Custom Keyboards: Passion Hobby Or Expensive Nonsense?
I started looking into custom keyboards after seeing so many people rave about them, but once I added up the cost of switches, keycaps, and parts, it felt hard to justify. I’m trying to figure out whether custom mechanical keyboards are actually worth the money for typing, gaming, and comfort, or if this hobby is mostly expensive hype. I’d really appreciate advice from anyone who’s been through it.
Custom keyboards are a hobby. If you want the blunt answer, they are a bad value if your goal is pure function.
A solid prebuilt in the $80 to $150 range gives you 85 to 95 percent of the typing feel most people talk about. Keychron, Monsgeek, Akko, Aula, even some Epomaker boards do this fine. You get hot swap, decent stabs, foam, wireless on some models, and you type on it the same day.
Custom starts making sense when you care about specific stuff:
Layout. Split, 65, Alice, ortho.
Sound. Thock, clack, muted, deep.
Feel. Light linear, heavy tactile, long pole, silent.
Looks. Colors, case material, desk setup.
The money adds up fast. Typical midrange build:
Case and PCB, $120 to $250.
Switches, $25 to $70.
Keycaps, $40 to $120.
Stabs, lube, film, tools, $30 to $80.
Now you are at $215 on the low end and $500+ fast. If you chase group buys or rare caps, lol, it gets dumb real fast.
My take:
If you want a better keyboard, buy a good prebuilt.
If you want a hobby, build one.
If spending $300 on sound and feel bugs you now, it will bug you later too. Thats the main filter.
It’s both, honestly.
I mostly agree with @sognonotturno, but I think people undersell one thing: customs are not always about chasing some mystical “endgame” sound. Sometimes it’s just about getting exactly what you want without compromises. Prebuilts are way better now, yeah, but they still tend to be “pretty good at everything” instead of “perfect at one thing.”
If your question is value for money, then no, custom keyboards are not rational. A $300 board does not type 3x better than a $100 board. Not even close. The gains get tiny fast. That part is very real.
But if your question is whether the hobby is nonsense, also no. People spend money on watches, sneakers, headphones, guitars, coffee gear, all kinds of stuff that goes past basic function. Same deal here. Typing is just the excuse.
Where I kinda disagree with the usual take is this idea that you either buy a prebuilt or dive headfirst into a full custom. There’s a middle ground. Grab a decent hotswap board, try a few switch packs, maybe replace keycaps later. That gets you most of the “custom” fun without instantly lighting $400 on fire lol.
So my answer:
  • need a better keyboard: buy prebuilt
  • want to tinker: go semi-custom
  • want collecting/aesthetic/sound obsession: welcome to the money pit
If the prices already make you wince, your gut is probly telling you something.
Hot take: custom keyboards make the most sense if you type a lot, not if you just want “better value.”
That’s where I slightly differ from @sognonotturno. People often frame this as luxury first, function second. I think for some users, ergonomics, layout, key feel, noise level, and repairability actually are practical benefits. A board with the right switches and layout can genuinely reduce fatigue and annoyance if you’re at a desk all day.
Still, the economics are brutal. Past a certain point, you’re buying preference, not performance.
Pros for custom keyboards:
  • exact switch feel you want
  • better case/build options
  • easier to repair or change parts
  • stronger sense of ownership
  • can target sound, size, and aesthetics very precisely
Cons for custom keyboards:
  • expensive fast
  • lots of trial and error
  • resale can be hit or miss
  • hype drives bad purchases
  • “upgrades” often bring tiny real-world gains
My honest cutoff is this:
  • If you want reliability and no fuss, skip customs.
  • If you enjoy tinkering as much as typing, they’re worth it.
  • If you’re chasing internet sound tests, dangerous hobby.
The sweet spot is not “cheap prebuilt vs $400 artisan shrine.” It’s buying only when you can name the problem you’re solving. If you can’t, it’s probably expensive nonsense.
