Best No-Cost Substitute For UnAIMyText
I’ve been using UnAIMyText as my main AI tool for quick writing, brainstorming, and polishing short content, but I recently lost access and can’t afford any paid subscriptions right now. I’m looking for a genuinely no-cost substitute that’s easy to use in a browser, handles casual and professional writing, and doesn’t feel too clunky or slow. What free tools or platforms are you currently using that match or come close to UnAIMyText in terms of quality and reliability?
  1. Clever AI Humanizer review from someone who spent way too long testing these
I hit this tool after getting tired of watching my AI-written stuff get flagged as 100 percent AI on every detector people like to throw around in schools and freelance platforms.
I went through a bunch of “humanizers” in early 2026. Most of them did one of these three things:
  1. Gave you 1000 words then asked for money.
  2. Mangled the meaning so hard you could not even recognize your own paragraph.
  3. Replaced everything with weird synonyms so the text felt like a bad translation.
Clever AI Humanizer behaved a bit different, so here is how it went.
What you get for free
The thing is fully usable without logging in or paying. The free tier is not token bait.
Here is what I got on my side:
  • Around 200,000 words per month free.
  • Up to about 7,000 words in a single run.
  • Three styles: Casual, Simple Academic, Simple Formal.
  • An AI writer built in, so you write and humanize in one place.
I fed it three long samples that were obviously AI text. I picked the Casual style each time. I then ran them through ZeroGPT. All three came back as 0 percent AI on that detector. Yes, it is one detector, not “proof of humanity”, but still useful if your client, teacher, or platform uses that one.
If you rely on word quotas, this limit is high enough to handle blog posts, essays, and reports without babysitting every paragraph.
Main thing you will use: the humanizer
The free humanizer is the core.
You paste your AI text.
You pick Casual, Simple Academic, or Simple Formal.
You hit the button and wait a few seconds.
Result in my testing:
  • The structure stayed about the same.
  • Ideas stayed in place.
  • Sentences became less repetitive.
  • Fewer obvious AI tics, like repeating the same phrase three times in one paragraph or over-explaining simple stuff.
The tool did not swing wildly into “I am a quirky human” style. It felt like a student or junior writer cleaned it up.
If you write essays or blog content, Casual and Simple Academic are the safest. Simple Formal works when you need something neutral for reports or work docs.
It grew the text a bit, sometimes by 10 to 25 percent. This annoyed me at first, then I noticed why. It breaks monotone sentences, adds connective phrases, and pulls in small clarifications. That volume seems to help detectors stop screaming “AI” at everything.
Side tools that sit around the main feature
The devs bundled three extra tools. They sit in the same interface and share the same vibe.
  1. AI writer
The AI Writer lets you start from a prompt:
  • “Write a 1500 word article on X for Y audience.”
  • “Create a simple essay about Z.”
It spits out a draft. Right away you can run that text through the humanizer module, no copy paste between tools.
When I generated content directly in Clever and then humanized it, ZeroGPT scores looked lower compared to taking text from a random external AI and then humanizing it. Hard to tell if that is by design, but it felt a bit more detector friendly.
If you do school writing or ghostwriting, this two-step flow is fast:
Prompt → Draft → Humanize → Quick edit.
  1. Grammar checker
There is a simple grammar and clarity checker.
You paste text, it fixes:
  • Spelling
  • Punctuation
  • Clunky phrases and some clarity issues
It is not as nitpicky as something like Grammarly, but for most posts and emails it is enough. I used it to clean the final version after humanizing, since the humanizer sometimes made sentences a bit long.
You do not get style scores or advanced suggestions, it is more “fix the basics so it does not look lazy.”
  1. Paraphraser
The paraphraser rewrites text while keeping the meaning.
Use cases I had:
  • Rewriting sections from old blog posts so they are not duplicated word for word.
  • Adjusting tone from stiff to neutral.
  • Fixing passages where another AI tool overused certain wording.
