I want to learn AI skills, but I’m feeling overwhelmed by all the courses, tools, and advice online. I recently tried to get started on my own and quickly realized I don’t know which beginner path is actually worth my time. I need help finding the best way to learn artificial intelligence, build real skills, and avoid wasting time on the wrong resources.
Pick one lane for 6 weeks. Do not try to learn “AI” all at once. Ths is where most people burn out.
Best beginner path, in order:
Learn Python basics.
Use 1 course. FreeCodeCamp or Kaggle Python.
Goal: variables, loops, functions, lists, pandas. -
Learn basic math for ML.
You need stats, probability, linear algebra at a simple level.
Focus on mean, variance, gradients, vectors, matrices.
3Blue1Brown helps a lot. -
Do classic machine learning first.
Use scikit-learn.
Learn regression, classification, train/test split, overfitting, cross-validation.
Build 3 tiny projects.
Example: spam detection, house price prediction, customer churn. -
Learn one deep learning tool.
Pick PyTorch.
Do tensors, neural nets, training loops.
Do not switch between TensorFlow, JAX, and 8 other tools. -
Learn how LLM apps work.
Prompting is not enough.
Learn embeddings, vector search, RAG, evals, fine-tuning at a basic level.
A simple weekly plan:
Week 1 to 2: Python
Week 3: math
Week 4 to 5: scikit-learn
Week 6: PyTorch intro
Rule: spend 70 percent building, 30 percent watching videos. If you watch 10 hours and build 0 projects, you learned less then you think.
Also, ignore “AI roadmaps” with 40 boxes. Most are content bait. You need one path, one tool per stage, and reps.
Biggest thing: stop asking “how do I learn AI?” and start asking “what do I want to do with it?”
That’s where I slightly disagree with @cazadordeestrellas. A strict 6-week lane is useful, sure, but for some people it feels weirdly abstract and they quit because they can’t see why they’re learning loops, matrices, or train/test splits in the first place. If you anchor it to a use case, it sticks better.
Pick one outcome:
- analyze data
- build prediction models
- make chatbots/tools with APIs
- automate work stuff
- do research-y ML
Then reverse engineer the skills from there.
If your goal is practical job-value fast, I’d honestly start with AI applications before hardcore theory. Not just “prompting,” but using APIs, structured outputs, basic evals, and simple automations. You can learn Python alongside that. Seeing something actually work is way more motivating than grinding math videos while wondering what any of it is for.
My rough advice:
- Choose one project you care about.
- Learn only the concepts needed to finish it.
- Keep a notes repo of every thing you break and fix.
- Ignore daily tool hype. Most of it is noise.
- After one finished project, then decide whether to go deeper into ML or LLM engineering.
Also, courses are overrated if you never ship anything. A messy finished project beats 20 half-watched tutorials. Ask yourself each week: “What can I demo?” If the answer is “I watched 14 hours of content,” ehh, that’s not much.
You do not need the perfect roadmap. You need traction. Thats the part people miss.
