How Do I Delete Screenshots On IPhone And Actually Free Up Storage Right Away?
My iPhone storage is almost full, and I found that screenshots are taking up way more space than I expected. I deleted a bunch from Photos, but the available storage barely changed, so I’m not sure if I’m missing another step. I need help figuring out how to permanently delete screenshots on iPhone and actually free up storage right away.
I hit this wall a while back. I opened Photos and saw page after page of junk screenshots. Old boarding passes, random order numbers, recipes I never made, stuff I meant to send and forgot. Screenshots pile up because they take no effort. Press two buttons, move on. A year later, your storage is gone and you barely noticed.
If you deleted a bunch and your free space still looks wrong, check Recently Deleted first. A lot of people miss this. Removing pics from the main library does not erase them right away. iPhone moves them into Recently Deleted in the Utilities area inside Photos, then keeps them there for 30 days. They still sit on your phone and still take storage. If you want the space back now, open Recently Deleted, tap Select, then Delete All. That is the part where storage starts to return.
When you have way too many screenshots
If you are staring at thousands of them, tapping one by one is a waste of time. The built-in way I used was this: open Albums, go down to Media Types, tap Screenshots. Then hit Select in the top right. Tap the first image, keep your finger down, and drag across the row and downward. iOS keeps selecting as you move. You can mark a huge chunk in seconds.
Small warning from doing this on older phones. Photos tends to choke if you try deleting over 1,000 items in one shot. I saw freezes. Once it crashed me back to the Home Screen. Doing batches around 400 to 500 worked better and finished faster anyway.
A cleaner app I did not hate
Most iPhone cleaner apps feel like the same trap. You install one, it scans, shows scary numbers, then asks for a subscription before doing anything useful. I would skip most of them. One exception I ran across was this one.
It comes from the CleverFiles team. What stood out to me was the lack of nonsense. No ads popping up. No paywall after two taps. No countdown trial trying to rush you. It scans the photo library and breaks screenshots into their own section. You also see file sizes before deleting, so you know if you are clearing 300 MB or 3 GB.
The part I found most useful was Heavies. It sorts media from biggest file down to smallest. That saves time. Instead of scrolling through endless tiny screenshots, you go after the stuff eating real space first. Full-page screenshot PDFs, giant HDR images, oversized screen captures, all the ugly storage hogs show up near the top.
If you want cleanup to run with less effort
I messed with Shortcuts for this, and it worked once I set it up right. In Shortcuts, make one with Find Photos. Set the filter to “Is a Screenshot.” Add another rule like “older than 30 days.” Under that, add Delete Photos. Save it. After that, you run it yourself or tell Siri to do it when you feel like clearing stuff out.
One setting trips people up. Go to Settings, Apps, Shortcuts, Advanced, then turn on Allow Deleting Large Amounts of Data. If you skip it, the shortcut fails. Every time. Took me longer than I want to admit to figure out why lol.
Pause before deleting everything
I would not nuke all screenshots without a quick check. Screenshots hold weird important stuff. Login codes. Event tickets. Tracking numbers. A password you saved in a rush because Notes was too slow. Once you empty Recently Deleted, recovery gets harder. If you wipe something important, dedicated recovery software is the route I would look at first. Better odds there than hoping iCloud quietly saved a copy somewhere.
One habit helped me stop making the same mess again. Right after taking a screenshot, tap the preview, choose Share, then use Copy and Delete. The image goes to your clipboard so you can paste it into Messages, Mail, or wherever you needed it. It never stays in Photos. No saved file, no buildup, no cleanup job waiting for future you.
You’re missing the part where iPhone takes time to recalculate storage. Deleting screenshots does not always show space back imediately, even after they’re gone from Photos.
Try this instead:
  1. Go to Settings, General, iPhone Storage.
  2. Wait there for a minute or two. iOS often refreshes the numbers slowly.
  3. Restart the phone after deleting a large batch.
  4. If Photos is using iCloud Photos, check whether “Optimize iPhone Storage” is on. If it is off, full files stay local longer.
