I’m trying to move my Quack AI setup fully on-chain, but I’m stuck on how to handle data storage, smart contract logic, and gas costs without breaking the user experience. Can anyone explain the best practices, tools, or patterns for deploying and managing an AI-driven dApp like Quack AI directly on-chain, and what tradeoffs I should expect for performance, security, and cost?
You do not want Quack AI “fully on‑chain” in the strict sense. Full on‑chain AI is impractical today. You split it:
- Data storage
• Put only small, critical data on chain.
- Model hash, version, config.
- User balances, permissions, billing state.
• Store heavy stuff off chain. - Model weights in IPFS, Arweave, S3, or Filecoin.
- User prompts and outputs in off‑chain DB or decentralized storage.
• Use content addressing. - Store IPFS CIDs or Arweave TX IDs on chain.
- Verify off‑chain data by those hashes in your contracts or backend.
- Smart contract logic
• Keep contracts thin.
- Accounting, access control, pricing, staking, refunds.
- Emitting events for off‑chain workers.
• Off‑chain execution pattern: - User calls contract with a request and fee.
- Contract logs an event
InferenceRequested(id, cid, user, fee). - Off‑chain worker watches events, runs the model, writes result to IPFS / Arweave.
- Worker submits
submitResult(id, resultCid, proof)to the contract.
• For trust: - Use an allow‑listed set of oracles / workers with staked bonds.
- Slash workers on dispute.
- Optional: use multiple workers and require matching outputs. Too expensive for most usecases though.
- Gas cost and UX
• Never store raw prompts or outputs asstringin state.
- Use events or external storage.
- If you log text, compress client‑side (e.g. gzip) then store bytes.
• Use L2 for cheaper calls. - Optimism, Base, Arbitrum, Polygon PoS, zkSync, Linea, Scroll.
- Keep settlement or token on mainnet if needed, bridge for UX.
• Batch workflows. - Frontend creates a single tx for multiple actions when possible.
- Use meta‑tx / relayers so users pay in your token or in stablecoins.
- Tools that help
• Ethereum + L2: for contracts.
• Storage:
- IPFS plus a pinning service (Pinata, Web3.Storage).
- Arweave for “permanent” logs or model versions.
• Oracles and automation: - Chainlink Functions, Pyth, API3, or your own off‑chain indexer with a bot.
• Frameworks: - Hardhat or Foundry for contracts.
- TheGraph or custom indexer for querying events fast.
- Pattern for a single Quack AI request
Rough flow:
- User signs request off‑chain with prompt + settings.
- Frontend uploads prompt to IPFS, gets CID.
- Frontend calls
requestInference(modelVersion, cid, maxPrice)on L2. - Contract stores minimal state, emits
InferenceRequested. - Worker sees event, fetches data from IPFS, runs model, uploads result to IPFS.
- Worker calls
submitResult(id, resultCid)with a bond. - User or another watcher can dispute if output is invalid, using some rules or a reputation system.
- After dispute window, contract releases payment to worker.
- UX tips
• Hide chains and gas from users.
- Use a relayer so users sign messages and your backend pays gas.
- Charge them off‑chain with Stripe, crypto payments, or your own token.
• Cache outputs strongly off‑chain.
• Use session keys or account abstraction wallets so repeats feel instant.
- What to avoid
• Putting model weights or full chat history on chain. Gas is too high and not needed.
• Fat contracts that try to “run” AI or store JSON blobs.
• Requiring an on‑chain tx for every single token in a conversation. Think “session” per tx, not “message” per tx.
If you share details like chain choice, token plans, and how large your typical prompts/results are, people here can help design a more precise pattern.
You’re kinda trying to park a rocketship in a one‑car garage with “fully on‑chain AI.” It can be architected in a clean way, but not by forcing everything into Solidity.
@sognonotturno already nailed the high‑level split. I’ll avoid rehashing that and focus on patterns and tradeoffs you should actually decide on:
1. Decide what “on‑chain” really means for Quack
You should write this down explicitly or you’ll keep moving the goalposts:
Examples of reasonable definitions:
On‑chain verifiability
Anyone can verify:- what model version was used
- how much was paid
- who requested it
- what output hash was produced
On‑chain coordination + off‑chain compute
Contracts coordinate payments, rights, and reputation, but:- inference is off‑chain
- storage is off‑chain but content‑addressed
Unreasonable for 2026, imo:
- Model weights, full chat history, and every token on L1 “because decentralization.”
