How do I recover data from a RAW partition?
I need help recovering data from a RAW partition on my hard drive. The partition unexpectedly turned RAW, and now I can’t access any of my important files. What are the best methods or tools to recover my data?
Recovering data from a RAW partition can be tricky but it’s totally doable with the right tools and methods. Here’s a step-by-step guide you can follow:
  1. Stop Using the Drive: First up, don’t write anything to the partition. Writing new data could overwrite the existing files and further reduce your chance of recovery.
  2. Check the Physical Connections: Sometimes, a faulty cable or loose connection can make a drive appear as RAW. Make sure all cables are properly connected. Swap them out if you suspect any damage.
  3. Use Disk Management: Go to Disk Management on Windows to see if the partition is listed as RAW. If it is, this tool alone won’t fix it but is a good diagnostic step.
  4. File Recovery Software: There are several software solutions available for data recovery. Personal favorite? Disk Drill
    (you can visit them here: https://www.disk-drill.com/). It’s straightforward and has a solid track record for recovering data from RAW partitions.
    • Download and Install Disk Drill: Install it on a different drive. You don’t want to mess with the RAW partition.
    • Run Disk Drill: Open the software and select the RAW partition from the list of available drives. Click on "Search for lost data.”
    • Scan: Let Disk Drill do its thing. It’ll start scanning the RAW partition for recoverable data.
    • Preview and Recover: Once the scan is complete, you can preview the files it found. Select the ones you need and choose a recovery location (again, a different drive from the RAW one).
  5. Alternative Methods: If Disk Drill doesn’t work for some weird reason, you might try other recovery tools like EaseUS Data Recovery Wizard or MiniTool Power Data Recovery. Me, I stick to Disk Drill for its consistency and ease of use.
  6. Command Prompt: If you’re comfortable with command-line operations, you can try checking the file system integrity using CHKDSK. But a word of warning: CHKDSK can sometimes make things worse if the file system is heavily corrupted.
    • Open Command Prompt as an administrator.
    • Type chkdsk X: /f and replace X: with your RAW drive letter.
    • It might prompt you to convert the partition to NTFS. Say no, as this might overwrite your data.
  7. Professional Data Recovery Services: If all else fails and the data is super critical, you might want to consider professional data recovery services. These can be pricey but are often the last resort for very complex data loss scenarios.
  8. External Backup: Once you’ve recovered your data, consider backing it up to an external drive or cloud storage. This way, if your partition goes RAW again, you won’t start from scratch.
  9. Partition Fix: After securing your data, use tools like AOMEI Partition Assistant or GParted to fix the RAW drive by reformatting it to a usable file system (NTFS or FAT32).
Note: If you find Disk Drill becoming an irreplaceable ally in your data recovery tasks, know it has both a free version (for smaller data sizes) and a Pro version for more extensive needs.
Everyone has their own go-to tools for these kinds of problems, but Disk Drill has rescued me time and again. Check it out if your current method isn’t cutting it: https://www.disk-drill.com/.
Good luck, and may your files find their way back home!
Ah, RAW partitions, the stuff of nightmares. Recovering data from a RAW partition isn’t always smooth sailing, but it doesn’t have to be a total shipwreck either. So, if you’re looking for a different perspective or a Plan B—I’ve got a few additional suggestions that might just save the day.
  1. Disk Management Alternatives: Before diving into recovery software, use a different OS to check your drive. Sometimes, Linux-based live CDs like Ubuntu can read partitions that Windows can’t. Just boot from a USB drive, mount your RAW partition, and see if your files are there.
  2. TestDisk: Unlike the fancier GUIs of Disk Drill and EaseUS, TestDisk is a rugged, free, open-source tool that can do wonders, especially for recovering lost partitions or making non-booting disks bootable again. It’s got a bit of a learning curve, but it’s worth it. Boot up TestDisk, let it analyze your drive, and follow the prompts. Detailed guides are all over the internet.
  3. Photorec: Often used in tandem with TestDisk, Photorec is also open-source and works wonders for file recovery. While TestDisk is great for partition recovery, Photorec dives in to recover specific files. Note, though, it’ll likely recover them without original filenames and structure, so be ready for some digital archeology.
  4. DiskGenius: Another alternative software worth mentioning is DiskGenius. This one’s got a neat feature set for both data recovery and partition management. It allows you to preview files before recovering them, which is a nice touch. Same precautions apply, though—install it on a separate drive.
  5. Hardware Checks: The software route is crucial, but let’s not neglect the hardware. Verify if your drive isn’t suffering from physical issues. If all else fails, it may be worth chucking it into an external USB enclosure and seeing if another computer can access it. Sometimes, the problem is with the SATA controllers on your mainboard or ports.