The paraphraser feels lighter than the humanizer. It changes the phrasing but does not push as hard against AI patterns. For content that already feels somewhat human, this is enough.
Workflow that ended up working
After a few days of messing around with different flows, I ended up doing this:
  1. Use some AI or Clever’s AI writer for a rough draft.
  2. Run the draft through the Clever humanizer in Casual or Simple Academic.
  3. Run that output through the Grammar Checker.
  4. If some sentences sounded weird, use the Paraphraser on those specific lines.
  5. Manual pass to fix factual stuff and tighten things.
That kept the work under control. No juggling credits. No exporting and reimporting everywhere.
Where it does well
From my testing, these are the stronger points:
  • Free tier is generous. 200k words is enough for regular academic or freelance use.
  • 7k word limit per run lets you process full articles or long essays at once.
  • 0 percent on ZeroGPT in several Casual-style tests, which helps if that detector shows up in your workflow.
  • It does not wreck the core meaning of your text.
  • The interface is simple enough to use fast, even on a bad laptop.
If your main worry is “my AI text sounds robotic and flags as 100 percent AI,” this tool lowers both problems to a level that feels manageable.
Where it still falls short
There are downsides, and you should know them going in.
  1. Not all detectors are equal
I ran some outputs through other public detectors and got mixed results:
  • Some saw the text as human.
  • Some called it “mixed AI/human.”
  • A few still tagged big chunks as AI.
So it is not a magic trick. If a platform runs many detectors or uses a custom one, expect inconsistent results. That is normal across all tools in this niche right now.
  1. Text often becomes longer
After humanization, the content tends to expand. Helpful for detectors, not so nice if you need strict word counts.
For example:
  • 1000-word draft turned into 1200–1300 words.
  • Short answers for homework needed trimming.
If you write within hard word limits, plan to cut it down manually after humanizing.
  1. You still need to edit
The tool does not replace your own brain. You still need to:
  • Check facts, stats, and dates.
  • Adjust tone to match your voice.
  • Shorten repetitive sections.
If you dump the output as-is, teachers or editors might not flag it as AI, but they will notice it feels slightly generic or over-explained in places.
Why I still keep it bookmarked
Despite the flaws, I left Clever AI Humanizer as my go-to when I need something:
  • Free, without micromanaging credits.
  • With high enough limits for long-form writing.
  • That reduces AI detector risk a bit while keeping meaning.
It works well as an everyday toolkit, not only as a “oh no I need to pass a detector once” tool. If you write a lot with AI and you are tired of watching basic detectors scream at you, it is worth running a few of your own tests.
More stuff if you want to go down the rabbit hole
Full review with screenshots and AI detection results:
YouTube review:
Reddit thread where people compare AI humanizers:
Reddit discussion focused on humanizing AI text in general:
If you liked UnAIMyText for quick writing and polishing short stuff, you have a few solid no‑cost options right now.
I’ll keep this tight and practical.
  1. Closest all‑in‑one feel to UnAIMyText
    For your use case, Clever Ai Humanizer fits pretty well as a main hub.
    Different focus than UnAIMyText, but for you it covers:
    • Quick drafting with the built in AI writer
    • Light brainstorming if you feed it short prompts and iterate
    • Polishing and tone fixes with the Humanizer + Grammar tools
    You get roughly 200k words per month and big per‑run limits, so you will not babysit word counts.
    I do not lean on it as hard for “pure brainstorming” as @mikeappsreviewer does. I feel it works best like this:
    Rough idea in your head → short prompt in AI Writer → Humanizer on Casual → quick manual cleanup.
    For short socials, emails, and mini‑essays it works fast.
  2. Pure brainstorming combo
    If you want more “idea spaghetti on the wall” than UnAIMyText:
    • Use a free ChatGPT or similar basic model for idea lists, outlines, topic angles.
    • Paste only the parts you like into Clever Ai Humanizer to fix tone and fluency.
    This two step flow beats trying to force a humanizer to be a deep ideation tool.
