Can someone walk me through how to set up a VPN at home?
I’m trying to set up a VPN on my home network for secure browsing and remote access, but I’m confused by all the different protocols, apps, and router settings. I’ve tried following a few online guides, but I keep getting errors and I’m not sure what I’m doing wrong. Can someone explain, step by step, how to properly configure a VPN for personal use, including any security best practices and common pitfalls to avoid?
Short version. You have two different goals that often get mixed up:
  1. Secure your browsing on the internet
  2. Remote access to your home network from outside
You handle them slightly differently.
Step 1: Decide what you want
If you want only secure browsing on public WiFi
Use a commercial VPN service on each device. No home router setup needed.
If you want remote access to your home network
You set up a VPN server at home and connect to it from outside.
You can do both, but keep them separate in your head.
Step 2: Pick the tech
For a home VPN server, today the usual options are:
• WireGuard
– Fast, simple config, modern crypto
– Many good mobile and desktop apps
– Supported by some routers (Ubiquiti, MikroTik, some Asus, etc)
• OpenVPN
– Older, more knobs, more guides online
– Slower than WireGuard on weak hardware
– Also supported by lots of routers
If you feel lost, start with WireGuard.
Step 3: Check your hardware
Option A: Router with VPN server support
Log in to router admin page
Look for “VPN server” or “WireGuard” or “OpenVPN” in menus
If it has a WireGuard or OpenVPN server option, use that.
Follow vendor guide, not random blogs.
Search “ WireGuard server” or “ OpenVPN server”.
Option B: Use a small always-on box
Examples: Raspberry Pi, Intel NUC, old PC that stays on
Install something like:
• OpenWrt as router plus VPN
• PiVPN (script that sets up WireGuard or OpenVPN) on Raspberry Pi
• Full firewall distro like OPNsense or pfSense on a small PC
For beginners, Pi + PiVPN + WireGuard is usually the least painful.
Step 4: Deal with your public IP and port
This trips people up a lot.
  1. You need your home IP to be reachable from the internet.
    Check on any browser: search “what is my IP”.
    Write it down.
  2. If your ISP changes your IP sometimes, use Dynamic DNS
    Many routers have Dynamic DNS built in
    Set up something like no-ip or DuckDNS
    Then you connect to “yourname.duckdns.org” instead of raw IP
  3. Port forwarding on your router
    For WireGuard default is UDP 51820
    For OpenVPN default is UDP 1194
On your router
• Go to Port Forwarding / NAT
• Forward UDP 51820 from WAN to your VPN server internal IP (for WireGuard)
Example: WAN UDP 51820 → 192.168.1.10 UDP 51820
If you have double NAT (modem + router both doing routing)
You need the forward on both, or set modem to bridge mode.
If you see two private IP ranges in a row, this might be your problem.
Step 5: WireGuard basic setup example (PiVPN style)
On the server
• Install WireGuard or use PiVPN with WireGuard
• Set server to listen on port 51820
• Use a network for VPN clients, like 10.6.0.0/24
• Enable “Allow clients to access LAN” if the script offers that
You end up with:
Server config has:
• Private key
• Public key
• Endpoint: yourname.duckdns.org:51820
• AllowedIPs: 10.6.0.0/24 for peers
Client config example (phone or laptop):
[Interface]
PrivateKey =
Address = 10.6.0.2/32
DNS = 1.1.1.1
[Peer]
PublicKey =
Endpoint = yourname.duckdns.org:51820
AllowedIPs = 0.0.0.0/0
If you set AllowedIPs to 0.0.0.0/0, all your traffic goes through home.
If you only want access to home devices, you use:
AllowedIPs = 192.168.1.0/24, 10.6.0.0/24
Step 6: Test locally, then from outside
  1. Test on LAN first
    On your phone, connect to WiFi, enable VPN, see if you reach 192.168.1.1 (router page)
    If that works, basic config is fine.
  2. Test from mobile data
    Disable WiFi, keep VPN on
    See if you can ping or open your NAS or home server
    Check if your public IP from “what is my IP” matches home IP
    If not, something is off with port forwarding or ISP CGNAT.
If nothing works from outside and port forwarding looks ok
Your ISP might use CGNAT. Then you do not have a true public IP.
Ask them for a public IPv4 or use a VPN provider that offers “port forwarding” or “static IP” and host VPN there instead of at home.
Step 7: Router settings you care about
On your main router:
• Port forward for the VPN port
• Reserve a static LAN IP for your VPN server
• Disable UPnP on the VPN server machine
• DNS settings so your VPN clients resolve names properly
Often easiest is to set DNS in the VPN config, like Cloudflare 1.1.1.1 or your router IP.
Step 8: VPN apps
For WireGuard:
• Windows and macOS: WireGuard official app
• Android: WireGuard app from Play Store
• iOS: WireGuard app from App Store
You import config via QR code or file.