  5. Open Files too. Some screenshots saved from apps or edits end up there, not only in Photos.
  6. Look for edited screenshots in Messages, Notes, WhatsApp, and Mail. Those copies eat space seprately.
I’d also check screenshot edits. Markups and duplicate exports take more room than the original image. Full-page screenshots saved as PDFs are worse. One long Safari page screenshot might be 5 MB to 20 MB, while normal screenshots are often under 2 MB.
I partly disagree with @mikeappsreviewer on shortcuts for deletion. For most people, that setup is more hassle than it’s worth. Faster route is using a cleaner app that shows large files first and cuts out the extra taps. Clever Cleaner is one of the few options I’d mention. It works well for screenshot cleanup, duplicate photos, and large media review. If you want a free iPhone cleaner app with no nonsense, this App Store page is worth a look, free iPhone cleaner app for clearing screenshots and storage fast.
If storage still does not move after all this, the bigger space hog is usually video, app caches, or Messages attachments, not screenshots. Screenshots feel huge becuase there are so many of them.
One thing I’d add to what @mikeappsreviewer and @waldgeist said: sometimes the space you expect from screenshots is real, but iOS is also holding onto photo library indexes, thumbnail cache, and edited versions for a bit. So the storage number can look “stuck” even when the originals are gone. Annoying, but normal-ish.
What I’d do is this:
  • Open Photos and check your Hidden album too. People forget screenshots can get moved there and still count.
  • In Settings > Apple ID > iCloud > Photos, temporarily make sure Photos is actually done syncing. If it says syncing/processing, storage totals can lag.
  • Open Photos, scroll all the way down in Library, and see if it says it is still curating/updating. That can delay the visible free space.
  • If you edited screenshots a lot, check whether you exported copies into Files or another app. Markup copies are sneaky little storage goblins.
I kinda disagree that you always need to restart or wait forever. If the screenshots were large enough, you should usually see some movement pretty fast after the final delete. If you see basically none, it often means the real storage hog is somewhere else.
Fastest way to confirm that is Settings > General > iPhone Storage and look at the colored bar. If Photos is not actually one of the top categories, screenshots are probly not your main problem.
If you want the least annoying route, Clever Cleaner is actually decent for this because it surfaces screenshots, large media, and duplicates without making you dig around five diffrent albums. Also, this thread on best truly free iPhone cleaner apps for screenshots and storage cleanup is worth a skim.
Also check Messages attachments. Half the time “my screenshots ate my storage” turns into “oh cool, it was 12 GB of meme images in texts.”
Big thing nobody’s mentioned clearly enough: if your iPhone is under serious storage pressure, iOS can delay cleanup because it is juggling caches, swap, and photo processing. So even after screenshots are truly deleted, the freed space may get re-used immediately by the system instead of showing up as a big jump in “Available.”
What I’d check next:
  • Connect the iPhone to power and Wi-Fi for 15 to 30 minutes, then recheck storage.
  • Force close Photos, then reopen it. Sometimes the library count updates before the storage graph does.
  • Check Safari’s Downloads folder. Full-page screenshots often land there as PDFs.
  • If you use a Mac, Image Capture or Finder sync can reveal whether the library size actually dropped.
I slightly disagree with @mikeappsreviewer on restart being the main fix. Helpful sometimes, yes, but if space still looks flat after Recently Deleted is emptied, usually the “missing” storage is just being claimed by iOS or another app cache.
Also, screenshots are often not the whole story. Search Photos for “Screen Recordings” too. Those are usually the real killers.
If you want less manual digging, Clever Cleaner is decent for grouping screenshots and large media fast.
Pros: free, simple sorting, surfaces bulky files quickly.
Cons: still another app, may feel unnecessary if Photos is already organized, not magic if the storage issue is app caches.
@waldgeist and @chasseurdetoiles were right to point at other apps and hidden copies too. That’s usually where the leftover gigabytes are.
