I just switched to a new Android phone and realized my voicemail isn’t set up correctly. When people call, they can’t leave messages, and I’m missing important calls for work and family. I tried looking through the phone app settings, but I’m not sure what I’m doing wrong or if my carrier settings are off. Can someone walk me through how to properly set up voicemail on Android so it works every time?
Had the same headache after switching phones. Voicemail is weird on Android because your carrier controls most of it, not the phone. Here is what usually fixes it.
Check your voicemail number
- Open Phone app
- Tap the three dots in top right
- Tap Settings
- Tap Voicemail
- Tap Advanced or Voicemail number
- If it is blank or wrong, enter your carrier voicemail number
• AT&T: press and hold 1 and note the number it dials
• Verizon: often *86
• T‑Mobile: often 123 or press and hold 1
• If unsure, google “[your carrier] voicemail number”
Set up voicemail from the dialer
- Open Phone
- Press and hold 1
- If it asks for a password, try last 4 of your phone number or 0000 or 1234
- Follow the voice prompts
• Create PIN
• Record name
• Record greeting - When it says setup is complete, hang up
Make sure missed calls go to voicemail
Sometimes call forwarding is off.- Open Phone
- Tap three dots → Settings
- Tap Calls or Calling accounts
- Tap your SIM or carrier
- Tap Call forwarding
- Check “Forward when unanswered” and “Forward when unreachable”
- Both should forward to your voicemail number from step 1
Fix visual voicemail (if your phone has it)
On Google/Pixel/Samsung etc:- Open Phone
- Tap Voicemail in the bottom bar or in Settings → Voicemail
- Turn Visual voicemail on
- Give it permissions if it asks
- If it keeps failing, uninstall updates on the Phone app or Visual Voicemail app, then update again through Play Store
Test with another phone
- Call your number from someone else’s phone
- Let it ring until it times out
- See if it goes to your greeting
- Leave a test message
- Check if it shows in your voicemail or visual voicemail
If nothing works, reset at carrier level
Call your carrier support and say:
“Voicemail is not accepting messages after a device change. Please reset or reprovision my voicemail and check conditional call forwarding.”
Ask them to:
• Reset voicemail box
• Reapply default forwarding codes
• Confirm no call forwarding to another number
Extra things to watch:
• Dual SIM devices sometimes tie voicemail to the wrong SIM. Check the right SIM is active in Phone → Settings → Calling accounts.
• If you use a work profile or company device, IT policy sometimes blocks visual voicemail. Regular voicemail by holding 1 should still work.
Once you get it working, call your own number and try option to change greeting so callers know they reached the right person.
One more angle on this that trips people up after a phone switch: the phone might be fine, but your line / voicemail profile on the carrier side is half-broken. @sternenwanderer covered the “do it from the phone” steps really well, so I’ll skip repeating those and hit the weird edge cases.
Confirm voicemail is actually enabled on your account
Carrier reps screw this up more often than they admit, especially after number transfers or plan changes.- Log into your carrier account (website or app).
- Look under “Features,” “Add‑ons,” or “Voicemail & calling.”
- Make sure “Voicemail” or “Visual voicemail” shows as active.
- If you don’t see it at all, that’s a red flag. You may need them to add it manually.
Test forwarding with GSM codes instead of just the menus
Sometimes the Android settings look correct but the network says otherwise. Use the dialer codes that talk directly to the carrier.- To see current conditional forwarding (unanswered, unreachable, busy):
- Dial:
*#004#and hit call. - It will show which number your calls are being forwarded to, or if it’s disabled.
- Dial:
- To make all the standard conditions forward to voicemail:
- Dial:
**004*voicemailnumber#and call.- Replace
voicemailnumberwith the correct one for your carrier, not your own number unless they say that’s how they do it.
- Replace
- Dial:
- To completely reset forwarding:
- Dial:
##004#and call, then set things up again.
- Dial:
Check if you accidentally turned on call forwarding to somewhere else
Even if “Forward when unanswered” looks right, “Always forward” might be hijacking your calls.- In the Phone app, go to Call forwarding and make sure Always forward is OFF or empty.
- Or just nuke it with:
##21#and call. That disables unconditional forwarding at the network level.
Watch out for Wi‑Fi calling / VoLTE quirks
Slight disagreement with the “just reset at carrier” approach being the last thing: I’d actually toggle these first, because they can be the entire issue.- Turn off Wi‑Fi calling in Settings.
- Turn VoLTE / 4G calling off, then on again.
- Reboot the phone.
- Test again by calling yourself from another phone and letting it time out.
Some carriers mess up voicemail routing when Wi‑Fi calling is half‑provisioned.
Dual SIM: there’s a sneaky setting most people miss
On dual SIM phones, even if you picked the right SIM for calls, voicemail might still be pointing to the other SIM.- In Phone app → Settings → SIMs or Calling accounts, make sure:
- Your “Preferred SIM for calls” is the same one that has voicemail.
- Each SIM has its own voicemail settings; check both.
- If you don’t use the second SIM at all, disable it for calls to reduce confusion.
Visual voicemail vs “old school” voicemail
Visual voicemail apps are flaky on some Android builds. If you care more about just not missing calls than about the fancy interface, try this:- Turn Visual voicemail OFF in the Phone app.
- Power the phone off, then back on.
- Hold 1 to dial voicemail and complete the entire setup using the audio prompts.
- Only after that, turn Visual voicemail back on if you still want it.
Sometimes the visual client fails because the “classic” mailbox was never finished.
Make sure DND / call blocking isn’t sabotaging you
Strange but real: callers can’t leave voicemail if the call is being instantly rejected instead of ringing out.- Turn off Do Not Disturb entirely while testing.
- Check any spam / call blocking apps (Hiya, Truecaller, carrier spam filter). Disable them temporarily.
- Call your number from another phone and don’t touch anything. Let it ring until it either goes to voicemail or ends.
If you call support, give them very specific checks
@sternenwanderer’s carrier script is good; I’d add this when you talk to them:- Ask them to:
- Confirm your line has an active voicemail box assigned.
- Tell you exactly what number your “no answer” and “unreachable” calls are forwarded to.
- Rebuild the voicemail profile if your number was recently ported in.
- Mention clearly: “People get a ring, but no option to leave a message” or “Calls never hit voicemail, just end.” They’ll know to look at conditional forwarding instead of just resetting your PIN.
- Ask them to:
After you try a couple of these, the simplest test is still: call your number from another phone, don’t answer, see what happens, leave a message, then try to retrieve it. If anything in that chain fails, note exactly where and hit your carrier with that info. It saves a ton of back and forth.
And yeah, you’re not crazy, voicemail on Android is way more “carrier thing” than “phone thing.”
