How To Make An Old IPhone Faster Without Resetting It Completely?
My old iPhone has become slow after recent app updates, with lag when opening apps, typing, and switching screens. I want to improve iPhone performance without erasing everything or doing a factory reset. What safe steps can I try to make it faster while keeping my data?
You can usually make an older iPhone feel a lot better without doing a full erase. The biggest wins are pretty boring: stop a few background/visual features from wasting resources, then free up enough storage so iOS has room to breathe.
Start with the battery
Check this before messing with anything else: Settings > Battery > Battery Health and Charging.
If the maximum capacity is under 80 percent, the phone may be slowing itself down to avoid random shutdowns. At that point, a battery replacement is going to help more than tweaking settings. If the battery is still in decent shape, then the slowdown is more likely coming from software settings or storage pressure.
Change the settings that actually matter
There are a few things worth turning off on older iPhones because they keep adding little bits of load all day:
  • Background App Refresh: Go to Settings > General > Background App Refresh and turn it off. Older chips do not need apps constantly refreshing in the background.
  • Reduce Motion: Settings > Accessibility > Motion > Reduce Motion. This swaps some of the heavier animations for simpler ones.
  • Reduce Transparency: Settings > Accessibility > Display and Text Size > Reduce Transparency. This cuts down on blur effects across iOS.
  • Low Power Mode: If you leave it on all the time, turn it off when you care more about speed than battery life. It intentionally limits performance to save power.
  • Safari cache: Settings > Safari > Clear History and Website Data. This mainly helps Safari and in-app browser views, but it is still worth doing.
Do not ignore storage
Storage is usually the part people check last, but it can make the phone feel awful. iOS needs free space for temporary files, indexing, and other background stuff. Once an older iPhone gets up around 85 to 90 percent full, you can start seeing weird lag: camera taking forever to open, apps crashing right away, stutter when switching apps, that kind of thing.
It creeps up slowly too, so it feels like the phone is just “old” when really the storage has been choking it for months.
The fastest place to recover space is usually Photos
Deleting things manually from a big photo library is a pain. Clever Cleaner makes that part easier, and it is free with no ads or subscription.
The useful flow is:
  1. Start with Heavies. It shows files from largest to smallest, with the exact size on each one. Old screen recordings and 4K videos are usually the real storage hogs. Deleting a few of those can free up more space than deleting hundreds of normal photos.
  2. Then check Similars. It groups photos that are almost the same and picks the sharpest one in each set. This is good for bursts, repeated shots, and all those “same photo but slightly different angle” situations.
  3. Look at Screenshots too. Screenshots pile up fast, and most of them are only useful for a day or two. The app shows the file size before you delete anything.
  4. Processing stays on the phone. Nothing gets uploaded to an outside server.
The order I would follow is simple: check battery health first, make the settings changes next, then clean up the photo library. After deleting photos or videos, open Photos and empty Recently Deleted, otherwise the storage number will not really change yet.
Doing only one of these helps a little. Doing all of them together is usually where the phone starts feeling noticeably closer to normal again, without wiping your data.
Reboot it first, then check whether the lag is everywhere or mostly inside a couple updated apps. If it started right after app updates, I would not jump straight to system-wide cleanup. Go to Settings > General > iPhone Storage, tap the worst offenders, and use Offload App for apps you can easily reinstall. That keeps documents and data but replaces the app itself, which can fix a bloated or glitchy install. I agree with checking storage and battery, but be careful with “cleaner” apps or random cache tricks as the main fix. On iOS, the safer boring move is offload/reinstall problem apps, delete big message attachments, restart, then give the phone a day plugged in on Wi-Fi so indexing and photo processing can settle down.
Don’t start with “Reset All Settings” or some cleaner that claims it will fix iOS system junk, because that can create more annoyance than speed. I’d do the low-risk stuff first: update iOS if your model still supports it, remove widgets you never look at, turn off notifications for noisy apps, and delete any third-party keyboards you do not need, since typing lag can sometimes come from those. I agree with @stellacadente that app-specific lag matters. If only Instagram, Facebook, Maps, etc. feel awful, treat those apps as the problem instead of blaming the whole phone. And after freeing storage, restart once and leave it alone for a bit. Older iPhones often feel worse right after a big cleanup or update because Photos, Spotlight, and iCloud are busy in the background.
Be careful deleting photos if iCloud Photos is turned on, because deleting them from the iPhone can delete them from iCloud and your other Apple devices too. A lot of people think they are “clearing local space,” then later realize they deleted the actual library. Before doing any big photo cleanup, check Settings > your name > iCloud > Photos and see whether iCloud Photos is enabled.
The safer move, if you use iCloud Photos, is to turn on Optimize iPhone Storage. That keeps smaller local versions on the phone and leaves the full-size originals in iCloud. It will not make a 32 GB phone feel brand new, but it can help if the phone is choking because every video is stored locally. If you do use a photo cleanup app like Clever Cleaner or anything similar, treat it as a sorting tool, not a magic speed button. Review before deleting, then empty Recently Deleted only after you are sure.
I agree with @stellacadente on offloading problem apps. That is usually cleaner than nuking settings. But check “Documents & Data” too. Some apps are ridiculous about cache. Social apps, podcast apps, streaming apps with downloads, and chat apps can quietly sit on several gigs. Offload keeps your data, while Delete App removes the app and its local data, so do not mix those up. For apps where everything is cloud-based, deleting and reinstalling can be fine. For apps with local projects, downloads, or drafts, be more careful.
Another boring thing that actually matters: heat. An older iPhone that is warm will feel much slower because iOS will pull performance back to protect the hardware. If it lags worst while charging, in a thick case, in the car, or during video calls, settings tweaks are not going to fix all of that. Take the case off for a bit, stop charging while testing, close the camera/navigation/video app, and see if it behaves differently after cooling down.
My order would be: make sure you have a backup, check iCloud Photos before deleting anything, offload or reinstall only the apps that are acting up, remove large local downloads and message attachments, then restart. Leave “Reset All Settings” as a last resort before a full erase. It is not a factory reset, but it can still make you redo Wi-Fi, privacy prompts, Apple Pay bits, keyboard settings, notification preferences, and other annoying stuff.
If the slowdown really kicked in right after updating apps, the thing nobody’s saying out loud is that new app versions often drop support for older iOS or just assume a faster chip. Check what iOS you’re stuck on. If your model can’t go past a certain version, some apps will keep updating past what your phone handles well, and no amount of cache clearing fixes that. In that case the fix is the opposite of updating: grab the older compatible version if you can, or just accept those specific apps will lag.
I’m with @jeff on the iCloud Photos warning, that trips people up constantly. Clever Cleaner is fine as a sorting pass for the big videos, but if Optimize Storage is already on, half your ‘space hogs’ are thumbnails and you’re not reclaiming as much as the numbers suggest. Worth checking that toggle before you spend an evening deleting stuff.
Honestly though, on a genuinely old phone, battery health is the whole ballgame. Everything else is shaving seconds.