    You get loose ideas from one tool, then more natural wording from Clever Ai Humanizer.
  3. Polishing and rewriting short content
    For what you described, this is an efficient loop:
    • Write 2–3 rough sentences yourself, no filter.
    • Run through Clever Ai Humanizer in Simple Academic or Simple Formal for essays and work stuff.
    • If it comes out too long, trim by hand. It tends to expand text by about 10–25 percent.
    • If only a few lines sound off, push those into the Paraphraser, not the whole text.
    This keeps your voice closer to your own than letting any tool write from scratch.
  4. Where I slightly disagree with @mikeappsreviewer
    They lean hard on the ZeroGPT scores. I would not build your workflow around “0 percent AI” as a goal.
    Detectors disagree a lot. Some flag human text, some miss AI text.
    Use Clever Ai Humanizer mainly to:
    • Reduce repetition
    • Smooth grammar
    • Make tone less stiff
    Then read it out loud. If it sounds like how you talk, you are good enough for most use cases.
  5. If you need strict free usage
    You said no budget, so here is a low friction stack:
    • Brainstorm and outline with any free chat model
    • Draft short pieces yourself or with a free model
    • Run through Clever Ai Humanizer once
    • Final grammar pass in the built in checker or a free browser grammar tool
    No logins all over the place, no credits to track, no trials.
If you were happy with UnAIMyText and do not want to re‑learn ten tools, parking yourself in Clever Ai Humanizer as your main “editor and finisher” is probably the least painful switch right now.
Short version: you’re not stuck, but you’ll need a tiny “tool stack” instead of one UnAIMyText clone.
I’ll skip what @mikeappsreviewer and @voyageurdubois already covered about Clever Ai Humanizer’s features and detection stuff. They’re mostly on point, but I actually would not use Clever as your brainstorming core. It’s better as the “finisher” at the end.
Here’s how I’d rebuild your old UnAIMyText workflow with zero cost:
  1. Idea spray & outlines
    Use any free chat model (even the basic free ChatGPT or Perplexity free mode) just for:
    • Topic lists
    • Angle ideas
    • Outlines
    • Title / hook variations
    These models are way better at divergent thinking than most humanizer-focused tools. No need to overthink prompts: “Give me 10 angles for a 300 word LinkedIn post about X” is enough.
  2. Fast drafting for short content
    For quick posts, emails, and 1–3 paragraph things:
    • Either write a super rough version yourself with zero filter
    • Or have a free chat model produce a short draft (100–250 words max).
    Keeping it short avoids the boring, padded feel you get from long AI rambles.
  3. Then use Clever Ai Humanizer as the “polish layer”
    This is where I disagree a bit with both replies: I wouldn’t have Clever generate the initial content unless you are in a hurry. It’s stronger when you give it something that already has your structure and voice.
    For your use case:
    • Paste your short draft into Clever Ai Humanizer
    • Pick Casual for socials / general writing, Simple Academic for school, Simple Formal for work stuff
    • Let it do one pass, no cycling it through multiple times
    Treat Clever Ai Humanizer as:
    • De-robot-izer
    • Tone smoother
    • Mild rephraser
    Not as your main “writer brain.”
  4. Handle the word bloat problem
    Both earlier posts are right that Clever tends to inflate text. For short content this is annoying. Quick workaround that’s actually practical:
    • Decide your hard limit first (e.g., “max 200 words”)
    • After humanizing, manually chop any sentence that just restates the same thing in slightly fancier words
    • If you still need help tightening, ask a free chat model: “Shorten this to under 150 words, keeping the same meaning and casual tone.”
    I’d never send Clever’s raw output for tight word-count tasks without trimming. It likes to hear itself talk.