For OpenVPN:
• Windows/macOS: OpenVPN Connect or Tunnelblick (mac)
• Mobile: OpenVPN Connect app
If your guides fail
Post these details next time:
• Router model
• ISP type (cable, fiber, LTE)
• Whether modem is in bridge or router mode
• Which protocol you tried (WireGuard or OpenVPN)
• A redacted server and client config
• Screenshot of your port forwarding page with private info blurred
With that info people on the forum can point to the exact step that blows up.
You’re not dumb, this stuff is a mess.
@stellacadente already covered the “textbook” setup pretty well, so let me come at it from a slightly different angle and cut some corners.
1. Decide what you actually care about
Blunt version:
  • “I’m on coffee shop WiFi and don’t want creeps sniffing my traffic”
    → Use a paid VPN app on each device. Done. No home config, no router, no pain.
  • “I want to reach my home NAS / PC / media server when I’m not home”
    → You need a VPN server at home.
Trying to make one setup magically solve both can be done, but it’s what usually causes people to faceplant.
2. Easiest realistic home-setup that doesn’t suck
If your router doesn’t have a clean VPN server option (or it does but the UI is garbage), I’d skip fiddling with it and instead:
  • Get a Raspberry Pi (or any low-power box that can stay on 24/7).
  • Use PiVPN + WireGuard.
Yeah, @stellacadente mentioned this, but I’ll be a bit more opinionated:
On consumer routers, OpenVPN is often slow and clunky, and the GUI “wizards” are half baked. A Pi with PiVPN is usually smoother than playing “guess the checkbox” in your router UI.
3. The one thing people miss: your ISP might be the real problem
Before you deep-dive configs, quickly check:
  1. On a device at home, go to “what is my IP” in a browser.
  2. Then log in to your router and see what its WAN IP is.
If:
  • WAN IP on router = public IP you saw in browser → Good, you have a real public IP.
  • WAN IP is something like 10.x.x.x or 100.64.x.x or 192.168.x.x → You’re likely behind CGNAT.
If it’s CGNAT, no amount of port-forward voodoo will help. In that case you have three realistic paths:
  • Call ISP and ask for a public IPv4 (often costs a bit).
  • Use IPv6-only VPN if your devices and ISP support it (less beginner friendly).
  • Host your VPN somewhere else (cheap VPS, some providers give 2–5 bucks/month) and connect home → VPS then client → VPS.
Most guides conveniently skip “your ISP might be trolling you” so people waste hours on configs that were fine.
4. Simple mental model for WireGuard on a Pi
Ignore all the wall of text you’ve seen and think of it as:
  • Your Pi gets:
    • One regular LAN IP, like 192.168.1.50
    • One VPN IP, like 10.6.0.1
  • Your phone / laptop gets:
    • A VPN IP, like 10.6.0.2, 10.6.0.3, etc.
When you’re outside:
  • Phone tries to reach 192.168.1.100 (say your NAS).
  • Traffic is wrapped inside a WireGuard packet and sent to your home IP on UDP port 51820.
  • Pi unwraps it and forwards it to the LAN.
So the only router bits that matter are basically:
  • Static IP for the Pi on LAN (e.g. 192.168.1.50).
  • Port forwarding: UDP 51820 on WAN → 192.168.1.50 UDP 51820.
No “DMZ”, no UPnP, no 12 extra checkboxes.
5. Remote access vs “all my traffic through home”
Two WireGuard client modes that confuse everyone:
  1. Remote access only
    You only want to see your home devices, but keep normal browsing going out via your current internet.
    In client config, AllowedIPs looks like:
  2. Tunnel everything through home
    All your browsing flows through your house.
    In client config, AllowedIPs = 0.0.0.0/0, ::/0
If you’re saying “I want secure browsing on random WiFi and access to home” through the same VPN, that second option is what you’re after.
This is where I slightly disagree with @stellacadente: you can keep both goals in your head at once with a single setup, you just have to understand that AllowedIPs line is the switch.
6. Router VPN server vs dedicated box
People love the idea “my router has VPN built in, I’ll just use that.” Reality:
  • Many ISP routers with VPN features:
    • Terrible throughput.
    • Strange half-broken implementations.
    • Bad firmware updates that randomly break configs.
Using the router makes sense if:
  • It clearly supports WireGuard server,
  • Has a decent interface,
  • And you actually find a vendor guide that works.
Otherwise, a Pi or mini PC is usually less janky.
7. Stuff you should post if you’re stuck
Next time something breaks, don’t just say “it doesn’t work” and rage quit. Share:
  • Router model and whether your ISP box is in bridge mode or not.
  • Whether your router’s WAN IP is public or private.
  • Which VPN you tried (WireGuard vs OpenVPN).
  • Screenshot (sanitized) of the port forward page.
  • Redacted server & client config for one test device.
With that, people can usually point straight at the exact dumb detail causing the headache, like “your ISP is CGNATing you into oblivion” or “your AllowedIPs is wrong.”
If you reply with your router model and whether you have a Pi / spare box, folks here can probably sketch the exact minimal steps for your setup instead of another generic giant how-to.
