Can I Recover Deleted RAW Photos From A Nikon Camera SD Card?
I accidentally deleted RAW photos from my Nikon camera SD card after a shoot, and some of the images are really important. I have not taken any new photos or used the card since I noticed they were missing. I need help figuring out the best way to recover deleted Nikon RAW files safely without making things worse.
I went through this with a Nikon card once, and I would not write the photos off yet. Deleted shots and files lost after a quick format still show up pretty often. What matters most is simple. Were those sectors overwritten, or not.
First move, stop using the SD card now. No more photos. No test video. No second format. Every write to the card eats into your odds of getting the RAW or JPEG files back.
If this happened after a quick format, I’d still feel decent about recovery. If the card got a full format or some secure wipe, odds drop hard.
If you do not have another copy anywhere, I’d start with recovery software. I’ve used Disk Drill for this kind of mess. It reads Nikon formats like NEF and NRW, plus normal JPG files, and the setup is not a pain.
What I’d do
  1. Pull the SD card out of the camera.
  2. Plug it into your computer with a card reader.
  3. Install Disk Drill on the computer itself, not on the SD card.
  4. Pick the SD card in the app, then hit Search for lost data.
  5. Run Universal Scan. For accidental deletion and quick format cases, it usually does the job.
  6. When the scan ends, preview what it found. If the NEF or JPG files open in preview, I’d take that as a good sign.
  7. Recover the files to your computer or a different drive. Do not save them back to the same SD card.
If you lost video too, I’d also try Advanced Camera Recovery after the first scan. Camera video files break up in weird ways, and this mode sometimes picks up clips the standard scan skips.
One part people don’t expect, recovered RAW files often come back with ugly generic names and no old folder layout. Annoying, yeah. Normal too. The software is often pulling files by file signature, not rebuilding the original directory cleanly.
Also, if a recovered NEF file refuses to open in the default Windows Photos app, I would not call it dead right away. Windows has been weird with Nikon RAW support for years. Try opening it in software with proper NEF support first.
Before you scan, check your boring backup spots too. I missed this once and wasted an hour. Look through your PC, old imports, SnapBridge transfers, cloud photo sync, vacation folders, random external drives. You might already have copies sitting there.
If the card does not show up at all, keeps disconnecting, or looks physically damaged, I’d stop messing with it. At that point a recovery lab makes more sense. A bad card tends to get worse when you keep retrying reads. I learned that the dumb way.
So yes, I think recovery is still on the table if the photos were deleted, vanished after a trip, or got wiped in a format mistake. The key part is speed. Stop using the card, scan it from a computer, and recover anything found to another drive.
Yes, your odds are still decent.
The big reason is you stopped using the card. Deleted Nikon RAW files, usually NEF, often stay on the SD card until new data overwrites them. If no new photos or video were shot, recovery rates are often high. On healthy cards, file carving tools recover a lot of deleted camera media. I’ve seen full shoots come back, names messed up, but images intact.
I agree with @mikeappsreviewer on the main point, stop all writes. I disagree a bit on one part though. I would not spend much time previewing every file before recovery if the card is acting flaky. On unstable media, fewer read passes is safer. Recover first to another drive, sort later.
A few things to check before you scan:
  1. Lock the SD card with the physical switch.
  2. Use a good USB card reader, not the camera over USB.
  3. If your computer asks to repair or format the card, hit no.
  4. Check if Nikon software, Lightroom, or old import folders already hold copies.
If the card mounts normally, Disk Drill is a solid pick for Nikon SD card recovery. It handles NEF and common photo formats well, and it’s easy enough if you’re not deep into recovery tools. If Disk Drill finds the files but some NEFs won’t open, test them in Nikon NX Studio or Lightroom before calling them corrupt. Windows chokes on RAW stuff all the time, tbh.
If the card is unreadable, slow, or disconnects, make an image of the card first, then scan the image instead of the card. That reduces stress on failing media. That part gets skipped a lot and it matters.
Also, here’s a solid SD card recovery tutorial if you want a quick visual guide:
best SD card recovery software guide for deleted photos and RAW files
Short version, yes, deleted RAW photos from a Nikon camera SD card are often recoverable. No new writes gives you a much better shot. Use Disk Drill or another recovery app from a computer, save recovered files somewhere else, and if the card looks damaged, stop poking at it becuase that makes things worse fast.
Yes, probably.
The biggest thing in your favor is that you stopped using the card. That matters more than anything else. Deleted NEF RAW files on Nikon SD cards are usually just marked as free space until something else overwrites them.
I mostly agree with @mikeappsreviewer and @mike34, but I’d push one extra point harder: if these photos are truly irreplaceable, make a byte-for-byte image of the SD card first, then do recovery attempts from that image instead of hammering the original card over and over. A lot of people skip that part, then wonder why a slightly bad card gets worse.
A few Nikon-specific notes people forget:
  • Some Nikon bodies create sidecar or helper files along with images. Recover those too if you see them.
  • NEF files may recover fine but not preview correctly in basic apps.
  • If a recovered RAW looks broken, test it in Nikon NX Studio before assuming it’s toast.
If you want the easy route, Disk Drill is a legit option for Nikon SD card recovery and it usually recognizes NEF files well. I woudln’t recover anything back onto the same card though, obviously. Save to your computer or another drive.
One small disagreement with the “preview everything first” idea: if the card is even a little unstable, recover first, inspect later. Less messing around is better.
Also worth checking before you go too deep:
best SD card recovery software recommendations for deleted camera photos
If the card is unreadable, disconnecting, or asking to be formatted, stop DIY stuff and consider a pro lab. But if it mounts normally, your chances are still pretty decent tbh.
