I’ve started seeing these new AI Overview boxes at the top of my search results and they’re getting in the way of the normal links I actually want to click. I’ve tried digging through settings, extensions, and even different browsers, but I can’t find a reliable way to fully disable them. Is there a proven method, workaround, or browser setting that will hide or turn off AI Overview results across all my searches?
Short version. You cannot fully turn off AI Overviews at the source yet. Google does not give a real “off” switch. You have workarounds.
Here is what helps the most right now:
Use the “Web” filter on Google
• On desktop and mobile, after you search, tap/click “More” or scroll the filter row.
• Pick “Web”.
• That shows mostly classic blue links with no AI Overview on top.
• You need to hit “Web” on each new search. Google does not lock it as default for everyone yet. -
Use a different start page that forces “Web”
You can set a custom search URL as your browser’s default engine or bookmark it. For Google, use something like:Steps example for Chrome desktop:
• Settings → Search engine → Manage search engines.
• Add a new one.
Name: Google Web only
Shortcut: gw
URL: Google Search
• Set it as default.
This sends every search with the “Web results” mode. AI Overview usually disappears. -
Use uBlock Origin or another blocker
On desktop browsers, install uBlock Origin.
Then add a custom rule to hide the AI box. For example filter (might need tweaking as Google changes stuff):google.com##div[data-hveid][data-ved] > div:has(h2 span:has-text(“AI Overview”))
If that breaks, you can use the element picker in uBlock on an AI Overview box and generate a new cosmetic rule.
This does not stop Google from generating it, but it hides it from your view. -
Use an alternative search engine for a while
Examples:
• DuckDuckGo
• Kagi
• Brave Search
Many people switch for normal link-first results and no AI box at the top. -
On mobile apps
• In the Google app, you cannot fully disable AI Overview.
• You can still tap “Web” after each search.
If it drives you nuts, use your browser with the “udm=14” link as default instead of the Google app.
Extra note. Google is testing options to reduce AI Overviews for some users, but there is no stable global toggle. Right now your best long term move is either the “Web-only” URL hack or switching search engines.
You can’t fully nuke AI Overviews at the source right now, and I kinda doubt Google is rushing to give us that big red “OFF” switch. @chasseurdetoiles already covered the Web tab + udm=14 trick and uBlock rules really well, so I’ll skip rehashing those.
Here are a few different angles you can try:
Change how you trigger Google in your browser
Instead of changing the search engine URL like they suggested, you can avoid Google’s “smart” page entirely for quick lookups:- Use the address bar for a different engine (DuckDuckGo, Brave, Kagi, whatever) as your default.
- Then keep Google only as a manual bookmark for those times you actually need it.
This flips the default: your normal searching is AI-free (or at least AI-lite), and you consciously opt into Google when you want it. In practice, that reduces your AI Overview exposure way more than tinkering only inside Google.
Use browser shortcuts to jump straight to “classic” results
If you’re stuck with Google (work / school / ecosystem), set different keywords:g→ your normal Googlegw→ Google with “Web-only” parameters (or privacy search wrapper if you use one)
You then train yourself: serious info hunt →gw, quick junk →g. It’s a behavior hack, but it works surprisingly well once muscle memory kicks in.
Strip a lot of the cruft with reader-like tools
Not ideal, but when AI Overviews + other junk is overwhelming:- Open the result you actually want in a new tab.
- Use a reader mode extension or built in “Reader” (Firefox/Safari) so at least the on-page AI crap and widgets don’t keep following you around.
This doesn’t remove AI Overview from the SERP, but it makes browsing the web itself less “assistanted.”
Use country / language variants to dampen it
Not foolproof, but for some people:- Try
https://www.google.com/ncrand then pick a specific country interface like.co.ukor.de(even in English).
Roll the dice: Google does not roll out every AI experiment at the same intensity in every locale. Sometimes one interface gets a lighter version of AI Overview or fewer triggers. It’s inconsistent, but some folks report way fewer AI blobs after switching locale and language combo.