You are getting good advice from @vrijheidsvogel and @stellacadente on how to wire things up, so I’ll zoom in on which approach to pick and some tradeoffs they skipped over.
Think of three separate designs:
1. “Everything exits at home” VPN
Goal: secure browsing on untrusted networks and see your home devices through the same tunnel.
How it works
  • You run a VPN server at home.
  • Clients use AllowedIPs = 0.0.0.0/0 (or equivalent setting in OpenVPN).
  • All internet traffic from your laptop/phone goes through home first.
  • One config on each device, brain-simple in daily use.
  • Your IP on the internet is always your home IP.
  • Ad/tracker blocking is easy to centralize (Pi‑hole / AdGuard Home behind the VPN).
  • Your home upload speed becomes the bottleneck. If your upstream is weak, browsing will feel slow.
  • If home internet goes down, you lose both remote access and “secure browsing”.
  • Slightly more complex firewall rules, because you’re effectively routing for remote clients.
This is where I mildly disagree with the “keep goals separate” angle: for a lot of people this single-tunnel design is actually easier, as long as you accept the bandwidth tradeoff.
2. “Split tunnel” remote access only
Goal: reach home gear remotely but keep normal browsing going out locally.
How it works
  • VPN server at home.
  • Clients use something like AllowedIPs = 192.168.x.0/24, <VPN subnet>.
  • Only traffic to your home LAN and the VPN subnet goes through the tunnel.
  • Streaming / big downloads use hotel / mobile network directly, so no double-hop lag.
  • Home connection only needs to handle light traffic for remote management, file access, etc.
  • Fewer weird geolocation issues, because most traffic exits wherever you are.
  • Not a “privacy” VPN in the usual sense, since normal browsing does not go via home.
  • Slightly harder to reason about at first, because “some” apps go through VPN, some do not.
If your primary use is “I want to hit my NAS / desktop / Home Assistant,” this design is usually best.
3. “No VPN at home at all”
Goal: only secure public WiFi and maybe unblock some services, no remote LAN access needed.
How it works
  • Use a reputable commercial VPN app on each device.
  • Skip any router / port forwarding / dynamic DNS work entirely.
  • Easiest path by far.
  • Provider handles IP changes, routing, peering, etc.
  • Often better speeds for general browsing than tunneling through a slow home uplink.
  • No access to your private 192.168.x.x devices unless you build a second solution for that.
  • You are trusting the provider with your exit traffic.
  • Apps per device, not “one central box” magic.
If you do later add a home VPN, you can run both: commercial VPN for casual browsing, home VPN for LAN access.
About products and tradeoffs
Since you mentioned being confused by protocols, think in terms of features instead of brand names:
  • WireGuard-type setups usually mean:
    • Fewer knobs, easier mental model.
    • Faster on weak CPUs.
  • OpenVPN-type setups often mean:
    • More legacy support and UI “wizards”.
    • More ways to misconfigure.
Some people bundle VPN plus extras like DNS filtering or firewalling into a single appliance. Those “all in one” products are convenient but have pros and cons:
Pros for that style of “one-box VPN solution”
  • Single interface for VPN, firewall, and sometimes ad blocking.
  • Often give you a nicer way to manage multiple clients and profiles.
  • Helpful if you want to add things like guest networks or parental controls later.
  • More complex initial setup than a bare WireGuard script.
  • You end up depending on that one box for routing, VPN, and filtering. Break it, lose everything.
  • Overkill if all you needed was “sometimes connect to my NAS.”
Compared to what @vrijheidsvogel and @stellacadente are describing, this kind of integrated product trades simplicity of protocol for “a lot of knobs in one place.” Their approaches are closer to building blocks; these appliances are more like a prebuilt toolkit.
What I’d actually do in your shoes
Without repeating their step‑by‑step:
  1. Decide first:
    • If you often need both “secure browsing” and “home access” from laptops/phones, lean toward the “everything exits at home” design.
    • If you mostly want your NAS / desktop while traveling, go split tunnel.
  2. Check your home uplink speed and whether you have a public IP.
    • Weak upload or CGNAT makes “everything exits at home” much less appealing.
  3. Only then pick a stack:
    • If your router has a clean WireGuard server implementation, use that.
    • If not, follow the Pi / small box path they outlined. Avoid mixing ISP router VPN with random third-party guides; that combo is where most people get stuck.
If you post your ISP type, router model, and whether you want “all traffic through home” or “just remote LAN,” someone can map that to one concrete recipe instead of you juggling protocols, apps, and menus in the abstract.
Try Tailscale. Install teh app on your laptop, phone, and one always-on home device like a Pi or NAS. No port forwarding. Works through CGNAT. Flip on MagicDNS for easy names. Set the home device as an Exit Node for secure browsing through home. Leave Exit Node off for remote LAN only. Speeds stay close to WireGuard line rate. Example, a 200 down, 20 up link gave 18 Mbps upstream through exit. Setup takes about 10 minutes. Free plan fits one user. Clear logs and ACLs help you audit who reaches what. Enable device approval for safety.
