I used an AI resume review tool to improve my resume, but I’m not sure if the feedback actually makes my resume better for real recruiters. Some suggestions seem generic and others conflict with advice I’ve seen online. Can anyone explain how to tell if AI resume feedback is reliable and what changes are really worth making for ATS and hiring managers?
Short answer. Treat AI resume feedback as a draft, not as truth.
Some practical checks you can run:
Compare to real job posts
- Take 3 to 5 postings you want.
- Highlight skills, tools, verbs, and nouns they repeat.
- Check if your resume uses those same terms in normal sentences.
- If AI told you to add buzzwords that do not show up in postings, ignore those.
Look for keyword stuffing
- If your resume reads like: “Results driven, detail oriented, innovative leader…” cut most of that.
- Keep specific bullets like “Increased email CTR from 12% to 19% in 3 months using A/B tests.”
- If a sentence would make you roll your eyes as a recruiter, delete or rewrite it.
Conflicting advice on length and format
- Under ~7–10 years experience, stick to 1 page.
- Over that, 2 pages is fine if all content earns its place.
- Avoid fancy templates, text boxes, columns that break ATS parsing.
- Simple layout, clear section headings, standard fonts.
Test the AI suggestions with this rule
For each AI change, ask:- Is this more specific than what I had before.
- Is it easier to scan.
- Does it show impact with numbers, scale, or scope.
If the answer is no, revert it.
Recruiter reality check
If you know any recruiter or hiring manager, send:- Your old resume.
- The AI edited one.
- Ask which they would call from and why.
Even one honest review is more useful than generic tool tips.
Quick self review checklist
- Each job has 3–7 bullets.
- Bullets start with strong verbs (built, led, improved, reduced, shipped, deployed).
- At least half of bullets have numbers. Revenue, time saved, error rate, users, volume.
- No paragraphs longer than 2 lines.
- No “responsible for” at the start of bullets.
When to ignore AI feedback
- It pushes you to exaggerate or lie.
- It suggests achievements you do not have, like “industry leading” with no proof.
- It tries to make every role sound like leadership when you were not leading anyone.
- It rewrites in awkward “AI voice” with too many adjectives.
If you want a more concrete check, post a redacted version of:
- One original bullet.
- The AI revised version.
- The role and target job.
People here tend to give sharper, job specific feedback than tools.
You’re running into the exact limit of AI resume tools: they’re great at generating “resume-shaped text,” not at making you more hireable.
@nachtdromer already covered the tactical stuff nicely, so I’ll come at it from a different angle: how to audit the quality of the AI’s feedback itself.
1. Figure out what “job” you’re hiring the AI for
AI tools try to do 5 different jobs at once:
- Fix grammar and spelling
- Rephrase bullets to sound more “professional”
- Suggest content to add
- Suggest content to remove
- Recommend layout / structure
They are usually decent at 1 and parts of 2, mediocre at 3 and 4, and often useless or harmful at 5.
So, go through the AI feedback and literally label it:
- G = grammar / clarity
- R = rephrasing only
- C+ = add new content
- C− = remove content
- L = layout / structure
Keep:
- G and R that keep your voice and accuracy
- C+ only if you actually did what it claims and forgot to mention it
- C− only if it removes fluff you agree is useless
- L only if it simplifies, not beautifies
If it’s inventing “strategic initiatives” you never led or recommending a 3–column Canva template, bin it.
2. Use a “difference test” with real humans, not theory
You’re worried whether recruiters like it. Don’t guess. Run a simple A/B:
- Create two versions: your original and the AI-edited
- Ask 3 people who have hired anyone before, not just recruiters
- Question is not “which looks better?”
- Question is: “Which of these resumes makes you more confident this person can do [target job] and why?”
Patterns to watch:
- If they say AI version is “slicker but vaguer,” you lost.
- If they say your original is “messier but more concrete,” you know what to fix: clarity, not content.
- If they consistently pick the AI version but complain about “generic wording,” keep the structure and re-edit the language yourself.
Don’t get bogged down in internet advice fights. Let actual reactions decide.
3. Check whether AI feedback helps decisions, not aesthetics
Ignore anything that only improves vibe. Keep what improves decision-making for the reader.
Ask for each AI change:
“Does this make it easier to answer yes/no to:
- Can this person do [core skill 1]?
- Have they done it at similar scale?
- Have they improved something measurable?”
If a new sentence just “sounds better” but doesn’t change those answers, it’s decorative. Decorative text burns space and attention.