That’s just self‑harm with gas fees.
So, instead of “fully on‑chain,” think “fully accountable on‑chain.”
2. Storage: don’t just pick IPFS and call it a day
A few extra patterns that complement what @sognonotturno said:
Tiered storage strategy
- Hot data
- Last N messages, user session metadata, rate limits
- Store in a centralized DB or Redis with backups
- Warm data
- Full conversations & outputs
- Use IPFS or Arweave with CIDs/TX IDs referenced on chain only when needed
- Cold / versioned data
- Model versions, safety policies, system prompts, eval reports
- Arweave or Filecoin makes more sense here than shoving everything into contract storage
- Hot data
When you actually want text on chain
- For auditable system behavior like:
- “This safety policy text was active between block X and Y”
- In that case, use:
bytes+ gzip on the client side- store a hash in state and the compressed blob in an event
Privacy / compliance angle
If Quack is ever touching PII:- Do not log raw prompts in public events
- Either:
- encrypt them client‑side and store ciphertext off‑chain
- or separate “billing / proof” data from “prompt content” entirely
If you ever want consumer‑facing UX, you really don’t want someone’s venting session immortalized in a chain explorer.
3. Smart contract logic: avoid over‑engineering
I slightly disagree with the vibe that you always need a fancy dispute game up front. Most AI outputs are subjective and users just want “a useful answer,” not a court case.
Think in phases:
Phase 1: honest‑operator assumption
- Contract roles:
- tracks credits / balances
- emits “InferenceRequested” events
- records
outputHash+ metadata if you really need it
- Off‑chain:
- one or more trusted operators run the model
- You rely on:
- reputation
- off‑chain refunds if something goes wrong
- Contract roles:
Phase 2: soft crypto‑economic guarantees
- Add:
- worker staking
- simple “challenge window” that can slash only on obviously invalid behavior
- wrong format
- missing output
- provably different from what was signed / uploaded
- For actual model quality, you’re better off with:
- post‑hoc audits
- eval leaderboards
- open logs of misbehavior
- Add:
Phase 3: heavy trustless games (maybe never)
- Multi‑worker consensus
- ZK proofs of inference
- Spot‑check verification
Honestly, this is still research‑y and overkill for most products. You’ll ship nothing if you wait for perfect crypto‑economic purity.
So: keep contracts composable, but under‑specify at first. Leave room to bolt on more verification later.
4. Gas & UX: design around sessions, not calls
Where I think a lot of people shoot themselves in the foot is confusing “chat messages” with “transactions”:
Session abstraction
- 1 on‑chain session = many off‑chain messages
- Contract only needs:
openSession,closeSession, maybetopUpSession
- Within a session:
- prompts, partial outputs, tool calls happen entirely off chain
- End of session:
- store a single final summary hash, token count, and bill
Gas‑aware design patterns
- Put pricing logic on chain
- e.g.
pricePerToken,maxTokens,modelTier
- e.g.
- Keep metering off chain but auditable:
- off‑chain worker signs a receipt with token counts and output hash
- user / frontend verifies it matches what they saw
- then submits to contract for settlement
Latency
- Use L2 or app‑chains, sure, but also:
- Don’t block the UX on the chain:
- user submits request
- you optimistically stream the answer from your backend
- chain interaction is just for accounting / receipts
- If you try to wait for confirmation per request, your UX is toast
5. Tooling choices & some alternatives
Most folks default to “Ethereum + Hardhat + IPFS.” That’s fine, but you’ve got more interesting options:
Execution environment
- General purpose L2 (Base, OP, Arbitrum) for most cases
- If you expect lots of requests and minimal DeFi interactions:
- rollup‑as‑a‑service (Caldera, Conduit, etc.)
- or a modular stack (Celestia for DA, custom rollup for logic)
Tradeoff: more control vs less shared liquidity.
Indexing
- Instead of only TheGraph:
- consider a plain Postgres + custom indexer that tails your node’s logs
- Lets you implement:
- analytics on prompts / tokens
- usage‑based pricing
- abuse detection
TheGraph is nice but tends to constrain how you think about data.
Oracles / worker coordination
- Chainlink Functions is nice but overkill if:
- you basically just need a queue and a signer
- A very workable pattern:
- Simple contract emitting events
- A small off‑chain queue (e.g. Redis, SQS) that polls your L2 / indexer
- Workers pick jobs, do inference, post back with signed receipts
Use oracles only where you really need independent trust boundaries.
