How do I switch my Wyze camera to a new WiFi network?
I recently changed my home WiFi network and now my Wyze camera won’t connect. I’m not sure how to update the WiFi settings on the camera. Can someone guide me through the steps to switch it to the new network?
Changing your Wyze camera to a new WiFi network is pretty straightforward, but you gotta reset it like how you initially set it up. Here are some steps to do it:
  1. Open the Wyze App: Make sure you’re logged into your Wyze account.
  2. Reset the Camera: This is kinda the main step. For most Wyze Cameras, you need to press and hold the setup button until you hear “Ready to connect.” The setup button can usually be found at the bottom or the side of the camera.
  3. Set Up as New: Use the ‘Add a Product’ (+) icon on the app, scan the QR code using the camera, and follow the prompts. When it asks for WiFi details, make sure to enter the new network’s SSID and password.
  4. Complete the Setup Process: Follow through the prompts and the camera should be back online with the new WiFi network!
If your WiFi network range isn’t great and your camera struggles to stay connected sometimes, you might want to consider using a WiFi analyzer. NetSpot
Site Survey Software comes in handy here. It helps you check WiFi signal strength and coverage so you can place your camera where it gets the best signal. Pros: It’s user-friendly, and gives comprehensive data on WiFi performance. Cons: The free version has limited features. Other options like WiFi Analyzer and inSSIDer are available too, but they might not offer the same depth of data.
Hope this helps. Don’t forget to take a note of your WiFi settings somewhere safe in case you need them in the future.
Hey there, if you’ve already tried the steps mentioned by @techchizkid, another thing you might consider is updating the firmware of your Wyze Cam before resetting it. Sometimes, newer firmware versions have enhanced abilities to deal with different WiFi networks, which can save you a lot of hassle. Here’s how you can do it:
  1. Make Sure Camera Is On: If it’s already powered up, open the Wyze app and go to the camera’s settings.
  2. Check Firmware Update: Navigate to Device Info and click on the “Firmware Version”. If there’s an update available, the app will prompt you to download it. Just make sure you’re on the same network as before while you’re doing this, otherwise, it might not work.
After updating the firmware:
  1. Switch Back to the New Network: Go through the setup process like @techchizkid mentioned. This time around, it might be smoother post-firmware update.
One point where I slightly disagree with @techchizkid is skipping the firmware update when resetting and re-adding the camera. This could sometimes solve connectivity issues right away without needing to completely reset the camera.
Lastly, for those struggling with weak WiFi signals, using a WiFi analyzer tool is excellent advice. NetSpot Site Survey Software can be incredibly useful for this task. It provides a comprehensive view of your home’s WiFi coverage so you can place your Wyze Cam in the most optimal spot.
For those interested, here’s the URL for more details: ‘https://www.netspotapp.com’. The site offers a lot of insight into how to troubleshoot and improve WiFi performance, so it’s worth checking out.
One more thing to keep in mind: if you’re using a dual-band router, ensure your Wyze Cam is connecting to the 2.4 GHz band instead of the 5 GHz one, as the camera only supports the former. Sometimes, the camera might pick the wrong band automatically, leading to connectivity failures.
Good luck, and hope this helps! It’s always a bit of a pain when changing networks, but once you’ve got it, the process tends to be a lot easier in the future.
You don’t need to reset the Wyze camera if you can update the WiFi settings within the app without a full factory reset. Here’s an alternative method to try:
  1. Open the Wyze App: Launch the Wyze app and make sure you’re logged into your account.
  2. Access Camera Settings: Tap on the camera that’s having the WiFi trouble to open its live stream, then tap the gear icon in the top right corner to access settings.
  3. Change WiFi Network: Look for the network settings option. You might see an option to change or update WiFi directly. If available, enter the new network’s SSID and password here.
If that doesn’t work or isn’t available, then yeah, doing a reset as mentioned by others is your next move.
Also, WiFi Extenders can sometimes mess up the connection if your new network name (SSID) is too similar to the old one. Try renaming your network to something unique and see if that helps the camera to detect it properly.
As for the other advice, updating the firmware before resetting is solid. Always a good habit to make sure your devices are running the latest software, especially if you’ve been having connection probs. Any device doing better after an update has saved a ton of headaches.
Regarding the WiFi analyzer, @techchizkid and @byteguru were spot on. NetSpot Site Survey Software is pretty handy. You could even try them out on a laptop around the areas you intend to place the camera. It’ll give a detailed view of the WiFi signal strength and might identify any dead zones or interference that could be screwing up your camera’s connection.
To know more about the tool, check out https://www.netspotapp.com. It’s straightforward to use and can provide a map of where your WiFi is strongest and weakest, making it easier to figure out optimal positioning for your camera.
Another quick note, which is often overlooked: if you’re using a mesh WiFi system, sometimes devices might get confused with all the nodes, leading to connectivity issues. If that’s your setup, ensure that your device is connecting to the correct node within optimal range.
One thing to keep in mind though—sometimes routers have “band steering” enabled, which auto-switches devices between 2.4 GHz and 5 GHz. Since Wyze cameras only support 2.4 GHz, turning that feature off temporarily while setting up might prevent any hiccups in connection.
Hope that adds some more options for ya! Network changes always seem to find new ways to be complicated, but once you’ve got everything set up right, it usually stays rock solid.
