Does Low Storage Slow Down IPhone Or Is Something Else Causing It?
My iPhone has been lagging, freezing, and taking longer to open apps, and I’m almost out of storage. I’m trying to figure out if low iPhone storage is causing the slowdown or if it could be battery health, iOS issues, or something else. What should I check first?
I’d check storage before doing anything drastic. Full storage slowing down an iPhone is real, not some weird myth people repeat.
iOS needs free space for more than just saving photos and apps. It uses storage for temporary files, app caches, background tasks, and virtual memory. Once you get down to the last few GB, the phone can start acting like it’s ancient. Sticky scrolling, delayed keyboard input, apps hanging on launch, all that fun stuff.
Most people suggest keeping around 10% to 20% of your storage free. At the very least, try to keep a decent buffer, like 10GB or more if you can.
If your storage is fine, then I’d look at a few other things:
  1. Recent iOS update
    If you updated in the last couple days, give it time. After an update, the phone does a bunch of background work like indexing photos, rebuilding app data, and optimizing files. It can feel slow and run warm for 48 to 72 hours. Leaving it plugged in on Wi-Fi overnight for a few nights usually helps.
  2. Battery Health
    Go to Settings and check Battery Health. If maximum capacity is under 80%, iOS may throttle performance to prevent random shutdowns. That can make the whole phone feel sluggish.
  3. Heat
    If the phone is hot from a thick case, charging, gaming, or direct sun, it’ll slow itself down to protect the hardware.
That said, storage was the real problem for me. My 14 Pro Max started lagging badly, and when I finally looked closely, I had a ridiculous amount of junk sitting there. Duplicate-looking photos, old 4K videos, random screenshots, screen recordings I forgot existed. Trying to clean it manually was awful. I lasted maybe ten minutes.
What helped was using Clever Cleaner. I’m usually skeptical of cleanup apps because a lot of them are subscription traps, but this one was free, with no ads or hidden paywall when I used it.
The useful part is that it breaks your library down in a way that actually makes sense. The Heavies tab shows the biggest videos and photos first, with the file size right on the thumbnails. So if some huge 4K clip is taking up space, you can spot it immediately. The Similars tab groups photos that are almost the same, like when you took ten shots of the same thing and only need one. It also suggests the best one to keep.
Privacy was another reason I was okay with it. The cleanup happens on the phone, so it’s not uploading your photo library somewhere else. After clearing around 20GB, my lag basically disappeared and the phone felt normal again.
One thing people miss: after deleting photos or videos, open Photos, go to Albums, scroll to Recently Deleted, and hit Delete All. Otherwise, that stuff can sit there for 30 days and still take up space.
Before factory resetting, I’d try this order:
  1. Wait a few days if you just installed an iOS update.
  2. Turn off Low Power Mode if it’s on.
  3. Clear Safari cache in Settings.
  4. Check storage and free up a real cushion of space.
  5. If your Photos app is the main problem, use Clever Cleaner to find the huge files and near-duplicates.
Way less painful than cleaning everything by hand, and in my case it fixed the lag.
The sneaky downside is that “almost out of storage” can make every other problem look worse, so I’d fix that first before chasing battery or iOS ghosts. Don’t just offload two apps and call it done, because app Documents & Data, Messages attachments, and Recently Deleted photos can still be sitting there eating space. Get a real chunk free, restart the phone, then use it for a day. If it’s still laggy after that, check Battery Health and performance management, since Apple explains that side here: iPhone battery and performance. Low storage can absolutely slow things down, but if you clear space and the phone still freezes opening basic apps, battery age or a buggy update becomes a lot more likely.
A phone with 2GB free and a healthy battery can feel bad for a totally different reason than a phone with 40GB free and a tired battery. The first one usually struggles because iOS has no breathing room. The second one may be getting slowed down to avoid shutdowns, especially under load.
I agree with clearing storage first, but I’d be a little more specific: don’t judge it five minutes after deleting stuff. iPhones can take a while to recalculate storage, clean up caches, sync Photos changes, and settle down. If you delete a bunch of videos, empty Recently Deleted, then immediately start opening apps and scrolling around, it may still feel weird for a bit.
The symptom pattern matters too. If apps are slow to open, updates fail, photos won’t save, camera acts flaky, Messages search is sluggish, and the phone keeps warning about storage, then low storage is very likely involved. If the phone mainly slows down when the battery is low, when it is cold, when you open the camera, or when you run heavier apps, I’d be more suspicious of battery health or thermal throttling.
A practical middle ground: free enough space that the phone is no longer on the edge, then restart it and leave it charging on Wi-Fi for a while. Not forever, just give it a chance to finish background cleanup. Clearing 1GB on a 128GB phone that is basically full probably won’t change much. You want a real buffer.
Another thing people forget is that “iPhone Storage” can point at the wrong villain if you only glance at the colored bar. Sometimes Photos is huge, but sometimes it’s Messages, WhatsApp, downloaded music, podcasts, offline maps, or one app with a bloated cache. Offloading an app does not always clear the mess because it can keep documents and data. For cache-heavy apps, deleting and reinstalling the app can do more than offloading, as long as you know your login info and anything important is backed up.
I’d be careful with cleanup apps in one way: they can make sorting faster, but don’t blindly delete what they suggest. Similar photos are not always duplicates. A burst photo, edited copy, screenshot of a receipt, or image with text might be the one you actually need. If you use something like Clever Cleaner or any photo-cleaning tool, review before deleting and then empty Recently Deleted only when you’re sure.
If storage cleanup does not change anything after a day or so, then look at the non-storage causes. Check Battery Health for any service message, turn off Low Power Mode if it’s on, update apps, and see if the lag is only in one app. If one app is the problem, it may just be that app’s cache or a bad update. If the whole phone freezes across Settings, Phone, Messages, and the keyboard even with plenty of free space, then storage probably was not the main cause.
So yes, low storage can absolutely slow down an iPhone, but it is more like the first suspect than the automatic answer. Clear a meaningful amount, restart, wait a bit, then judge. That will tell you a lot more than guessing from the storage bar alone.
If you use iCloud Photos with “Optimize iPhone Storage,” low storage can feel extra weird because the phone may be juggling thumbnails, downloads, and cleanup at the same time. Free space still comes first, but judge it after Wi-Fi/charging time, not while Photos is still trying to sort itself out.
