Can I Recover Files From A Formatted Flash Drive After A Quick Format?
I accidentally quick formatted my USB flash drive before copying off important photos and work documents. The drive still shows the full size, but all the files are gone. I need help figuring out if quick format data recovery is possible and what steps I should take right away to recover files from the formatted flash drive without making it worse.
Losing files after formatting a USB drive is rough. I did this once with a flash drive full of photos, and the first thing I learned was simple, formatting does not always mean the data is gone.
What matters most is the type of format.
If you ran a Quick Format, your odds are often decent. Quick Format usually wipes the file system records, not the file data itself. The old data often sits there until something else gets written over it.
If you ran a Full Format, recovery gets a lot worse. A full format writes over the storage, so normal recovery software usually finds little or nothing.
One thing I had to sort out early, there is no real ‘unformat’ button for a USB stick. Once the format happened, it happened. Recovery apps do something else. They scan the drive, look for leftover file data, and try to rebuild files from what still exists on the device.
If you want the best shot, stop using the USB drive right now.
Do not copy anything onto it.
Do not format it again.
Do not run CHKDSK or any repair tool.
Every write lowers your chances. Old files get replaced bit by bit, and once that happens, recovery tends to fall apart.
What I would do next:
  1. Install Disk Drill on your computer’s internal drive, not on the formatted USB.
  2. Plug in the flash drive.
  3. Open Disk Drill and pick the USB from the drive list.
  4. Hit Search for Lost Data, then choose Universal Scan if it asks.
  5. Let the scan run to the end. I know it is tempting to click around early, but I got better results after waiting.
  6. Preview what it finds. If a photo opens, or a document shows readable content, or a video starts, your odds for those files are better.
  7. Recover the files to a different drive. Do not save recovered data back to the same USB.
A small thing people skip, and I would not skip it. If the flash drive keeps disconnecting, throws read errors, or feels unstable, make a byte for byte image first and scan the image instead. Disk Drill supports this. It saved me once when a cheap USB stick started dropping offline mid-scan.
Also, if recovered files come back with weird names like FILE0001 or missing folders, that is normal after formatting. The folder tree is often damaged first. What matters is whether the file itself opens.
So yeah, recovery from a formatted flash drive is often possible, mostly after a quick format. The best move is boring but important, stop touching the drive, scan it soon, and recover the results somewhere else.
Yes, after a quick format, recovery odds are often decent. The format usually clears the file table, not the photo and document data blocks. So your files might still be there.
I agree with @mikeappsreviewer on the big point, stop using the USB. I disagree a bit on full format being always hopeless. On newer Windows, full format often overwrites, so recovery rates drop hard. On some older setups, results were mixed. Still bad odds, but not always zero.
A few practical things:
  1. Check if the drive was formatted to the same file system or a different one. FAT32 to exFAT or NTFS often damages metadata more.
  2. If your photos matter most, look for file signature recovery. JPG, PNG, DOCX, PDF often come back even when folder names are gone.
  3. If the USB is small and important, make an image first. Scanning the image is safer.
  4. Recover files to your PC or another external drive, never back to the USB.
Disk Drill is a solid pick for a formatted USB scan because it handles both deleted entries and raw file carving. Preview matters. If previews fail, the file is often toast.
Also, for anyone searching this later, best data recovery software for a formatted USB flash drive is the phrase you want, not “best software for a formatted USB”.
This short clip explains the recovery idea in plain english too:
see how formatted USB recovery works
If the scan finds nothing useful, stop there. More tinkering makes it worse. If the files are irreplaceable, pro recovery lab is the next move. Time matters a bit here, so dont wait days while plugging it in over and over.
Yep, a quick format USB recovery is absolutely possible, and usually more possible than people think. @mikeappsreviewer and @voyageurdubois already covered the big “stop using the drive” rule, so I’ll add one thing they kinda glossed over: sometimes the flash drive itself is the bigger problem than the format. Cheap USB sticks love to fail at the exact worst moment.
Quick format usually removes the filesystem map, not every actual file block. So photos, PDFs, Word docs, etc may still be sitting there waiting to be found. The catch is file names and folder structure might be toast, esp if the drive was reformatted to a different file system.
What I’d check first:
  • Was it quick formatted or full formatted
  • Did Windows ask to “fix” the drive before or after
  • Is the USB behaving normally, or disconnecting randomly
If it’s stable, scan it with Disk Drill from your computer, not from the USB. I know people love trying five random free tools in a row, but that can waste time and sometimes makes the mess worse if you start writing temp files by accident. Preview the files before recovering them. If the previews work, that’s a very good sign.
Also, don’t get hung up if the original folders are gone. Raw recovery often brings files back ugly but usable. That’s still a win, lol.
If you want a solid explainer on recovering files from a quick formatted USB flash drive, this is worth a read:
how to recover files from a formatted USB flash drive
Small disagreement with the others: I wouldn’t jump to a pro lab unless the drive is physically acting weird or the data is truly irreplaceable. For a plain accidental quick format, software recovery is usualy the first shot.
Quick format is usually recoverable, but I’d push back on one tiny thing from @voyageurdubois, @boswandelaar, and @mikeappsreviewer: people focus a lot on the format type, but with flash drives the controller can be just as important. If the USB is silently remapping bad cells, recovery results can look random even after a harmless quick format.
A couple things worth checking that they did not really dig into:
  • TRIM support on USB media: uncommon, but some newer flash devices and USB SSDs can clear blocks faster than old sticks. If this is a USB SSD, odds are worse than a basic thumb drive.
  • Capacity fraud: if it is one of those fake 256 GB bargain sticks, files may never have been fully stored correctly in the first place.
  • Reformatted file system: if you switched from FAT32 to NTFS or exFAT, recovery may still work, but names and folders often get mangled.
My take: if the drive is detected normally and not disconnecting, software recovery is still the first move. Disk Drill is a reasonable option here.
Pros of Disk Drill
  • good at combining file system scan + raw carving
  • simple preview system
  • can scan disk images, which is safer
  • decent for photos and common office docs
Cons of Disk Drill
  • deep scans can be slow
  • raw recovery often returns messy filenames
  • best features are not fully free
  • if the flash memory itself is failing, no app can fix that
One more thing people skip: after recovery, open a sample from each file type. A recovered JPG that previews is great, but DOCX/PDF corruption can still show up only when opened fully.
So yes, recovery after a quick format is often possible. Just do not judge success by “files found.” Judge it by “files actually open.”
