I accidentally put the wrong birthdate on my TikTok account when I first signed up, and now some features seem limited, like certain videos and live streams. I’ve tried looking in the settings but can’t find a clear option to update my age or birthday. Is there a correct way to change my age on TikTok or contact support so my account reflects my real age without getting it banned or deleted?
Short version. You cannot change your age yourself in TikTok settings once the account is created. You need support to do it.
Here is what usually works now:
Gather proof of age
• Government ID with birthday visible
• Or a school ID, passport, driver’s license
• Cover sensitive stuff like ID number if you want, leave name, photo, birthdate -
Go to TikTok support
• Open TikTok app
• Profile tab
• Top right menu
• Settings and privacy
• Report a problem
• Choose Account and profile
• Then Editing profile or Other
• Tap Need more help at the bottom -
Write a short message
Example text, edit with your details:
“Hi, I entered the wrong birthdate when I created my account. My correct date of birth is [DD/MM/YYYY]. Some features like lives and age restricted videos do not work. I want my account age corrected. I attached an ID photo as proof.” -
Attach your ID
Use the attach/upload option in the form.
Make sure your name on TikTok matches the ID or at least is close enough. -
Wait for a reply
• Usually 1 to 5 days
• Check your TikTok notifications and the email linked to your account
• They might ask for a clearer picture or more details
Important stuff:
• If your real age is under 13, they often restrict or remove the account.
• If you are 13 to 17, some features stay limited by design. Age fix will not turn it into a full adult account.
• If you are 18 or older and they confirm it, you get access to lives and age restricted content again after the change.
If the in app flow fails:
• Use the TikTok feedback form in a browser:
https://www.tiktok.com/legal/report/feedback
Choose Account or profile, explain the same thing, attach ID.
If they ignore you:
• Try again from the app and from the web form.
• Keep the message short and clear, no long rant.
• Use the same email every time.
There is no safe “hack” or trick in settings. No third party site fixes age. If someone says “use this tool to change your TikTok age” they want your login or money.
You’re right that it’s not in Settings, and TikTok makes it deliberately hard so people can’t just flip their age every time something is age‑gated.
@vrijheidsvogel already laid out the “official” route with support + ID, so I’ll skip retyping that checklist. A few extra angles that might help:
Check what you actually want changed
TikTok has:- Account age (what you entered at sign up)
- “Mature content” / restricted mode & content filters
If your real age is 18+ and you already turned off Restricted Mode and still can’t see certain videos or go live, then it’s almost certainly the DOB issue like you said.
Match your info first
Before contacting support, make sure:- Your TikTok display name or username isn’t something totally random if your ID shows your real name.
- Your email in TikTok is one you can actually access, because sometimes they reply there instead of in-app.
This sounds small, but mismatched details are one of the reasons they silently ignore requests.
Be very specific in your message
I don’t fully agree with keeping it too short like some people say. In my case, the request only worked after I added:- The wrong date I used
- The correct date
- A line like: “I understand some features are age restricted and I only want my birthdate corrected to match my legal ID.”
That makes it sound less like you’re just trying to bypass protections.
What happens if your real age is under 18
- Under 13: realistically, they might just lock or delete the account. There’s no magic wording that avoids that.
- 13–17: you still will not get full adult features. So if you’re 16 hoping this will unlock everything, it won’t. It just fixes your profile age, not TikTok’s teen rules.
If they don’t respond
- Submit from the app once.
- Submit from the web feedback form once.
- Wait a few days between tries.
Spamming daily tickets usually hurts more than it helps. TikTok support is slow and inconsistent, so half of this process is just patience.
When it’s not worth the fight
If:- Your account is small
- You don’t have drafts you care about
- You’re actually old enough but typed something drastrically wrong (like 2008 instead of 1998)
Sometimes it’s faster to: - Make a new account with the correct DOB
- Download and reupload your old drafts (or save them while logged in)
than to wait weeks for support to care. That’s what I ended up doing after two ignored tickets, then TikTok fixed my original age a month later anyway, which was… helpful but also useless by then.
Avoid “tricks”
Any site or video claiming “change TikTok age without ID” that asks for:- Your login
- Payment
- A weird “age unlock” app
is just trying to scam you. There is no hidden settings menu that support users don’t know about. If there was, TikTok would have patched it already.
So: no in-app toggle to fix age. Your real options are support with ID, or cut your losses and remake the account if it’s not that valuable yet.
Short version before the details: you basically have three realistic paths, and only one of them involves TikTok actually changing your birthdate.
1. Understand what “age” TikTok is using
People often mix these up:
- The date of birth you entered at signup
- Content controls inside the app (Restricted Mode, keyword filters, family pairing)
If you typed a fake younger age and you are actually 18+, then even with Restricted Mode off you will still hit age walls for Lives, certain sounds, and “mature” videos. That is the account-age problem you are seeing.
