai evaluate itself before you do
This is underused and very effective for accuracy and focus:
Ask your question normally.
Then append:
“Before giving the final answer, first:
- List 5 checks you will use to verify your answer matches my request.
- Run those checks against your own draft.
- Only then output the final version.”
You basically force it into a tiny review cycle. If it violates your constraints, tell it:
“You failed check #2 and #4. Try again, explicitly fixing those.”
4. Time‑boxing & length‑boxing
Sometimes vagueness is because it’s trying to cover too much politely.
Try:
- “Spend 80 percent of the answer on implementation details, 20 percent on context.”
- “Maximum 2 sentences of theory, everything else is concrete steps.”
- “If you don’t know something, write ‘UNKNOWN’ instead of guessing.”
This is slightly different from “be specific.” You’re allocating budget to the parts you actually care about.
5. Use contradiction hunting
To squeeze out deeper thinking:
“First, answer my question as you normally would.
Second, write a short section ‘Where this could be wrong’ and attack your own answer: assumptions, missing constraints, alternatives.”
This is fantastic for project work where you’ll build on top of what Dippy Ai says. You get both the default response and a mini red‑team pass in one go.
6. When Dippy Ai forgets context, pin it
Long threads drift. Instead of repeating everything:
“Pinned context (do not ignore in this chat):
- Audience: junior devs
- Style: practical, numbered steps
- Scope: backend only, no UI
Acknowledge these 3 bullets, then answer my question.”
If you see drift later, say:
“You broke the pinned context: you added UI and theory. Redo, respecting the 3 bullets.”
This kind of scolding actually helps within a session.
7. Pros & cons of using Dippy Ai this way
- You can turn Dippy Ai into a decent “project co‑pilot” with:
- Pinned rules
- Self‑evaluation
- Short iterative loops
- Very fast to refine:
- You can go from vague essay to tight checklist in 2–3 rebakes.
- Great for:
- Architecture sketches
- Risk lists
- Turning messy notes into structured artifacts
- Requires some discipline:
- You have to think like you’re designing an API for your AI.
- Easy to overcomplicate prompts:
- If every message is a giant wall of instructions, you’ll confuse it again.
- Not a source of truth:
- Still need to validate anything critical, especially numbers and legal / medical stuff.
8. How this differs a bit from @viaggiatoresolare & @cacadordeestrelas
- They focus heavily on “be specific” and “persona + structure,” which is solid.
- I’d slightly disagree with always front‑loading everything in one monster prompt. In practice:
- Start lean,
- See how Dippy Ai fails,
- Add constraints only where it actually messed up.
You end up with a lighter workflow instead of 20 bullet rules that it half follows.
If you want a concrete tune‑up: drop one of your exact prompts plus 1–2 sentences of “what I wish this answer looked like,” and people can rewrite it so you can reuse that pattern across your Dippy Ai projects.
