Looking for an alternative to Ekahau for Wi-Fi planning
I’ve been using Ekahau for a while for Wi-Fi network planning, but it’s becoming too pricey for my budget. Can anyone recommend a reliable alternative with similar features, preferably something more affordable? Would really appreciate any advice or suggestions.
Hey everyone,
I’ve totally been there with Ekahau - it’s an amazing tool, but yeah, it can get super pricey. If you’re looking for an alternative, I highly recommend checking out NetSpot. It’s a solid choice for Wi-Fi planning and network analysis, and it’s much more affordable than Ekahau. I think you’ll find it just as reliable for most of your needs.
NetSpot offers a lot of similar features, including heat mapping, detailed network analysis, and even troubleshooting tips. Plus, it’s user-friendly, so you won’t miss out on the ease of use you’re used to with Ekahau. You can run comprehensive surveys and create detailed reports without breaking the bank.
For more details, you can visit their site here: NetSpot
Hope this helps! Cheers!
If Ekahau’s pricing is becoming a bit much, there are def. some other tools worth considering. Like, have you checked out NetSpot? Shizuka brought it up, and I gotta say, it’s quite reliable and way easier on the wallet than Ekahau. You get similar features like heat mapping and network analysis, and it’s pretty user-friendly too.
I think another good tool you might wanna look at is Wi-Fi Analyzer by Ubiquiti. It’s not exactly a clone of Ekahau, but it does provide pretty solid network diagnostics and planning tools. Plus, Ubiquiti is pretty well-known in the networking world, so you can expect quality support and frequent updates.
One more thing to think about is TamoGraph Site Survey. It’s a highly recommended alternative with similar features to Ekahau. While it might not have the same polish, it’s certainly up there in terms of capability.
In the end, it comes down to balancing your budget with the features you really need for your Wi-Fi planning. Maybe a mix of these tools could be the perfect solution. Hope you find what you need! Cheers!
