My iPhone storage is almost full, and Photos is taking up most of the space. I noticed the option to optimize iPhone storage or keep original photos and videos, but I’m not sure which setting is better for saving space without losing quality. I take a lot of pictures and need help choosing the best option for iPhone storage, iCloud photos, and keeping my originals safe.
I ran into this after my iPhone kept throwing the storage warning, and I spent way too much time poking through settings to figure out what Apple was doing.
The first thing I learned, and this tripped me up, is simple. ‘Optimize iPhone Storage’ does not work on its own. It depends on iCloud Photos. Your phone keeps smaller preview versions on the device, and the full files sit in iCloud. If iCloud Photos is off, or your iCloud storage is full, optimization kind of stalls out. There has to be a full copy stored online or the phone has nowhere to offload the original.
On the safety side, I was nervous too. I did not want to lose years of photos over one setting. From what I saw, the feature is safe because the photos are not being erased, they are being shifted. When you open a picture, edit it, or zoom in, the phone pulls down the full version from iCloud. The catch is internet access. If you are offline, on a plane, or stuck with bad signal, you might only get the smaller version until your connection comes back.
One annoying part, and I saw this on my own phone, is how slow iOS is to free space. You turn optimization on and expect room to open up right away. Nope. Mine sat near full for longer than I expected. Apple seems to wait until storage gets tight before it starts being aggressive about removing local originals. And if you are using the free 5GB iCloud plan, it fills fast. Once iCloud is packed, optimization stops helping.
As for whether you should use it, I think it depends on your phone and how much storage you bought. If you have a 512GB iPhone and tons of room left, keeping originals on the device makes life easier because everything stays available offline. If your phone is closer to the smaller storage models, optimization helps a lot.
What pushed me to stop relying on settings alone was performance. My iPhone started feeling bad once storage got close to full. Apps dragged. The camera took longer to open. A few things crashed for no clear reason. I checked my library and, honestly, a lot of the mess was my fault. Screenshots I forgot about. Blurry shots. Five copies of the same thing from trying to get one decent pic.
So I ended up cleaning the library instead of only toggling iCloud options. I tried a few cleaner apps and most felt sketchy, or they pushed subscriptions right away. The one I landed on was Clever Cleaner.
What stood out for me was the plain usefulness. It shows file sizes for screenshots and videos, so you see what is worth deleting first. There is a Heavies section for the biggest files, which helped me find one huge 4K video I forgot existed. There is also a Similars section, and this part saved me the most time. It grouped near-duplicate shots, then pointed to the best one so I could ditch the rest without sorting through everything by hand.
I also liked how it handled privacy. From what I saw, the sorting and scanning stayed on the phone. My stuff was not being shipped off somewhere else. After I cleaned things up, I got back around 15GB, and my phone stopped lagging.
If optimization looks turned on but your storage still looks cooked, open Settings > General > iPhone Storage and check the real breakdown first. If photos or System Data are eating the space, clean the junk before you start deleting apps you still use. For me, clearing the library was what fixed the problem, not waiting for iCloud to sort it out.
If your iPhone is almost full, pick Optimize iPhone Storage. For most people, it’s the better setting.
Keep Originals stores full-resolution photos and videos on your phone. That eats space fast, esp if you shoot a lot of 4K video, Live Photos, or bursts. Optimize keeps smaller versions on the device and leaves the full files in iCloud. You save local storage, which usually helps your phone run smoother too.
I slightly disagree with @mikeappsreviewer on one part. I would not say Keep Originals is “easier” unless you spend a lot of time offline. For daily use, Optimize is the more practical choice if storage is tight. The tradeoff is simple. You need iCloud Photos turned on, enough iCloud space, and internet access when you want the full file.
Use Keep Originals only if:
you have plenty of free iPhone storage,
you want full-res files offline all the time,
you do not want to depend on iCloud.
Use Optimize if:
your Photos app is the main storage hog,
your phone is under 15 to 20 percent free space,
you already pay for iCloud or plan to.
One extra thing. Optimization won’t fix a bloated library by itself. If you’ve got duplicate shots, giant videos, and old screenshots, clean those out first. Clever Cleaner is good for spotting large files and duplicate photos without making it a whole project. I’d do both, turn on Optimize, then trim the junk.
Also worth a read if you’re comparing cleanup options: read this iPhone cleaner app review for smarter photo storage cleanup.
Short version, low storage equals Optimize. Plenty of storage and need offline access equals Keep Originals. If your phone is already screaming for space, don’t wait arond.
If your iPhone storage is almost full, pick Optimize iPhone Storage. That’s the short answer.
@mikeappsreviewer and @cazadordeestrellas are mostly right, but I’d push it a bit further: Keep Originals only makes sense if you deliberately want your entire photo library offline on the phone all the time. Most people think they need that, but they really don’t.
What Apple doesn’t make super obvious is that Optimize is really a space-management setting, not a cleanup tool. It helps prevent Photos from hogging your device, but it won’t magically fix years of junk sitting in your library. If your storage is already trashed by giant videos, duplicate selfies, screenshots of recipies you never cooked, and random screen recordings, the setting alone won’t save you fast enough.
That’s where I’d do something extra besides just flipping the toggle. Clever Cleaner is actually useful for spotting big videos, duplicate photos, and leftover clutter in the Photos app without turning it into a whole weekend project. That’s a better combo: optimize storage and remove the obvious junk.
One small disagreement with the other replies: people overstate the offline issue a bit. Unless you’re constantly traveling with no service, it’s usually not a big deal. For normal day-to-day use, Optimize is fine.
If you want a quick visual guide, this easy iPhone photo storage optimization guide explains it pretty well.
So yeah:
- Low storage = Optimize
- Need everything offline = Keep Originals
- Library is a mess = use Clever Cleaner too
That’s probly the most practical answer.
If your phone is nearly full, I’d still lean Optimize iPhone Storage, but I disagree a little with the idea that it’s always the “best” setting. It’s the best pressure-release valve, not always the best long-term setup.
What matters is your habits:
- Choose Optimize if you mostly want space back and you’re usually on Wi-Fi or cellular.
- Choose Keep Originals if you shoot a lot, edit a lot, or travel/offline a lot and don’t want any delays loading full-res files.
One thing @cazadordeestrellas, @yozora, and @mikeappsreviewer all circle around is storage, but the hidden issue is bandwidth and patience. With Optimize on, old videos can take a second to download when you need them. That annoys some people way more than the low storage warning itself.
My take: if Photos is the main storage hog, turn on Optimize, then wait a bit. If your library is messy, clean that too, because optimization does not remove garbage you don’t need.
Clever Cleaner is decent for that part.
- good at spotting duplicates and similar shots
- helps find large videos/screenshots fast
- simple enough that you’ll actually use it
- no cleaner app is magic, you still need to review deletes
- similar-photo grouping can sometimes be too aggressive
- if your problem is iCloud space, it won’t solve that
So the practical answer is:
- Need space now: Optimize
- Need offline originals always: Keep Originals
- Need space and your library is bloated: Optimize + clean with something like Clever Cleaner