Example:
- Before: “Reduced cloud spend by 18% by consolidating underutilized instances.”
- After AI: “Proactively optimized cloud infrastructure, driving significant cost efficiencies.”
The second one sounds fancier and is strictly worse for decisions. Put the numbers back.
4. When conflicting advice appears, use context rules
You mentioned conflicting advice you’ve seen online. Some of that is because:
- ATS advice is often recycled from 2010
- Different industries / seniorities play by different norms
Quick context filters to decide:
- Tech, product, data, design: impact and portfolio / GitHub / links matter more than hyper-optimized keywords.
- Consulting / finance: wording polish and structure get more weight, but they still hate fluff.
- Early career: AI tools tend to overinflate; cut anything that sounds like executive leadership if you were an intern.
If AI feedback sounds like “generic ATS optimization” but your target roles are in smaller companies or startups, you can safely ignore a lot of the keyword theater.
5. Use AI as a sparring partner, not the writer
One trick that works well:
- Paste one of your own bullets and say:
“Give me 3 alternative phrasings of this bullet. Do not add responsibilities I did not mention. Keep all numbers.”
Then:
- Steal phrases you like
- Merge with your original
- Throw out the rest
You’re leveraging AI’s ability to remix language without letting it hijack your narrative.
If you just click “apply all suggestions,” you end up with “AI voice” and a resume that sounds like 10k others.
6. A sanity test to see if AI hurt your resume
Read your new resume and ask yourself:
- Could I comfortably defend every line in a detailed interview?
- Would I actually talk like this out loud? Or would I be embarrassed?
- Did I lose any specific numbers, tools, or examples I used to have?
- Do 2–3 bullets now sound like they could belong to almost anyone in your field?
If you answer yes to 2 or 4, the AI pushed you into generic territory. Reintroduce your specifics from the old version.
7. Where I slightly disagree with @nachtdromer
They say to ignore buzzwords not in job postings. Mostly agree, but with a nuance: some higher-level competencies (stakeholder management, cross functional collaboration, ownership) may not be repeated as keywords but do matter, especially for mid-senior roles.
So:
- Don’t stuff your resume with those words,
- But a couple of well-placed bullets that demonstrate them is smarter than only mirroring the posting.
Example: instead of adding “stakeholder management” as a bare keyword, keep a bullet like:
“Aligned 4 stakeholder teams on quarterly roadmap, reducing conflicting priorities and cutting rework by 30%.”
AI tools often miss that middle ground and either remove these concepts or pump them full of hot air.
If you want a reality check on whether the AI made things better, post:
- One original section (e.g., your last role)
- The AI-edited version of that same section
- The job type you’re targeting
People here can usually spot in 30 seconds whether the tool helped, hurt, or just put lipstick on it.
You’re bumping into the core issue: AI tools are optimizing for “sounds like a resume,” not “gets you interviews.”
@nachtdromer covered how to cleanly triage the AI feedback. I’ll zoom out and look at when AI feedback is actually useful vs when it quietly sabotages you, plus how to sanity check your strategy, not just wording.
1. Start from the funnel, not the resume
Before judging the AI’s edits, look at your actual metrics:
- Are you getting 0 callbacks? You might have a targeting or experience problem, not just a resume problem.
- Are you getting screening calls but no interviews? Then clarity and impact may be the issue.
- Are you getting interviews but no offers? Resume is probably good enough; AI tweaking here is marginal.
If your funnel is broken at the top, then AI “polish” is lipstick. In that case, focus on:
- Aligning your past experience to the roles you’re applying for
- Making sure your resume actually matches the seniority and tech stack in job posts
- Networking and referrals, which no resume bot can fix
Only once that is reasonably aligned does it make sense to obsess over AI edits.
2. Check if AI accidentally downgraded your level
This is one thing I see AI tools mess up constantly.
Common pattern:
- Original: “Led a team of 4 engineers to deliver X ahead of schedule.”
- AI edit: “Collaborated with engineers to deliver X.”
You just went from lead / senior profile to “generic IC who helped out.” That is worse for real recruiters, even if it sounds smoother.
To catch this:
- Highlight every mention of ownership: “owned,” “led,” “was responsible for,” “reported directly to,” “drove,” “defined,” “designed.”
- Compare old vs AI version.
- If leadership / ownership verbs disappeared or got softened, revert them.
