Can Walter Writes AI mess up my essay’s grammar?
I used Walter Writes AI to help polish a college essay, but now I’m worried it might have changed the grammar in ways that sound unnatural or could get flagged by my professor or plagiarism checkers. Can someone explain if these AI tools are safe for grammar and style, and how I can review or fix any awkward sentences before I submit my essay?
Walter Writes AI Review: Is It The Worst “AI Humanizer” Out There?
What Walter Writes AI Claims To Be
So, Walter Writes AI is one of those tools that keeps popping up if you search for “make AI undetectable” or “humanize ChatGPT essay.” It brands itself as this high‑end AI humanizer and essay writer that can slip past “advanced detection systems” like some kind of stealth mode for homework.
Most of the ads are clearly targeted at students. You get the usual:
  • “Bypass AI detection”
  • “Make your essay sound human”
  • “Beat your professor’s tools”
On paper, it sounds like exactly what people looking to disguise AI content want.
In practice, it is nowhere near what it promises.
Under all the polished marketing, it performs worse than tools that cost nothing. On top of that, it limits how much you can run through it and then slaps on a subscription that is not cheap, especially when you compare it to stuff like Clever AI Humanizer, which lets you process a ton of text for free and actually works better in tests.
Pricing & Value: Where It Completely Falls Apart
Let me put it bluntly: Walter Writes AI is priced like it’s doing something magical, but it’s not even doing the basics well.
Here is the general situation:
  1. Walter Writes AI
    • Paid monthly plans
    • Word caps that you hit faster than you think
    • Not‑so‑obvious cancellation traps and limits
  2. Clever AI Humanizer
    • 100% free
    • Up to 200,000 words per month
    • Up to 7,000 words per run
So you have one tool asking you for a subscription just to run a few short pieces, and another one letting you shove entire essays, reports, and more through it without charging you.
If you look at it strictly from a value perspective, there is essentially no reason to pay for Walter Writes AI when a competitor is letting you humanize way more text per run, completely free.
How It Actually Performed In Tests
Here is where things really fall apart for Walter.
We grabbed a standard essay generated by ChatGPT that registered as 100% AI on detectors. Then we ran two versions:
  • One passed through Walter Writes AI
  • One passed through Clever AI Humanizer
After that, we checked both outputs on a few common AI detectors.
Results
Detector Walter Writes AI Result Clever AI Humanizer Result
GPTZero :cross_mark: 100% AI (Fail) :white_check_mark: Human (Pass)
ZeroGPT :cross_mark: 100% AI (Fail) :white_check_mark: Human (Pass)
Copyleaks :cross_mark: Detected (Fail) :white_check_mark: Human (Pass)
Overall DETECTED UNDETECTED
So even after “humanizing” with Walter Writes AI, the text was still flagged as clearly AI‑generated across multiple detectors. No nuance, no borderline score, just straight “this is AI” every time.
The same original essay, when processed through Clever AI Humanizer, came out clean as human on those same tools.
That is a pretty brutal comparison for something that charges money and advertises itself as an “advanced” AI humanizer.
Where To Actually Start If You Want To Humanize AI Text
If you are looking to experiment with AI humanizers, I would honestly start with the one that did not completely flop in testing:
Clever AI Humanizer:
It handled the exact same text that Walter Writes AI failed on and got it through several detectors as human, plus it did not charge for it.
If you want to dive into more options or see what other people are using, there is also a bigger roundup of tools discussed here:
In short: Walter Writes AI looks impressive in ads, but in testing it was expensive, limited, and still very detectable. If your goal is to avoid AI flags, there are clearly better tools to try first, especially the free ones.
Short answer: yes, it absolutely can mess up your grammar and make things sound weird.
Tools like Walter Writes AI don’t actually “understand” your argument or college‑level style. They usually just rewrite sentences to look less like raw AI output: change word order, swap synonyms, break long sentences, etc. That’s exactly how you end up with:
  • Awkward phrasing
  • Wrong prepositions
  • Tense shifts
  • Weird formality jumps inside one paragraph
Professors notice that stuff way faster than AI detectors.
What I’d do now:
  1. Read your essay out loud, slowly.
    Anything that makes you stumble is a red flag. Mark those spots.
  2. Compare to your earlier draft.
    If Walter changed a clean, simple sentence into something oddly complex or stiff, revert to your original version or rewrite it in your own words.