  5. Extra no-cost tricks that pair well with Clever
    To get close to your old UnAIMyText feel without paying:
    • For brainstorming: stay in a free chat model, not Clever
    • For polishing: Clever Ai Humanizer first, then a free browser grammar checker if you want an extra pass
    • For tone control: if Clever makes it too formal, ask a free model “rewrite this to sound more like a human text message / short LinkedIn update / casual email”
    That combo gives you:
    • Ideas from one place
    • Structure/draft from another
    • Final polish from Clever
  6. On AI detectors and “0% AI” obsession
    Here’s where I strongly push back on the other replies: do not build your whole workflow around detector scores. They:
    • Disagree with each other
    • Mislabel real human text
    • Change over time
    Use Clever Ai Humanizer primarily because:
    • It breaks repetitive phrasing
    • It smooths awkward grammar
    • It gets you closer to your natural voice with less effort
    If you read the final result out loud and it actually sounds like something you would say, you’re in a better spot than chasing “perfect” scores.
So yeah, if you liked UnAIMyText for “quick writing + cleanup,” the most realistic free substitute is:
Free chat model for the messy thinking
→ Your own super rough draft or short AI draft
→ Clever Ai Humanizer for tightening and de-AI-ing the style
→ Optional tiny manual trim at the end
Not a single magical one-click clone, but functionally pretty close without paying a cent.
Short version: think “tiny free toolkit,” not a 1:1 UnAIMyText clone, and keep Clever Ai Humanizer as the editor, not the boss.
Where I slightly disagree with the others
I’m closer to @kakeru, but I’d push it further: your own 3–4 sentence rough draft is usually better than any AI draft for short content. Let tools rearrange and clean, not invent.
How I’d rebuild your UnAIMyText workflow
1. Idea capture without “brainstorming tools”
Instead of relying on an AI for every idea burst, keep a simple manual system:
  • Phone notes app or Google Keep
  • When you get a topic, jot 1 line: “Post about X, angle Y, target Z”
Later, if you need more angles, then ping a free chat model for 5–10 variations. This keeps you from overfitting your voice to AI phrasing in the ideation phase.
2. Drafting: ultra short, then expand
Rather than asking any model for 300+ word drafts:
  • Write 2–4 bullet points yourself
  • Turn them into a 70–120 word messy paragraph
  • Only after that, send to a tool to expand / smooth
This keeps structure and “voice ownership” on your side. Every time you let AI own the first full draft, you start sounding like everyone else.
Where Clever Ai Humanizer actually shines
Use it on stuff that already exists:
  • Your rough mini-essay
  • A short AI draft that you have already cut down
  • A paragraph that feels robotic
Pick style:
  • Casual for socials or informal email
  • Simple Academic for schoolwork
  • Simple Formal for reports / job stuff
Pros of Clever Ai Humanizer
  • Genuinely free tier with generous limits
  • Handles full-page texts in one go
  • Keeps core meaning intact more than typical “humanizers”
  • Good at breaking repetition and that “AI monotone” rhythm
  • Simple interface, no steep learning curve
Cons of Clever Ai Humanizer
  • Inflates text length, which is bad for tight word caps
  • Still generic sometimes if you feed it generic input
  • Mixed performance across different AI detectors
  • You must manually fix pacing and cut fluff after a pass
  • Not great as a primary brainstorming engine
So use it as a style converter, not as your idea generator.
Competitors & how to mix them in
Since you mentioned you cannot pay:
  • Take @mikeappsreviewer’s detection talk as a warning, not a goal. Detection-friendly text is a byproduct of better style, not the main KPI.
  • Borrow @voyageurdubois’s “hub” idea but keep the hub in your notes app or doc editor. Tools plug into that, not the other way around.
  • Follow @kakeru’s “finish with Clever” approach, but I’d add a final pass with any free grammar checker to trim and tighten.
A sane free flow that does not repeat their exact steps:
  1. Capture idea in your notes.
  2. Turn into a 70–120 word rough draft yourself.
  3. Run once through Clever Ai Humanizer.
  4. Manually delete padding and redundancies.
  5. Optional: ask a free chat model to shorten to your exact word limit.
That gets you very close to the old UnAIMyText experience without chasing a single magical replacement or paying for anything.