Here I slightly disagree with people who say “focus mostly on impact.” For mid and senior roles, scope and ownership are often more important than pure metrics. AI tends to flatten those out.
3. Look for “AI fingerprints” that annoy humans
Some recruiters are actively wary of AI-written resumes. Not because it is cheating, but because it signals lack of judgment.
Red flags that scream “AI did this”:
- Overloaded buzz strings like “results-driven, detail-oriented professional with a proven track record of success” in your summary.
- Every bullet starts with a different fancy verb and ends with vague impact words.
- Entire sections talk about “strategic vision” and “transformational initiatives” for entry-level or junior roles.
If your updated version reads like a corporate blog post instead of something a human in your role would naturally say, scale it back. Keep the structure, re-inject your own more direct phrasing.
4. Compare depth vs surface: a quick “substance balance” test
Pick one job on your resume and do this:
- Count how many bullets are about actual work: built X, shipped Y, reduced Z, handled specific volume, tools used.
- Count how many are about vibes: “collaborated,” “supported business goals,” “drove innovation,” etc.
If after AI edits the “vibe” bullets increased and the concrete work bullets decreased or became vaguer, quality went down.
Your goal is not a prettier surface. It is more signal:
What you did, how big it was, what changed, and what level of ownership you had.
5. Resolve conflicting online advice with a “who is the decider?” rule
You mentioned you see recommendations that contradict what AI says. Instead of fighting theory vs theory, pick who matters most for your target roles:
- Enterprise / Fortune 500: likely a recruiter + ATS + hiring manager.
- Small startup: mostly hiring manager, sometimes founder.
- Academia / research: PI or committee, almost no ATS.
- Government: keyword-heavy, but with strict format rules.
Then:
- If your primary decider is a hiring manager in a technical role, prioritize clarity, specifics, and relevant projects. Ignore anything that sounds like it was written to make ATS bots happy but makes humans roll their eyes.
- If your primary decider is a high-volume recruiter, some keyword tuning and role titles aligned to the market matter more, and AI can help suggest those.
This is where I part a bit from the “ignore ATS myths” school. For some environments (large, process-heavy organizations), mirroring the language of their postings does change who even sees your resume. Just do not let it replace clarity.
6. Use AI for “translation,” not “fiction”
The safest and highest ROI way to use an AI resume tool is as a translator between:
- What you actually did
- The way your target jobs describe that work
You can prompt or configure it more narrowly:
- “Rephrase this bullet to better match a data analyst role in e‑commerce, but keep numbers, tools and seniority level the same.”
- “Shorten this bullet by 20 percent, keep the metric and remove fluff words like ‘successfully’ and ‘proactively’.”
You are telling it how to help you. Blindly accepting generic “you should show more leadership” style suggestions encourages the tool to fabricate or exaggerate.
Litmus test: if a suggestion would require you to lie or seriously stretch the truth in an interview, it is bad feedback, even if it sounds impressive.
7. Spot conflict: when AI and experienced humans disagree
If the AI tells you one thing and experienced people (like hiring managers in your field) tell you another, default to the humans.
Simplest way to test:
- Take 3 AI-edited bullets you are unsure about.
- Show them and your original versions to someone who has done hiring for similar roles.
- Ask which ones better help them decide if you are a fit and why.
If the human consistently prefers your version or a hybrid, you have a quantitative signal that the AI is optimizing the wrong objective (usually style over clarity).
8. About “”: pros & cons in this context
Since you mentioned using an AI resume review tool, here is how a product like ‘’ typically plays in:
- Fast grammar and spelling cleanup across the entire document.
- Can surface missing obvious keywords when you paste in a job description.
- Good at catching repetitive wording and suggesting varied phrasing.
- Useful for people who struggle to write about themselves at all.
- Tends to normalize resumes toward one bland corporate voice, which reduces memorability.
- May overemphasize ATS-style changes that do little in real-world hiring.
- Can quietly strip out signs of seniority, ownership, and technical depth.
- Feedback can be confidently wrong on layout norms in your specific industry.
So it is a decent assistant for editing, not a reliable authority on what actually gets you hired.
Compared with someone like @nachtdromer, a tool such as ‘’ has scale and speed, but no lived hiring context. @nachtdromer can be wrong in spots too, but at least their advice reflects reality in some subset of markets, not a generic average.
If you want a more grounded verdict on whether the AI helped or hurt, post a single “before vs after” section and specify the target role and level. People can usually tell very quickly if the tool just made it shinier or if it actually sharpened your story.
