I used an AI detector on something I wrote myself, and it flagged parts of it as AI-generated. Now I’m confused about how AI detectors work, what they actually look for, and why they can misidentify human writing. I need help understanding AI detection accuracy, false positives, and what to do if original content gets flagged.
AI detectors look for patterns, not truth.
Most of them score text based on things like predictability, sentence structure, word choice, and how ‘smooth’ the writing feels. AI text often has low randomness. It tends to pick common phrasing and clean grammar. Humans do this too, esp if they write clearly, formally, or follow a standard essay style. So your own work gets flagged.
A lot of detectors use ideas like perplexity and burstiness. Low perplexity means the next word was easy to predict. Low burstiness means the sentence lengths and structure stay too even. If your writing is organized and polished, detector tools sometiems read it as machine-made.
They also make false positives. A lot. Schools and workplaces keep learning this the hard way. These tools are weak evidence, not proof.
What to do:
- Keep drafts and revision history.
- Save outlines and notes.
- Use Google Docs or Word version history.
- If challenged, show your process.
So, no, a detector flag does not mean you cheated. It means the tool made a guess. Sometimes a bad one.
Yeah, detector scores get treated way too seriously. @sternenwanderer is right that they’re pattern matchers, but I’d push it a bit further: some of them are basically doing authorship triage, not actual AI detection. They compare your text against features they associate with machine output, then spit out a confidence score that sounds more certain than it really is.
What they often notice besides “smoothness” is stuff like:
- low variation in punctuation
- repeated transition habits
- very balanced paragraph lengths
- generic topic sentences
- lack of weird little human detours
Problem is, tons of real people write like that. Especially students, non-native writers, technical people, or anyone trying to sound formal. Ironically, if you write messy and idiosyncratic, you may look more human. Kinda dumb, but thats how it goes.
Also, detectors can get biased by context. Short passages are easier to misread. Edited text gets flagged more. Even grammar-checker suggestions can make human writing look “AI-ish.” So if you polished your draft a lot, that alone can trip it.
My honest take: these tools are better at saying “this sounds generic” than “a machine wrote this.” Big difference. If someone uses a detector as proof, they’re overselling junk science a bit. Not total nonsense, but nowhere near courtroom-level evidence either.
Short version: AI detectors do not “know” who wrote something. They estimate how statistically similar your text is to patterns seen in AI output.
A piece you wrote yourself can get flagged because detectors often react to things like:
- predictable sentence rhythm
- uniform vocabulary level
- clean grammar
- low surprise or low specificity
- school-essay structure
I slightly disagree with @sternenwanderer on one point: it is not only about generic writing. Some detectors also rely on token probability patterns, meaning they check whether your wording looks too “expected” compared with how humans usually vary. That sounds fancy, but it still breaks a lot in real use.
Why false positives happen:
- You wrote formally.
- You revised heavily.
- You used grammar tools.
- The sample was too short.
- You write in a second language.
- The detector was trained badly.
Pros for the ‘’: fast screening, easy to use.
Cons for the ‘’: unreliable certainty, weak as proof, lots of false positives.
Best way to read a detector score: as a rough warning flag, not a verdict.