- Try
Nuke personalization where possible
This will not turn AI Overview off, but it can reduce how “eager” Google is to mess with your results:- Log out of your Google account for searching.
- Turn off Web & App Activity and ad personalization.
- Use incognito or a different browser profile just for search.
Less profile data = sometimes fewer “smart” features. It’s not magic, but it can help on the margins.
On Android, dodge the Google app entirely
Instead of fighting the Google app (which is stuffed with AI stuff and has practically zero off switches):- Long press the search bar widget and remove it.
- Put your browser’s search bar widget on the home screen instead (Firefox / Brave / DDG / whatever).
- Point that widget at your preferred engine or your custom Google URL.
That alone stops a lot of accidental AI Overview exposure because you just never open the “AI-first” Google app.
Mental model reality check
If your goal is “completely turn off AI Overview in my search results,” right now the honest answer is: you can’t, unless you stop using consumer Google search directly. You can:- Hide it (cosmetic filters like uBlock).
- Route around it (different engine, “Web-only” hacks, locale changes).
- Reduce how often it appears.
But a clean setting like “AI Overview: OFF” does not exist, and all of this is workarounds on top of a design choice Google is clearly committed to.
So the practical strategy is:
- Treat Google as the exception, not the default.
- When you must use Google, use a “Web-first” route into it.
- On desktop, hide the Overview box with a blocker so you don’t even see the thing.
- On mobile, avoid the Google app and rely on browser search instead.
It’s annoying, but right now the real power move is shifting your habits, not waiting for a magic toggle that probably isn’t coming any time soon.
Short version: you cannot fully kill AI Overviews inside Google itself right now, but you can quarantine them pretty hard without just copying what @chasseurdetoiles already laid out.
Here are some different angles that build on (and occasionally disagree with) their approach.
1. Stop treating Google as a “page,” treat it as a backend
Instead of going to google-dot-com directly:
- Use a meta-search or privacy front‑end that still pulls Google results but strips the layout, experiments and AI junk.
- Conceptually, you are using Google as a data source, not as the interface.
- You still get Google’s index and ranking quality.
- Layout and experiments like AI Overview are often removed or heavily minimized.
- Some front‑ends break occasionally when Google changes things.
- You are trusting an extra service in the chain.
This is where something like an unnamed “search wrapper” product shines. Think of it as a “Google reader mode for search.”
Pros for that kind of tool:
- Gives you classic, link‑first SERPs.
- Often adds its own filters and grouping that Google hides behind AI stuff.
Cons: - One more bookmark / default engine to maintain.
- Sometimes slower than going to Google directly.
@chasseurdetoiles leans more on URL parameters and adblock rules. That works, but those break more often than a dedicated wrapper that is actively maintained.
2. Change your query style to minimize AI triggers
AI Overviews do not fire uniformly on every kind of query:
- They are more aggressive on “how do I…”, medical, recipes, “best X for Y”, and “explain” type searches.
- They are less common on very specific technical strings, product codes, or navigational queries.
Practical trick:
- If you are just trying to reach a known site: search
site nameor even addsite:domain.comand you often dodge the blob. - For “best X” queries, deliberately search like an old‑school power user:
- Example: instead of “best budget mechanical keyboard,” search
'budget mechanical keyboard' review -reddit -quoraand then manually pick comparison reviews.
This is not perfect, but it significantly cuts how often AI Overviews show up.
3. Use browser profiles to sandbox Google
Instead of changing your main setup:
- Create a separate browser profile (or even a separate browser) that is “Google‑only, AI‑tolerant.”
- Your primary browser is set to a different engine as default, with no Google shortcuts at all.
Why this helps:
- You are adding just enough friction that you only open that “Google profile” when you absolutely need something Google is good at, like weird long‑tail queries or language‑specific searches.