Now, Disk Drill is a solid suggestion without a doubt, but what I really love about it (besides the comprehensive recovery capabilities) is the clear interface. For those less tech-savvy, Disk Drill is a fantastic go-to. And for a deeper dive, you can check out their official page for more detailed recovery instructions here: Disk Drill Data Recovery Software.
  1. Backup & Future-proofing: We always learn the hard way, don’t we? Once your data is safe, invest in a robust backup solution. Local backups work, but cloud storage options add an extra layer of security. Look into automated solutions—something like Backblaze, or even good old external HDDs and SSDs using software like ChronoSync on macOS or FreeFileSync on Windows.
  2. Drive Health Monitoring: After fixing your partition, regularly check the drive’s health using tools like CrystalDiskInfo or HD Tune. These apps can give you a heads-up if your drive starts showing signs of failure again.
So, buckle up, and dive into some alternatives if your first choices don’t work. Good luck with recovering those invaluable files. And hey, even the best of us have been there, cursing at a RAW partition. You’ll get through it.
Oh man, dealing with a RAW partition can be a real headache, but don’t sweat it too much. You’ve already gotten some great advice from @byteguru and @codecrafter, but let me toss in a few additional tips and thoughts.
For starters, I echo the caution to stop using the drive. Writing anything to it now could be a lethal blow to your recovery efforts. It’s not just a good idea—it’s essential.
Hardware Checks
Physically check your drive. Absolutely don’t overlook this step. It’s often skipped because it’s the simplest, but a loose connection or bad cable can be all it takes to make your drive appear RAW. If you have the tech skills, pop it into a different machine or an external USB enclosure to see if it reads fine there. Sometimes, it might just be a specific port issue on your primary PC.
Alternative OS
Here’s a twist: before diving into recovery software, why not try booting from a Linux live CD, say Ubuntu? Linux is a different beast and can sometimes access data that Windows stubbornly refuses to acknowledge. Trust me, it’s easy to boot from a USB and gives you a fresh perspective.
TestDisk & Photorec
If you can stomach a bit of a learning curve, TestDisk and Photorec are a formidable combination. TestDisk is like that Swiss Army knife tool—open-source and effective but needs some know-how. Photorec complements it perfectly for file-specific recovery, though keep in mind it’ll dump recovered files loosely without their original names and folders.
Advanced Data Recovery Tools
Disk Drill gets a lot of mentions here, and for good reason. It’s user-friendly and powerful.
Pros of Disk Drill:
  • User Interface: Simple and intuitive, fantastic for non-techies.
  • Comprehensive Scanning: It deeply scans for lost data, potentially recovering even from heavily corrupted drives.
  • Free Version Limitations: The free version limits you to smaller data sizes. If you have a ton to recover, you’ll need to go Pro.
  • Speed: Can be slower on larger drives.
If Disk Drill isn’t cutting it for some reason, you might want to look into EaseUS or MiniTool Power Data Recovery. Both are highly reputable, although, like Disk Drill, they have limitations in their free versions.
Command Line Options
A quick note on CHKDSK: this can be a double-edged sword. It’s powerful but can sometimes make things worse. Use it cautiously:
  1. Open Command Prompt as an administrator.
  2. Type chkdsk X: /f (replace X: with your RAW drive letter).
  3. If it prompts for NTFS conversion, decline. Overwriting is what you’re trying to avoid.
Professional Help
If all else fails and this is life-or-death level data we’re talking about, professional recovery services are your fallback. But brace yourself; they can be costly.
Backups & Monitoring
Lastly, post-recovery, please, please invest in a robust backup strategy. And not just any backup—a reliable schedule. Use local and cloud solutions to keep your bases covered. Tools like ChronoSync for macOS or FreeFileSync for Windows can automate this process.
Techie or not, regular health checks for your drives using tools like CrystalDiskInfo or HD Tune can save you from future heartaches. Early detection of drive issues can give you the leeway to back up data before it’s too late.
Good luck! You’ve got this. Once you’re through this RAW partition storm, you’ll be better prepared for any similar tech nightmares in the future.
Leave the RAW drive alone. Skip CHKDSK and decline any prompt to format it.
If you need a few specific files, look for copies you already shared. From another device, search your email and chats for the project name. In Gmail, try filename:pdf or filename:xlsx to find attachments.
For photos, check your phone and camera card for the originals. Save each copy to a seperate drive, then open it and check for your latest edits. List anything still missing before you spend money on recovery.
