Need help choosing Mac data recovery software
I accidentally deleted important files from my Mac and emptied the Trash before realizing I still needed them. I’m looking for reliable Mac data recovery software that can recover lost documents and photos without making things worse. Which tools actually work and are safe to use?
Mac recovery apps, after way too much trial and error
I went through a pile of Mac recovery tools over the past couple years. If I had to name one pick for most people, I still land on Disk Drill.
Not because it wins at everything. It doesn’t. I kept coming back to it because the mix feels right. Recovery results were solid. The app was easy enough to use without feeling stripped down. And on newer Macs, it didn’t feel out of place or half-broken.
A lot of Mac recovery software falls into two bad buckets. One type is too shallow and misses stuff. The other feels like you need a weekend and a terminal guide to get anywhere. Disk Drill sits in the middle, which for normal use is where I wanted it.
What stood out to me
The app feels like it was built with macOS in mind instead of being shoved over from Windows.
From what I saw:
  1. It handles APFS well.
  2. It runs fine on Apple Silicon.
  3. It works with external SSDs, USB drives, SD cards, and Time Machine volumes.
  4. Previewing files before recovery is dependable enough to save time.
  5. It includes backup and disk image options, which helped when I dealt with a sketchy drive.
  6. It does well with photo and video recovery, including RAW formats from cameras.
I had one corrupted APFS volume where other apps either returned junk or stalled. Disk Drill pulled a usable set of files off it. Not everything, but enough where I stopped treating it like another shiny recovery app and started keeping it around.
Other tools I’d still keep on the list
Disk Drill isn’t the only one worth touching. The right tool changes with the mess you’re dealing with.
PhotoRec
Free, ugly, effective.
I used it on SD cards and on file systems in rough shape. It found more than I expected. The tradeoff is rough. You usually lose original filenames and folder structure, so cleanup after recovery turns into its own chore. The interface feels old and blunt, but if your priority is pulling data out at all costs, it’s still one of the better options.
iBoysoft Data Recovery
This one felt easier for beginners. APFS support was decent in my tests, and for common deletion or format mistakes it did fine. My only real gripe is the pricing model. The subscription setup gets old fast.
Data Rescue
Older tool, still usable.
I wouldn’t call it my first pick now, though I had decent luck with it on external drives and simpler recovery jobs. If the case isn’t too messy, it still has a place.
The part people mess up
The biggest mistake I keep seeing is continuing to use the same drive after files disappear.
Stop writing data to it. Right away.
On SSDs, TRIM changes the whole situation. Deleted data on modern Macs can vanish fast, and once it does, recovery gets bleak. I learned this the hard way on a work drive. Waited too long, kept using it, lost more than I should have. Dumb move.
What to do instead
If you’re trying to recover files, do this first:
  1. Install the recovery app on a different drive if you have one.
  2. Save recovered files to another drive, not back onto the same disk.
  3. If the drive looks unstable, clone it before running scan after scan.
  4. Skip random repair tools until after you recover what matters.
I’ve seen recoveries fail because people kept rebooting, copying stuff around, or trying every repair app they found in search results. At a certain point, the drive isn’t the only problem. The extra activity is.
My plain answer
If somebody asked me for one low-risk recommendation without wanting a deep technical lecture, I’d still point them to Disk Drill.
If you’re more experienced, or the damage is specific and ugly, one of the other tools might fit better. Still, for a broad Mac audience, it’s the one I had the least friction with and the most consistent results from.
If you emptied Trash on a Mac, speed matters more than the app list. Stop using the Mac first. Especially if your files were on the internal SSD. TRIM on modern Macs wipes deleted blocks fast, so waiting hurts your odds a lot.
I mostly agree with @mikeappsreviewer on Disk Drill. It’s one of the better Mac data recovery software picks for normal users, and the preview feature helps sort docs and photos before you pay or recover. Where I differ, a bit, is I would not spend too much time testing multiple apps on the same internal drive. Every extra install, scan, and reboot is more disk activity. That part gets people.
My short list:
  1. Disk Drill
    Best balance for Mac users. Good APFS support. Clean UI. Solid for deleted files, external drives, memory cards, and photo recovery.
  2. R-Studio
    Less friendly, more technical. Better if you need deeper control or RAID/network stuff. Overkill for most ppl.
  3. PhotoRec
    Free. Strong file carving. Messy results. You lose names and folders often, which is a pain for documents.
If the files matter a lot, recover to an external drive only. If Disk Drill finds your files and previews look ok, I’d start there. If it finds nothing on an internal SSD, the bad news is the data might already be gone.
Also, if you want a quick roundup, this video guide to the best Mac data recovery software is a decent place to compare options fast.
My vote, Disk Drill first. Fast scan, preview, recover to another drive. Don’t overthink it and dont keep using the Mac.
If the files were deleted from your Mac’s internal SSD, I’d be a little less optimistic than @mikeappsreviewer and @nachtschatten make it sound. Not because they’re wrong about Disk Drill being a solid pick, but because on newer Macs the real issue is often whether anything is still there to recover at all, not which app has the prettiest scan button.
That said, for actual Mac data recovery software, my shortlist would be:
  1. Disk Drill
    Best all-around option for most people. Good for deleted documents, photos, external drives, SD cards, and APFS volumes. The interface is way less annoying than a lot of competitors, which matters when you’re already stressed and panicking lol.
  2. R-Studio
    Stronger if you’re comfortable with more technical stuff. I don’t usually suggest it first unless the drive setup is weird or you need more control over scanning.
  3. PhotoRec
    Free and legit, but kinda chaotic. Great if you only care about salvaging file contents and don’t mind sorting through a mess after.
My slight disagreement: I would not chase “the best” app for hours. Pick one, scan once, and see if previews look real. If Disk Drill can preview the files, that’s a very good sign. If it can’t find anything on the internal SSD, trying six more apps usually just wastes time.
Also worth checking this Apple forum discussion on Mac file recovery after emptying Trash if you want another angle from Mac users.
Short version: Disk Drill for Mac is probably the safest first try. If the files are super important and not showing up, stop DIY-ing it before you make it worse. That part sucks, but it’s true.
One thing I’d add to what @nachtschatten, @caminantenocturno, and @mikeappsreviewer said: where the files were deleted from matters almost more than which app you choose.
If it was your Mac’s internal SSD, I’m a bit less optimistic than some people here. Not because Disk Drill is bad, but because macOS on SSDs can make recovery windows brutally short. If the files were on an external HDD, SD card, or even some external SSDs, your odds are usually better.
My take on Disk Drill:
  • very easy to use when you’re stressed
  • good at previewing photos/docs before recovery
  • handles APFS better than a lot of older Mac tools
  • decent balance between beginner-friendly and actually useful
  • not magic on TRIM-affected internal SSD deletions
  • paid recovery can feel pricey if this is a one-time accident
  • deep scans can return lots of clutter, so sorting takes time
I slightly disagree with the “just try app after app” mindset some people fall into. Usually that just burns time. Pick one serious tool first. For most Mac users, that’s Disk Drill. If it shows clean previews of your lost files, great. If not, I’d move to R-Studio only if you’re comfortable with a more technical interface. PhotoRec is still worth knowing about, but mostly when file names/folder structure are no longer your priority.
So my ranking would be:
  1. Disk Drill for normal users
  2. R-Studio for advanced cases
  3. PhotoRec if you just want raw recovery and can sort the mess later
If the files are business-critical or irreplaceable family photos and Disk Drill doesn’t find them quickly, I’d stop DIY there instead of grinding through five more apps. That’s the point where a recovery lab makes more sense than another download.
