How To Compress Photos On IPhone For More Storage Space?
My iPhone storage is almost full, and photos are taking up most of the space. What’s the best way to compress photos on an iPhone without noticeably reducing image quality?
The best method depends on what you're trying to accomplish.
For a smaller file that you can email, upload, or send in a messaging app, the built-in iPhone tools are usually enough. You don't need another app for a couple of photos.
  1. In Photos, select the image and tap Share.
  2. Choose Save to Files, pick a location, and tap Save.
  3. Open Files and find the saved image.
  4. Touch and hold it, then select Quick Actions > Convert Image.
  5. Choose JPEG and pick Small, Medium, or Large.
That creates a separate, smaller copy you can share while leaving the original alone.
Freeing up storage is a different problem. Converting photos individually gets old fast if your library has thousands of images. For that, something like Clever Cleaner is more practical. It can compress photos in batches and help find duplicate or similar pictures, large videos, old screenshots, and Live Photos you don't need. I recovered a surprising amount of space this way without manually sorting through my entire library.
Basically, use Files > Convert Image when you only need a smaller file for sharing. If the real goal is reclaiming iPhone storage, a dedicated cleaner or compression app makes more sense.
Don’t batch-compress your library and delete the originals until you’ve checked that everything is backed up and the compressed copies still include the quality and metadata you want.
For storage, I’d try Apple’s “Optimize iPhone Storage” setting before recompressing anything. With iCloud Photos enabled, the full-resolution files stay in iCloud while smaller versions remain on the phone, and originals download when needed. The catch is that you need enough iCloud storage, and accessing originals may require an internet connection.
@omegaexplorerhq’s Files method is fine for occasional sharing, but it creates another copy, so it can temporarily use more space rather than less. For a large library, start by removing big videos, duplicate shots, screenshots, and unwanted Live Photos. Clever Cleaner may speed up that sorting, but review its selections carefully instead of approving a mass deletion.
A library already shot in HEIF is different from one full of older JPEGs: recompressing HEIF photos may save less space than expected while adding visible artifacts. I’d keep Optimize iPhone Storage as @falcon6612 suggested, then set Camera > Formats > High Efficiency for future shots. That won’t shrink existing files, but it prevents the problem from growing. For immediate space, videos and Live Photos usually deserve attention before ordinary photos.
Photos are rarely the real culprit. Nine times out of ten it’s video, and a single 4K clip can outweigh hundreds of stills. So before anyone starts recompressing their photo library, open Settings > General > iPhone Storage and actually look at the breakdown. If videos are eating the space, compressing JPEGs is wasted effort.
@vibergirl is right about the HEIF thing, and it’s the point most people skip. If your recent photos are already High Efficiency, running them through another compressor gives you tiny savings and a worse-looking image. You’d be trading quality for almost nothing. Old JPEG-heavy libraries are where compression actually pays off, so it really depends what era your camera roll comes from.
Where I’d push back a little is on leaning too hard on Optimize iPhone Storage. It works, but it’s not free storage, it just shifts the burden to iCloud. The moment your iCloud fills up, the whole thing stalls and you’re back to square one, now paying monthly. Fine if you already pay for iCloud, annoying if you were hoping to avoid it.
For the sorting part, something like Clever Cleaner is reasonable as a way to surface the big videos, duplicates, and old screenshots quickly, but treat it as a shortlist tool, not an auto-delete button. Same warning @falcon6612 gave. Let it find the candidates, then you decide.
My honest take: skip photo compression entirely until you’ve cleared the videos and duplicates. Delete a few large clips or move them off the phone and you’ll usually free more space in five minutes than a full library recompress would ever get you.
