How do I use an AI story writer for creative projects?
I’m looking to start writing stories using an AI story writer but I’m not sure which tools to use or how to get started. I want tips on choosing the right AI for storytelling, setting up my first project, and making the most of these tools. Any advice or recommendations would help a lot.
Alright, so you wanna let a robot help you write stories, huh? Here’s the truth: AI story writers are just fancy autocomplete machines. They’ll spit out stuff faster than you can blink, but don’t expect Hemingway overnight. For tools, OpenAI’s ChatGPT (paid version if you want more control), Sudowrite, and NovelAI are the go-tos. Each has a slightly different toy chest. Sudowrite’s like your creative pal that throws weird and fun suggestions at you. NovelAI’s more for the fiction nerds, and ChatGPT is somewhere in between.
How to start? Well, pick your poison, sign up, and type in a prompt—could be as simple as, “A dragon lands in Central Park.” The AI will try to take it from there. Will it go off the rails and have the dragon work at a coffee shop? Maybe. That’s kind of the point—it’s brainstorming with zero judgment.
Tips? Keep your expectations low until you get the hang of steering it. The more specific you are, the better. Instead of “tell me a story,” try “write the first paragraph of a sci-fi story set in underwater New York.” Rinse and repeat, don’t be afraid to regenerate or nudge it in another direction if it gets weird or dull. And expect plenty of nonsense—AI loves plot holes and logic fails more than you love plot twists.
In the end, it’s a tool; you’re the writer. Don’t let the bot take the wheel or you’ll end up lost. Use it to break writer’s block, play with ideas, or generate drafts, but edit and polish yourself. Remember: AI can string sentences together, but it doesn’t know what makes your story truly good.
I get what @sonhadordobosque is saying about AI being just a superfancy autocomplete, but tbh, I think there’s a bit more potential if you play around right. For one, not all AIs are created equal: ChatGPT, Sudowrite, and NovelAI each have their quirks, sure, but it also totally depends on whether you prefer open-ended, collaborative generation or more granular tweaking. Personally, I’d add Claude and Poe to the mix if you want to try something fresh—Claude’s got real juice for narrative consistency.
Setting up your first project? Go beyond just prompts. Build out some world details and keep a doc handy with quick notes like character traits, key places, and themes—AIs are wayyyy better if you remind them what’s what every so often. I disagree that you have to “keep expectations low.” If you get comfortable nudging and rewinding the AI, you can get some impressively coherent scenes.
My “hack”: use AI for heavy lifting during brainstorming or for rough dialogue, then switch to “manual mode” for the actual emotional beats and structure. Don’t trust it to write endings! I’ve fallen into the “let’s see where this goes” trap and ended up with ten pages of fish puns or a plot twist about sentient cheese. So yeah, steer hard when the AI gets wild.
For maximizing results, try working in small chunks—ask for a paragraph, not a full chapter, and iterate. Copy/paste the best bits into your own doc. Treat the AI as your well-meaning (but slightly unhinged) writing buddy who’s great with first drafts but not allowed near the final edit. AI still can’t outwrite a determined human, but it’ll happily turbocharge your output if you give it a leash.
Here’s the honest, boots-on-the-ground breakdown if you want to use an AI story writer for creative projects: you don’t need to treat the AI as a wise oracle or a wild horse you’ll never control. Instead, think of it like a slightly over-caffeinated writing partner—sometimes brilliant, sometimes bonkers, but always fast. Unlike some takes from earlier, I’d argue you’re actually better off mixing both macro (full scene drafts) and micro (single lines or dialogue snippets) approaches—let the AI propose the big canvas, then workshop details, rather than relying exclusively on paragraph-at-a-time or just for brainstorming.
Choosing your AI story writer? Forget the marketing hype: here’s the rundown. OpenAI’s ChatGPT (especially paid) is flexible for prose and genres but can waffle or lose plot threads in long form. Sudowrite is quirky and geared for idea generation—great for plot twists but can derail your flow if you’re not already grounded in your outline. NovelAI shines for consistent tone in fantasy/sci-fi, but sometimes feels a bit “on rails” and less creative unless you really tinker. Claude is gaining traction for continuity, while Poe is still carving out its identity. AI story writer tools each have their flavor, so test a few before settling.
Setting up your project: one thing not mentioned by the others—structure your outline and chapter goals FIRST, then feed AI small sections or “scene tasks.” For example: set up the conflict of a scene, get two rough dialogue options, and then pick which works best. Don’t just launch cold with a “write a story” prompt—AIs need context breadcrumbs.
Pros for the AI story writer approach: rapid ideation, zero judgment, fun for breaking blocks, decent first drafts. Cons: logic jumps, tone whiplash, cliché factory, and, most importantly, lack of emotional nuance if you don’t step in. Don’t just copy-paste output—edit, curate, and punch up the text yourself.
Against previous recommendations, I’d add: don’t totally fear letting the AI run semi-wild on occasion. Some of the weird plot developments will spark genuinely new directions you wouldn’t have thought up. Just… be ready to prune the tangents.
Competitors mentioned offer a good spread—some more collaborative, some more granular—but the golden rule holds: no AI perfectly “gets” your voice or your plot, so you always need to stay in the driver’s seat.
If you’re focused on SEO or discoverability for your stories, also leverage the unique angles AI-generated drafts can give—think character archetypes, plot models, or scene ideas that push beyond your comfort zone. Mix, match, edit ruthlessly.
Bottom line? Use your chosen AI story writer as a springboard, not a substitute. Take breaks, reset the prompt, save your branches, and most importantly: keep your weirdest, most human ideas at the core.