Before you do anything else, quickly check in the app:
- Settings & privacy → Content & display → Restricted Mode
- Make sure it is off and not locked with a passcode someone else set
If Restricted Mode is on, fix that first. If it is off and you are still blocked, then it is the DOB on the account, which matches what you described.
2. Where I disagree slightly with the others
@chasseurdetoiles and @vrijheidsvogel are right that you cannot flip your age inside settings and that support plus ID is the “official” way. I do disagree a bit on two things:
ID is not always strictly required in every region
In some countries, if the wrong age is not massive (like off by 1 year and still under 18), support sometimes refuses to change it at all, even with ID. They basically treat it as “not worth the risk” from their legal side. In that case, you can keep sending them ID all day and they will reply with canned answers or nothing. -
It is not always worth waiting on a small account
People sometimes burn weeks on tickets for an account with 10 followers and no drafts. In practice, TikTok support is slow, inconsistent and will not prioritize “I typed 2009 instead of 2003” over serious reports. If your account is tiny, starting over is not a “last resort,” it is often the cleanest solution.
3. Three realistic options
Option A: Push support properly
You already know the basic support path from the others, so here are extra angles that matter:
- Make sure your email and phone on TikTok are valid and you can access them
- Temporarily change your profile info so it is less “trolly” and closer to the ID (photo and name especially)
- In your message, be very literal and factual:
- Include the wrong date you used
- Include the correct date
- Say you understand age restrictions and you only want your age to match your legal documents
This is boring but it makes you look less like you are trying to cheat your way into 18+ content.
If they ignore you twice in a row after several days, that is usually a soft “no.” Spamming them every day does not turn into a “yes,” it just gets your tickets filtered.
Pros of this path
- Keeps your followers, drafts, DMs, and username
- Once fixed and verified, your account is less likely to be flagged for age issues again
- Necessary if you are already a creator with a real audience
- Slow
- Sometimes no response at all
- Under 13 can lead to the account being restricted or removed
- 13 to 17 will still be limited after the change
Option B: Make a new account with the correct age
This is underrated for small or new accounts.
- Log into your current account
- Save any drafts or posted videos to your phone
- Note any important usernames you follow
- Create a new account, this time with the correct date of birth
- Reupload anything you care about, refollow people, and move on
If later support magically replies and fixes your original age, you can choose which account to keep as your “main.”
- Immediate fix for future content and features
- No waiting for support
- Clean record with correct age from day one
- Lose existing stats (views, likes, follower count)
- Have to rebuild your feed personalization and social graph
- Some usernames might already be taken by your old account
Option C: Accept teen restrictions if you are under 18
If your real age is actually under 18:
- Under 13: TikTok’s rules simply do not allow a normal account in most places. Correcting your age may remove or heavily limit the account.
- 13 to 17: even with the correct age, Lives and some content types are restricted by policy, not by a bug.
In that case, no birthdate change will magically unlock adult-level features. The only honest move is either:
- Live with the limited feature set, or
- Wait until your real age hits the threshold TikTok uses in your country
Trying to “game it” with a fake 18+ age can backfire later when they run extra checks, especially on accounts that start growing.
4. About “tools” or third party tricks
Anything claiming “change your TikTok age without ID or support” is basically:
- Phishing for your login
- Trying to install shady apps
- Wasting your time
There is no hidden menu, no shortcut in Settings, and no browser trick that flips your account age behind TikTok’s back. If there were, it would have been patched already because it breaks their compliance obligations.
5. Mini comparison with what others said
- @chasseurdetoiles focused on the practical checklist and is spot on about using ID and staying concise
- @vrijheidsvogel added some good nuance about specifying both the wrong and correct dates and being realistic if you are under 18
I lean more toward “support + ID if your account is established, new account if it is not” instead of trying to brute force support for everyone.
So your decision tree is basically:
- If you are 18+ and this account matters: push support carefully with ID, then wait
- If you are 18+ and this account is small: new account with correct DOB, maybe still send one normal ticket on the old one
- If you are under 18: even a fixed DOB will not give you full adult features, so adjust expectations instead of hunting for secret settings
Alternative, simpler path: file a privacy rights correction.
- Open Settings and privacy. Tap Report a problem. Search privacy rights. Open the Privacy Center link.
- Pick Correct my personal info.
- Enter your accout email and @username. State the wrong DOB and the correct DOB.
- Upload a government ID and a matching selfie.
- Submit.
Most regions require companies to fix inaccurate data. This route skips normal support queues. Many users report replies in 7 to 14 days. If approved, your age updates across the accout. Keep screenshots and the request ID.