- Over time, your default mental path is non‑AI search, and Google becomes a specialist tool.
This is more effective long term than just adding special udm=14 shortcuts, which people tend to forget or mistype.
4. Use mobile browser “quick search” tricks instead of the OS defaults
I partly disagree with the idea that “avoid the Google app” is enough. On a lot of Android setups, the system search will still try to pipe you into Google’s AI‑heavy flow.
Instead:
- In a mobile browser like Firefox or Brave, set your main engine to something non‑AI or AI‑lite.
- Configure “quick search” keywords there for the rare Google usage.
Example: typeg your queryin the URL bar to send only that query to Google.
This solves two annoyances:
- The random, muscle‑memory taps on the system search bar do not open AI Overview at all.
- When you consciously use Google via
g, you are in a normal browser where you can still run any cosmetic blocking you want.
5. Organizational workaround: shared “classic search” link
If you are in a work or school environment where people keep sending Google links that open with AI Overview:
- Create and share a “classic search” internal bookmark (for example, a documentation page or intranet link) that explains:
- Which URL pattern to use for web‑only results.
- Which browsers / extensions your org recommends.
You turn it into a small internal standard. Once a few people use it, the volume of “polluted” Google links you receive drops, because they start from the cleaner entry point.
This is not just a technical fix, it is a social one.
6. Accept partial wins instead of chasing a total “OFF” switch
You are not going to get the browser‑level “AI Overview: Disabled globally” toggle from Google any time soon. If you aim for zero presence, you will just burn time and end up frustrated.
A more realistic goal:
- 80–90 percent of your searches should hit a clean interface.
- The remaining 10–20 percent are on Google, but entered through:
- a wrapper,
- a special profile,
- or a shortcut that lands you closer to classic results.
That is usually enough that you simply stop noticing AI Overviews in day‑to‑day browsing, even though they still technically exist.
Bottom line: instead of fighting for a magical in‑Google setting that does not exist, reshape how and where you search. Treat Google as a backend and emergency tool, and let other engines or wrappers handle your actual “search page” experience.
Use a one-click bookmarklet to hide the AI Overview after Google loads.
Create a bookmark, name it “Hide AI,” then paste this into its URL field:
javascript:document.querySelector(‘[data-mcpr]’)?.remove
When the box appears, tap the bookmark. It removes the overview from the current page and leaves normal links untouched. No browser profile, search wrapper, or query changes needed.
Google sometimes changes page code, so the selector might need an update later. For now, this is quick, local, and easy to undo by refreshing the page. Takes about 30 secounds to set up.
A bookmarklet you tap after the page loads and a URL parameter that fires before anything renders are solving two different problems. @j.collins’s hide trick is fine for the odd search where the box surprises you, but if you run twenty searches an hour you’ll get sick of clicking it, and on mobile bookmarklets are a pain to trigger at all. The udm=14 route wins there because you never see the thing in the first place, no manual step.
The catch nobody’s flagging: udm=14 and the Web filter aren’t a clean ‘AI off.’ They drop you into a plain text-links mode, which also strips images, the map panel, shopping boxes, the little ‘sites’ carousels, sometimes even the knowledge panel on the right. Most days that’s exactly what you want. But when you’re actually looking for a product picture, a local business with hours, or a quick image search, you’ll be flipping back to normal results and eating the AI Overview anyway. So it’s less ‘disable AI’ and more ‘swap into a stripped view.’ Worth knowing before you set it as your only default.
For a middle ground I’d keep two shortcuts and not overthink it. One that lands on plain Web mode for the boring info lookups, and normal Google for the visual or local stuff. That covers most of the day without a browser profile setup or query-rewriting gymnastics. And honestly, if Google’s the only reason you’re building all this scaffolding, just try a week on a different engine as your default. Half the workarounds in this thread disappear the moment Google stops being the first thing your address bar reaches for.
