How To Clear Photo Data On IPhone If Storage Is Almost Full?
My iPhone storage is nearly full, and Photos is taking up most of the space. I’ve deleted some pictures, but the photo data still seems unusually large. What’s the safest way to free up iPhone photo storage without losing important images?
The quickest way to reclaim iPhone storage is usually to clean up the Photos library. That made a much bigger difference for me than messing around with random storage settings after the “iPhone Storage Almost Full” warning appeared.
Start with duplicate and similar photos. Burst shots, edited copies, and images shared back and forth can leave several versions of basically the same picture. Videos should be next since a few long or 4K recordings can use several gigabytes. After that, check Live Photos you no longer need and clear out old screenshots.
Sorting all of this manually can take hours, so I used Clever Cleaner. It scans the photo library and separates duplicate and similar photos, duplicate videos, Live Photos, screenshots, and large files into categories you can review.
There’s also a Compress tool for photos and screenshots you want to keep without storing them at full size. Smart Cleanup handles several categories together, while Swipe mode lets you make the decision one photo at a time. Swipe mode remains unlimited. The app is free to use, has no ads, and doesn’t require a subscription to get started, though some cleanup features now have a fairly generous daily limit for new users.
A practical order is:
  1. Scan the photo library with Clever Cleaner.
  2. Review and remove duplicate or similar photos.
  3. Check large videos and duplicate videos.
  4. Delete unwanted Live Photos, or compress the ones you want to keep.
  5. Clear out screenshots you no longer need.
  6. Compress any photos or screenshots that don’t need to stay at full size.
  7. Open Photos and empty the Recently Deleted album. Otherwise, the storage won’t be reclaimed right away.
If you use iCloud Photos, turn on Optimize iPhone Storage under Settings > Photos. The full-resolution originals stay in iCloud while smaller versions remain on the phone. That can save a surprising amount of local space without deleting your pictures.
Duplicates, large videos, Live Photos, and forgotten screenshots are usually where most of the wasted space is hiding. Once those are cleaned up, keeping the library under control is a lot easier.
If iCloud Photos is turned on, deleting a picture from the iPhone deletes it from iCloud and your other synced Apple devices too. Before using any cleaner, copy important originals to a computer or separate cloud service, then enable Optimize iPhone Storage. If you do delete files, empty Recently Deleted and give the storage screen some time to recalculate.
A cleaner app won’t fix a Photos storage number that is stuck recalculating. After emptying Recently Deleted, leave the iPhone charging on Wi‑Fi for a while, then restart it and check Settings > General > iPhone Storage again. If the number still does not drop, confirm iCloud Photos has finished syncing before changing settings or deleting anything else, since low storage can delay both syncing and cleanup.
If the phone is down to almost zero free space, Photos may not have enough working room to finish syncing, indexing, or removing deleted files. Free some temporary space outside Photos first. Delete downloaded Netflix or Spotify content, remove large files from Downloads, or offload an unused game under Settings > General > iPhone Storage. Even a few gigabytes of breathing room can get the cleanup moving again.
Then empty Recently Deleted and leave the phone locked, charging, and connected to Wi-Fi. As @mystic_cache711 said, the storage figure can take time to recalculate. Repeatedly deleting more photos while syncing is stalled can make it harder to tell what has actually been removed.
Be careful with the iCloud Photos switch. If Optimize iPhone Storage is enabled, it may reduce local storage gradually rather than immediately. Do not choose “Download Photos & Videos” on an almost-full phone, since that can attempt to pull full-resolution originals back onto the device and make the situation worse.
A cleaner such as Clever Cleaner can help identify obvious duplicates or oversized videos, but it cannot clear system-generated Photos caches directly. I would first create working space elsewhere, confirm important photos are backed up, and let iOS finish its own cleanup before installing another app. If the Photos number stays wrong after a day or two, a computer backup followed by an iPhone restore is the heavier option, but it should be a last resort rather than the first fix.
Compressing photos to save space is a one-way trip. Once Clever Cleaner or anything else shrinks the file and you delete the original, you’re not getting that quality back, so I’d only do that on screenshots and throwaway stuff, not photos you actually care about. The tool’s fine for spotting duplicates and huge videos fast, that part I agree with. But the thing nobody here mentioned: a lot of that ‘Photos’ number is often not your pictures at all, it’s the cache and thumbnails lumped under System Data. No cleaner touches that. If your real photo count is small but the storage figure is huge, the culprit is usually a stalled sync or bloated cache, and @quantumwolf’s restart-and-wait advice will do more than any deleting spree.