6. Concrete architecture sketch for Quack
Trying to map all this to something you can actually build:
On chain (L2)
QuackBilling- manages credits / deposits
- price tables per model / tier
QuackSessioncreateSession(modelId, maxSpend, optionalCid)- logs
SessionCreated(sessionId, user, modelId, ...) finalizeSession(sessionId, tokensUsed, outputHash, workerSig)
Off chain
- API server:
- handles auth (JWT, wallet, whatever)
- uploads prompts / convos to IPFS or your DB
- opens a session via relayer when needed
- Worker:
- listens to new sessions or HTTP requests
- runs the model
- streams output to user directly
- at the end, computes:
- token counts
- final transcript hash
- signs
(sessionId, tokensUsed, outputHash) - calls
finalizeSessionvia a funded worker wallet
- API server:
User
- Only signs messages (or does a single “approve & top‑up” tx occasionally)
- Sees:
- streaming answers
- “on‑chain verified” flag if the settlement succeeded
This way, the “on‑chain” part is:
- verifiable cost
- verifiable model version
- verifiable transcript hash
while the heavy UX and data stay off chain but still tied together cryptographically.
If you share rough numbers like:
- avg prompt length
- avg output length
- whether you plan human‑in‑the‑loop / tools / RAG
you can narrow this even further. Right now, I’d strongly push you toward “on‑chain receipts + off‑chain brains” rather than chasing the “fully on‑chain AI” buzzword and ending up with a super expensive toy.
You’re not blocked by tech so much as by where to draw the trust boundary. Since @sognonotturno already sketched patterns, I’ll zoom in on what you should concretely commit to for Quack AI and where I mildly disagree.
1. Stop aiming for “fully on‑chain,” specify 3 invariants
Instead of “everything on Ethereum,” define 3 things that must be cryptographically locked:
Billing invariant
- Given a session, anyone can recompute:
charged_amount = f(model_id, tokens, tier, time) - That means:
- Pricing tables and discount logic on chain
- Tokens used and final output hash referenced on chain (or a commitment to a transcript hash)
Model identity invariant
- For any answered request, you can prove:
- which model family
- which version / hash of weights or checkpoint
- This does not require weights on chain.
Store:keccak(model_manifest_blob)on chain- manifest blob itself on Arweave / Filecoin / S3 + hash pinning
Policy invariant
- At block N, you can prove the moderation / safety policy that should have applied.
- Here I disagree slightly with “store only a hash & event”:
If you want serious accountability, store:- policy hash in state
- compressed policy text as an event
Event logs are cheap enough on L2 for periodic updates.
Everything else is negotiable.
2. Data layout: think in objects not “history vs storage”
Rather than “hot / warm / cold” as abstract layers, define object types:
Session object
- Minimal on‑chain:
sessionIdusermodelIdmaxSpendfinalTokensUsedfinalTranscriptHash
- Full transcript:
- JSON stored off chain, e.g.
{'messages':[...],'tools':[...],'meta':{...}} - Use a stable canonical encoder so hash is reproducible
- Minimal on‑chain:
Model object
- Manifest example:
{ 'name': 'quack-v2-chat', 'version': '2.3.1', 'provider': 'Quack AI', 'weights_uri': 'ipfs://...', 'tokenizer_uri': 'ipfs://...', 'arch': 'llama-3-70b', 'evals_uri': 'ar://...', 'policy_hash': '0x...' } - You store the hash of this manifest on chain in a simple registry.
- Manifest example:
Policy object
- Same idea as model manifest
- Lets you later say: “user X was served under policy P at block B”
This object-oriented mental model prevents the “let’s just shove stuff into IPFS” trap and makes Quack AI auditable in a way that is understandable to non‑crypto people.
3. Execution pattern: lean into receipts, but add user verifiability
I agree with @sognonotturno on receipts, but I’d harden one part: the user should be able to detect cheating without trusting your backend.
Pattern:
Worker returns:
- output text
tokens_usedtranscript_hash(over full convo object)worker_signatureon(sessionId, tokens_used, transcript_hash, model_manifest_hash)
Frontend:
- Recomputes
transcript_hashlocally from the conversation it sees - Verifies signature against a known worker key from the contract
- Recomputes
Only then send a transaction to settle.
That small check means you cannot silently bill people for a different transcript than they actually saw, even if your API or DB is compromised.
