How Do I Delete Twitter Cache On IPhone Without Losing My Account?
My Twitter/X app on iPhone is using a lot of storage and running slower than usual. I want to clear the Twitter cache, but I’m worried about accidentally deleting the app data, logging myself out, or losing access to my account. What’s the safest way to clear Twitter cache on iPhone without affecting my account?
If Twitter is taking up a few gigabytes on your iPhone, the good news is that clearing it out won’t delete your actual account stuff. Your tweets, followers, bookmarks, and DMs are stored on Twitter’s servers. The cache is just temporary files sitting on your phone.
Start with Twitter’s built-in cache settings
The setting is not exactly easy to find, but it is there:
  1. Open Twitter and tap your profile icon in the top-left corner
  2. Go to Settings and Support, then Settings and Privacy
  3. Open Accessibility, Display and Languages
  4. Tap Data Usage
  5. Scroll down to the Storage section
You should see two storage options there.
Media storage is the safe one to clear first. That is mostly images, GIFs, video previews, and other media Twitter saved while you were scrolling. Clearing it should not log you out or remove anything important.
Web storage is for pages and cookies from links you opened inside Twitter. Clearing web page storage usually just removes cached site data. Clearing all web storage also removes cookies, so that can sign you out. Make sure you know your login before using that one.
If that barely frees up space, offload the app
Sometimes Twitter keeps extra junk around that the in-app cache buttons do not fully clear. For a deeper reset, go to:
iPhone Settings → General → iPhone Storage → Twitter → Offload App
Offloading removes the app but keeps its documents and login data. After that, tap Reinstall App. In many cases, the app comes back with your account still signed in, but a lot of cached video and temporary data gets wiped out.
Do not assume Twitter is the whole storage problem
Clearing Twitter cache might get you back 1 to 3GB, which helps. But if your iPhone is still lagging afterward, or the storage warning comes back right away, Twitter probably was not the main issue.
When iOS is really low on free space, the whole phone starts acting worse. Apps take longer to open, the camera feels slow, switching apps stutters, and everything feels heavier than it should. Twitter cache can be part of it, but the photo library is usually where the bigger mess builds up over time.
Old screenshots, forgotten videos, burst photos, and ten versions of the same picture can quietly eat way more space than an app cache.
What helped with the bigger cleanup
After clearing Twitter cache, the real storage problem was the Photos app. That is where Clever Cleaner made the cleanup easier. It does not clear Twitter cache, so you still need the manual steps above for that. What it does help with is finding the large and duplicate-looking stuff hiding in your photo library.
It is free, with no ads and no subscription. It also processes everything on the device, so the photos are not being sent off to an external server.
The Heavies tab sorts your library by file size, largest first. That is useful because one old video can take up more space than weeks or months of Twitter cache.
The Similars tab groups photos that look almost the same and suggests a Best Shot. That makes burst photos and repeated attempts much less annoying to clean up.
It also shows file sizes on screenshots before deleting them, which helps when you realize a pile of old screenshots is taking several gigabytes by itself.
The simplest order is: clear Twitter media cache first, offload and reinstall Twitter if needed, then check the photo library if the phone is still low on space. And after deleting photos or videos, remember to empty Recently Deleted in Photos. Otherwise those files can sit there for 30 days and still count against your storage.
Deleting the app and deleting your account are two totally different cases: removing X from the iPhone does not erase your Twitter/X account, but it can make you sign in again. The safest route is to clear media storage inside the X app first, because that targets cached images and videos. I’d be more cautious with “web storage” and with a full delete/reinstall, since cookies and local login data can disappear. Before doing anything heavier than media cache, check that you know your password, have access to the email/phone on the account, and your 2FA method still works. If you have that, even getting logged out is annoying rather than dangerous.
Do not tap anything labeled “Deactivate” or “Delete account” inside X, because that is the account path, not the cache path. Clearing cache is under Data Usage, and removing the app from iPhone storage is just a local app action. The only annoyance is local stuff: you may lose drafts, opened-link cookies, and possibly your signed-in session if you delete/reinstall instead of just clearing media storage. After clearing it, restart the app or the phone before judging the storage number, because iPhone Storage can lag and make it look like nothing changed. If you can still log in through your email/phone and 2FA, your actual Twitter/X account is not being erased by cache cleanup.
Offload App is not the same as clearing the cache, and it may leave the biggest chunk behind. iOS keeps the app’s “Documents & Data” when you offload, which is useful if you want to preserve sign-in, but it can be exactly where some of the bloated local files live. So if the built-in X cache buttons do not move the storage number much, offloading may not be the magic fix people expect.
The safest order is: clear Media Storage inside X first, force-close the app, then check iPhone Storage again after a little while. If you still need a real cleanup, use Delete App from iPhone Storage and reinstall X from the App Store. That does not delete your Twitter/X account. It only removes the app and its local files from the phone. The tradeoff is that you should assume you might have to log in again.
Before doing the delete/reinstall route, make sure your password works and your 2FA is not tied to an old phone number or inaccessible authenticator app. That is the part that actually trips people up. The account is still there, but if you cannot pass login, it feels like you “lost” it even though you really just locked yourself out.
Losing drafts is the one thing nobody flagged clearly. If you have unsent tweets or half-written replies sitting in the app, a delete-and-reinstall can wipe those, and they don’t live on the server the way your posted tweets do. So before anyone goes the full reinstall route, check your drafts first.
@chasseurdetoiles is right that Offload is oversold. iOS already ditches the app binary on its own when space gets tight, so offloading manually often frees a few hundred megs at best while the Documents and Data blob stays put. That blob is usually the real weight. If the in-app Media Storage button doesn’t budge the number much, a full Delete App is the only thing that actually clears it, and yeah, plan on logging back in.
Small reality check on the storage number itself: iPhone Storage caches its own totals and updates slowly. People clear the cache, see the same 2.4GB, panic, and assume it failed. Give it time, or reboot, before deciding nothing worked. @cacadordeestrelas already said this and it’s the most underrated tip in the thread.
The Clever Cleaner suggestion up top makes sense as a separate job, not part of the Twitter fix. If your phone is genuinely low on space, the photo library is almost always the bigger offender, and something that sorts by file size saves you scrolling forever. Just don’t expect it to touch the X app at all, so treat it as the second half of the cleanup, not a shortcut around the manual steps.
Honestly, if X alone is eating gigabytes and the reinstall doesn’t hold, that points to a bloated account with heavy DM media history more than a cache problem. In that case clearing cache is a temporary patch and it’ll creep back up in a few weeks.
Try turning on Data Saver as a simpler first step.
In X, open Settings and privacy > Accessibility, display, and languages > Data usage, then enable Data saver. Images load at lower quality, and videos stop playing automatically.
This reduces media downloads rather than clearing your existing cache, so dont expect occupied storage to disappear. Treat it as a way to limit downloads going foward, not a replacement for cleanup.