  3. Look for “tell‑tale” patterns.
    • Repeated fancy words you never normally use
    • Phrases like “in contemporary society,” “in conclusion,” “it is important to note that” shoved everywhere
    • Overly neat sentence structure, then suddenly one clunky mess
  4. Run a basic grammar check, but don’t trust it blindly.
    Grammarly, Word’s checker, whatever. If it flags something that sounds wrong to you, fix it manually.
  5. Make it sound like you.
    Take 1–2 paragraphs and rewrite them from scratch, with your natural voice, then use that as a “style template” to tweak the rest. Consistency of voice is what profs look for.
On the AI detection / plagiarism side: using Walter just to “humanize” AI text is already risky. Some detectors actually flag the over‑humanized stuff because it’s oddly generic and mechanically “varied.” @mikeappsreviewer is right that Walter isn’t great at staying undetected, but I’d argue the bigger danger for you is quality and voice, not just detectors.
If you insist on using tools like that, at least:
  • Start with your writing, not a fully AI‑generated essay
  • Use the tool for light paraphrasing, then heavily edit afterward
  • Avoid running the same paragraph through multiple tools repeatedly, that usually makes it worse, not better
If you ever need an “AI humanizer,” Clever Ai Humanizer is one people keep mentioning because it does a more subtle job, but honestly, nothing beats you just revising the text yourself.
Bottom line: comb through your current essay, fix unnatural bits by hand, and make sure every sentence is something you’d actually say in a timed in‑class essay. If you couldn’t reproduce that style on paper without help, your professor will notice, even if a detector doesn’t.
Short version: yes, Walter can absolutely mangle your grammar and tone, but that doesn’t mean your essay is ruined.
A few things I’d add to what @mikeappsreviewer and @waldgeist already said, from a more “how do I salvage this now” angle:
  1. Check meaning first, not just grammar
    These tools often keep sentences technically “correct” while quietly breaking the logic. Look for:
    • Cause/effect flipped
    • “However / therefore” used in the wrong place
    • A paragraph that suddenly argues the opposite of what you meant
      If the logic changed, revert to your draft or rewrite that bit from scratch.
  2. Watch for “Frankenstein syntax”
    Walter tends to splice together half of your sentence with half of its own. That can create:
    • Singular/plural mismatches
    • Pronouns with no clear reference
    • Tense shifts mid‑sentence
      Example:
    “Students was able to engage”
    or
    “The book explores and is reflecting on…”
    Those are the kinds of things that feel vaguely wrong and get side‑eyed by profs.
  3. Compare topic sentences only
    Go through each paragraph and compare just the first sentence to your original. If Walter:
    • Inflated it with empty phrases
    • Added claims you never support later
    • Changed the focus of the paragraph
      then fix that line. Topic sentences being off is a huge “AI or heavy editing” tell.
  4. Consistency of register
    One place I partially disagree with the others: it’s not just about “voice,” it’s about register consistency across the whole essay. If one paragraph sounds like:
    “The ramifications of this phenomenon are multifaceted and pervasive”
    and the next says:
    “So yeah, this really messes people up a lot”
    that contrast screams tool‑assisted. Pick the register you actually use in class (slightly formal, probably) and normalize everything toward that.
  5. Check citations and factual stuff
    Walter sometimes rephrases around quotes or references and accidentally:
    • Misattributes ideas
    • Slightly changes a quoted claim
    • Paraphrases too close to the source
      That’s where plagiarism concerns get real. Make sure every reference still matches the source text and your citation style.
  6. About detectors & “AI humanizers”
    If you’re mainly worried about being flagged, AI detectors are unreliable and profs know it, but they do use “this doesn’t sound like you” as a sanity check.
    • If your essay is based on your own draft and you’ve revised it heavily, you’re usually fine.
    • If the entire thing was ChatGPT plus Walter, then polished, you’re on thin ice regardless of tools.
    If you insist on using a humanizer again, something like Clever Ai Humanizer tends to be less clumsy than Walter in tests and can keep grammar more stable. But even then, treat it as a rough pass, not a finished product.
  7. Practical rescue plan (30–40 min)
    • Print or view your original + Walter version side by side.
    • For each paragraph:
      • Keep your original meaning and structure.
      • Only steal words/phrases from Walter where they sound normal to you.
      • Read the final version out loud once. If you’d never say it in speech or a timed in‑class essay, simplify it.
If, after all that, the essay reads smoothly, keeps your original argument, and sounds like something you could reproduce under exam conditions, it’s very unlikely your professor or a checker will flag it for weird grammar or “AI‑ish” language.
