Need help figuring out how to use the Threads app
I just installed the Threads app but I’m confused about how it really works compared to Instagram and Twitter. I’m not sure how to manage followers, privacy settings, and cross-posting to other platforms. Can someone explain the basics and share any tips to get started and avoid common mistakes?
Threads is sort of Instagram’s text side, with a bit of Twitter flavor. Here’s how to handle what you asked about.
  1. Followers and following
  • When you sign up, it pulls your Instagram account.
  • You get an option to “Follow all” your Insta follows. You can skip and pick people manually.
  • Anyone who follows you on Threads is separate from Instagram followers. They do not auto sync both ways after setup.
  • To see followers: Profile picture top right → Your profile → “Followers” or “Following”.
  • To mute / restrict / block: Tap the three dots on a user’s profile or on their post.
  1. Privacy settings
  • Threads is linked to your Instagram account. Your Threads profile uses the same account, but privacy is separate.
  • Go to: Profile → two lines in the top right → Privacy.
    Key things to check:
    • Private vs public profile
    • Private means only approved followers see your Threads.
    • Public means anyone can see posts, but only followers see them in their feed more often.
      • Mentions
    • Set who can mention you. Everyone, people you follow, or no one.
      • Replies
    • When you post, you pick who can reply:
      Everyone, people you follow, or only people you mention.
      • Hidden words
    • You can filter replies with blocked words. Same system as Instagram’s hidden words.
      • Blocking
    • Blocking on Threads also blocks on Instagram, since it is the same account.
  1. Posting and cross posting
  • To post: Tap the pencil icon. Write text. Add photos, videos, or GIFs if you want.
  • There is a toggle to “Post to Instagram” for some types of content, usually when you share a Thread to your story or feed.
    You have a few options:
    • Share a Thread to Instagram Story
    • Tap the share icon on your Thread → “Add to story”.
    • This sends a tappable sticker to Instagram Stories.
      • Share a Thread as an Instagram feed post
    • Use the share icon again and pick the feed option if available. Sometimes this rolls out in stages, so if you do not see it yet, check again later.
      • Share to Twitter / X or others
    • Same share button → “Copy link” or use your device’s share menu.
    • Paste into Twitter, Mastodon, etc.
  • There is no full auto cross post to Twitter / X. You have to share each one.
  1. Feed and algorithm stuff
  • There is a Following tab and a For You style tab.
  • Following shows accounts you follow, in time order or close to it.
  • For You mixes your follows with suggested accounts.
  • Threads likes short posts, fast replies, and conversations. Replies tend to surface posts more.
  1. Account and deletion warning
  • Threads is tied hard to Instagram.
  • Deleting Threads used to require deleting Instagram. Meta added a separate option:
    Go to Profile → Settings → Account → Deactivate or delete Threads.
    Check what it says on your version, since they change this a lot.
  1. Simple starter setup checklist
  • Set profile to private or public.
  • Check who can reply and mention you.
  • Turn on hidden words if you care about spam and insults.
  • Follow a small group first so your feed is not chaos.
  • Share one Thread to your Insta story so your Instagram people know you are on Threads.
If you say what you want it to feel like, more like Twitter or more like Insta, you can tweak settings to match that style.
Couple of extra angles on top of what @vrijheidsvogel already explained:
  1. How it feels vs Twitter & Insta
  • Think of Threads as “group chat energy in public.” It rewards quick back‑and‑forth, not carefully crafted bangers like X.
  • Visuals matter less than on Instagram, but posts with at least one image or short vid still get more interaction in practice.
  • If you try to use it exactly like Twitter, it’ll feel weird, because people are more chill and a bit more “Instagram-ish” in tone.
  1. Followers & discovery “gotchas”
  • Your follower count on Threads can grow from people who don’t care at all about your Instagram. Treat it like its own audience.
  • Reposting (quoting) and replying is how you actually get discovered. Just posting into the void and waiting is kinda useless.
  • Don’t obsess over who follows you back: Threads is still messy with discovery, so engagement > follower ratio.
  1. Privacy in a more practical sense
  • If you’re unsure, start public but lock replies down a bit. For example, let “people you follow” reply, then open it up later.
  • Private profiles on Threads can feel like shouting into a locked room. If your main worry is harassment, reply controls and hidden words help more than flipping full private.
  • One thing I slightly disagree with @vrijheidsvogel on: treating Threads privacy as totally “separate.” Technically it is, but socialy, people see it as an extension of your Instagram identity. If your Insta is very personal, maybe don’t overshare on Threads unless you’re ready for some crossover.
  1. Cross‑posting strategy (not just “how”)
  • Automatic full cross‑posting doesn’t exist for X, and honestly that’s a blessing. The vibe on Threads and X is different.
  • What I do:
    • Post the full thought on Threads.
    • Copy a shorter version to X or Bluesky, plus the Threads link if I really want.
    • Only share the “hits” back to Instagram stories so I don’t spam followers who don’t care about text content.