4. Where to be more aggressive about on‑chain use
Some places I would be more on‑chain than suggested earlier, but still cheap:
Dispute metadata only, not a full game
Add adisputeSession(sessionId, reasonCode, evidenceCid)call:- Simple reason codes like:
- 1: non delivery
- 2: malformed output
- 3: policy violation
- Log an event and freeze settlement for that session
Human / DAO / centralized moderator can resolve later.
You get: - Public record of disputes
- Data for future slashing or worker scoring
Without needing a complex fraud proof architecture.
Simple worker score on chain
Track counters per worker:totalSessionsdisputedSessionsconfirmedSlashingEvents
Even if slashing is rare, this helps wallets / dapps choose which Quack AI worker to route to.
5. Gas & UX: you should pre‑commit to an L2 and batching strategy
Hand‑wavey “use an L2” is not enough for something chatty like Quack. You need a policy:
Pick an L2 and optimize around its quirks
- If you pick an optimistic rollup:
- design for cheap calldata, batching many
finalizeSessioncalls in one tx via a relayer
- If you pick a zk rollup with higher fixed costs:
- lean more heavily on off‑chain merkle trees of sessions, periodically anchored
Batch settlement pattern
- Off‑chain aggregator maintains:
- a merkle tree of
(sessionId, tokensUsed, transcriptHash, workerSig)leaves
- a merkle tree of
- Periodically submits:
- root + compressed list of sessions
- Contract:
- updates user balances based on the batch
- If someone later challenges a bogus leaf, you can expose the proof and worker signature.
This is slightly more complex than a naive per‑session finalize, but drastically better for gas when you have many micro sessions.
6. Privacy: treat “on‑chain AI logs” as toxic waste
I’ll push this harder than others: logging anything resembling user natural language into public infra will burn you later.
Concrete rules:
No prompts, no outputs, no partial tokens in:
- contract storage
- events
- analytics that aren’t access‑controlled
If you really need searchable logs:
- Encrypt payload client side
- Use per‑user keys so even a DB breach limits blast radius
If you add features like “public sharable Quack conversations”:
- Treat them as a separate object with explicit opt in
- Different policy, different buckets, different CIDs
This still keeps Quack AI “on‑chain accountable” without making it a GDPR landmine.
7. Where to start tomorrow morning
If you want to ship instead of architecture‑astronauting:
Implement:
QuackModelRegistry(manifest hashes)QuackBilling(credits, pricing, per‑session records)- Simple event
SessionFinalized
Off chain:
- API that:
- canonicalizes transcripts
- hashes them
- verifies worker signatures in the frontend
- DB or object store for transcripts & manifests
- API that:
Add later:
- dispute flow
- worker scores
- batch settlement
That gives you a pattern where Quack AI feels “fully on‑chain” to the user in the meaningful sense: cost, model, and policy are provable, yet the UX is still normal chat‑app smooth.
As for tooling, both you and @sognonotturno are circling similar tradeoffs. I’d just bias a bit more toward verifiable client logic and batching, and a bit less toward premature staking games, until you see real misbehavior patterns in the wild.
Try a streaming credit model.
- Use Sablier v2 or Superfluid. User opens a USDC stream to Quack at a tier rate, for example 0.0005 USDC per second.
- Frontend starts or pauses the stream on chat start and stop. Idle timeout 60s.
- Publish model and policy fingerprints in signed Git tags. Mirror the JSON to IPFS.
- Keep transcripts off chain. Post a daily CSV with sessionId, tokens, cost, hash. Pin to IPFS.
- Users compare CSV totals to stream debit. One setup tx, rare pauses, no per session txns. Cleaner UX, predictable gas.
The streaming model @waldgeist described breaks the moment usage stops matching time. Charging 0.0005 USDC per second assumes the cost tracks wall clock, but token spend is bursty. A user can sit on a paused stream while a long generation runs, or idle with the stream open and get billed for nothing. You end up reconciling the stream debit against the real token count anyway, which is the exact thing the daily CSV is trying to patch over. If your pricing is truly per token, a stream is the wrong meter.
Everyone here is converging on off-chain compute with on-chain receipts, and that’s correct. The piece I’d flag that hasn’t come up: worker signature key rotation. If a worker key gets compromised or you rotate it, every past receipt signed with the old key still needs to verify, so store key validity windows in the registry, not just a single current key. Miss that and your ‘provable model version’ story quietly falls apart the first time you rotate.