  • Threads stuff that does well often reads a bit more casual and less “performative” than on X. Don’t just mirror everything 1:1.
  1. How to test the waters without messing up your feed
  • Follow like 20–30 accounts max to start: some friends, a few news/tech/whatever you like, a couple of meme pages. Your feed will be way more readable.
  • Use mute aggressively instead of unfollowing if you like someone but hate their posting frequency.
  • Spend 10 minutes replying to posts in your niche. That shapes what the algo shows you far more than you’d think.
  1. Simple “first week” plan
  • Day 1:
    • Set privacy & reply rules.
    • Post a short intro thread.
  • Days 2–3:
    • Reply to 10–15 posts/day in topics you enjoy.
    • Share one good Thread to your Insta story.
  • Days 4–7:
    • Experiment: one text‑only post, one with an image, one mini‑rant, one question.
    • See which one actually gets people talking, then lean into that style.
If you say what you mainly want out of it (friends-only hangout, brand growth, or just Twitter escape), it’s easier to dial in the exact settings & posting style.
Quick analytical breakdown, building on what @viajantedoceu and @vrijheidsvogel already nailed, but from a slightly different angle.
1. Think in “personas” instead of features
Before touching settings, decide who you are on Threads:
  • Same person as on Instagram
    Use the same vibe and follow mostly the same people. In that case, let Threads auto follow from Insta during sign up, then prune.
  • More like your Twitter / X self
    Ignore the “Follow all” suggestion. Manually follow news, creators, brands, etc. This stops Threads from becoming “Instagram with extra text.”
  • Fresh identity / smaller circle
    Keep your account public, but follow a tiny set (15–30) and let the algorithm learn from what you interact with. This works better than going full private right away.
I slightly disagree with the “just follow everyone from Insta” approach. That often floods your feed with people who only post visual content and barely use Threads.
2. Practical follower management mindset
Instead of focusing on “who follows me,” think:
  • Who shapes my feed?
    • Follow = see them regularly.
    • Mute = keep the social connection, remove their posts from your headspace.
    • Restrict = they can talk, but they talk into a pillow.
      Use mute a lot. It is your main sanity tool.
  • Replies over follower count
    On Threads, replies to mid‑sized accounts in your niche are gold. One thoughtful reply can do more than posting 5 original threads nobody sees.
3. Privacy: what actually matters daily
You already got the menu paths from the others, so here is the “what to prioritize” view:
  1. Reply controls per post
    This is more important than global privacy. If a post is spicy or personal, limit replies to “Profiles you follow” or “Mentioned only.”
    That gives you public visibility without opening the door to every random account.
  2. Hidden words first, block later
    Turn on hidden words early and add a few custom terms. It is easier than cleaning up harassment after it starts.
  3. Public vs private in practice
    • Private: safer, but growth is slow and discovery is poor.
    • Public: better for discovering communities, but you need those reply controls set right.
      If you are unsure, start public, but lock replies for your first week.
4. Cross posting strategy, not just mechanics
You already know how to share. What usually works better:
  • Write for Threads first
    The culture is a bit looser and more conversational than X. Use that. Then shorten and sharpen for Twitter / X if you want.
  • Only send “highlights” back to Instagram
    Turning every Thread into an Instagram story can annoy people who do not care about text content. Maybe share 1 out of 5 posts to Insta.
  • Don’t expect auto sync
    There is no real automatic cross post to Twitter / X, and that is not a bug. The audiences and tone are different enough that copy‑pasting everything would feel off.
5. How to “train” your home feed fast
Day 1–2, spend 10–15 minutes doing just this:
  • Search topics or hashtags you like.
  • Open posts from accounts that feel “right.”
  • Like a few, reply to a couple, follow a handful.
The algorithm leans heavily on what you respond to in the first days. If you only follow your real‑life contacts from Instagram, it will keep showing you that world and not much of the broader conversation.
6. About “”: pros & cons in this context
You mentioned readability, so dropping a quick view on the product title ‘’ in the context of using Threads and other social apps:
  • The name itself is simple, which can work nicely if you are trying to keep your social media setup uncluttered.
  • Easy to remember and type, which helps when you are hopping between Threads, Instagram and Twitter / X.
  • Neutral branding that does not clash with the more visual, noisy feel of Meta products.
  • The title is so minimal that it can be hard to understand what it does at a glance.
  • In search results, it might get buried under more descriptive competitors, so you might need extra context around it.
  • Less distinctive compared with products that lean into stronger identities.
This type of straightforward naming can pair well with a platform like Threads, where short, clean explanations and quick links matter for readability and engagement.
7. Quick comparison to what others said
Where I differ slightly:
  • I would not recommend importing your entire Instagram social graph if you want a Twitter‑like experience. Start smaller and more curated.
  • I think reply controls + hidden words are more useful long term than going full private, unless you already know you only want a closed friend space.
If you say whether you care more about:
  1. staying in touch with friends,
  2. growing an audience, or
  3. just replacing Twitter,
    you can fine tune this even more.
