Is Recuva Safe For Recovering Files From A USB Stick?
I accidentally deleted important files from my USB drive and I’m trying to figure out the safest way to get them back without causing more damage. I found Recuva, but I’m worried it could overwrite data or make file recovery harder. Has anyone used Recuva for USB file recovery, and is it a safe option?
People ask this all the time, and I don’t think the answer fits into a clean yes or no. If you want the short version, yes, Recuva is safe to run. It is not malware, it is not some fake recovery app, and it is not built to wreck your PC. The part people skip is the second half. Safe for your machine is one thing. Safe for your privacy, and safe for the files you want back, depends on how you use it.
I’ve been testing recovery apps on old drives, USB sticks, and a couple disks I should have stopped touching sooner. Recuva still comes up a lot in 2026, so here’s the plain version of what I saw.
About the malware rumors
A lot of the fear traces back to the 2017 CCleaner mess. Same company lineage. Piriform got hit in a supply chain attack and an official CCleaner build shipped with malware. That part is real, and people still bring it up for good reason.
Still, old disaster does not mean the current Recuva download is infected. Piriform moved under Avast, then under Gen Digital. The current installer gets checked a lot, and if you throw it into VirusTotal, it usually comes back clean or close to it. Sometimes one obscure engine throws a warning. I saw this once myself. It looked more like a heuristic false alarm than anything serious, which makes sense for software poking around file systems and deleted sectors.
If you download Recuva from the official source, you’re not dealing with a virus problem. That part seems fine.
Privacy is a different question
This is where people lump everything together and miss the boring part. Recuva itself is not spying in some cartoon villain way, but the company does collect data. IP address, device details, OS info, location data tied to fraud checks and licensing. Standard stuff for big software companies now, even when the app is free.
If you hate that sort of thing, go into the settings right after install. Open Options, then Privacy, and turn off the usage sharing box. I do this first, every time. Their policy also says IP data sticks around for 36 months before anonymizing. Some people won’t care. Some people will stop there and uninstall. Fair enough.
The mistake people make with deleted files
Here’s the part that matters most. Recuva is usually not what kills your recovery chances. The user does.
Do not install it on the same drive where your deleted files were sitting.
Windows often does not erase a deleted file right away. It marks the space as available. So if your missing photos were on drive C, and you grab the installer and drop it onto drive C, you might write new data over the exact area where the old files still lived. Then it’s done. No app fixes that.
The safer move is the portable build. Put it on a USB stick. Run it from there. Same rule for recovered files, don’t save them back onto the drive you are scanning. Use another disk, an external SSD, anything else. I messed this up years ago with a memory card dump and I still remember the sick feeling after realizing I overwrote part of what I wanted back. Dumb mistake. Easy one too.
How well it works now
This is where Recuva starts feeling old.
For simple undelete jobs, it still does alright. Empty Recycle Bin by accident, deleted a folder ten minutes ago, healthy Windows drive, no file system damage. In those cases it’s quick, light, and free. No paywall blocking the scan, no weird file cap. I get why people still keep it around.
But once things stop being clean and easy, the cracks show.
Recuva has not had a full rebuild in ages. It got enough patching to stay alive on newer Windows versions, sure, but it still behaves like an old-school undelete utility. If your drive shows up as RAW, or Windows asks you to format it before use, Recuva often won’t help much. Sometimes it won’t even recognize the volume in a useful way.
On formatted USB tests, results tend to land in the mid range. Roughly 63 percent to 67 percent recovery success from what I’ve seen referenced and from similar test setups I tried. And even when it lists files as recoverable, the output is hit or miss. I had JPGs marked excellent that opened into nothing. Corrupt file. Dead image. Same name issue too. Folder structure gets flattened and suddenly you’re staring at thousands of files named 000123.jpg and 000124.jpg. Have fun sorting your life out after that.
When free stops being enough
I still think Recuva makes sense as a first pass if the loss was recent and the drive is healthy. But if the files matter, your only copy of family photos, work docs due tomorrow, camera footage from a paid shoot, I wouldn’t spend hours pretending a basic tool will save the day if the first scan comes back weak.
Every extra scan adds stress. On a failing drive, time matters. I learned this the hard way on an old laptop disk. It clicked, scanned slow, then vanished from BIOS before I got a second clean pass. Once hardware starts acting weird, stop gambling.
At that point, you need something built for more than undelete jobs. In my use, Disk Drill tends to be the step up people end up taking when Recuva runs out of road.
It handles damaged partitions and RAW volumes far better. Recovery rates on formatted drives tend to be much higher, often around 95 percent to 97 percent in better-case test runs. One feature I wish more free tools had is Byte-to-Byte Disk Imaging. You clone the failing drive first, then scan the image instead of the original hardware. That is a huge deal. If the physical disk dies halfway through, you still have your clone. Recuva does not give you that safety net.
It also does better with media files. Recuva has a rough time with fragmented video and camera RAW formats. If you shoot on Nikon or Canon and lost files off a card, Recuva feels out of its depth fast. I wouldn't trust it there unless I had no better option.
For a side-by-side look, this YouTube review is worth watching:
https://www.youtube.com/watch?v=z0CVd7PxOms
My take
If you need a free first try on a normal Windows PC after a simple mistake, Recuva is still fine.
What I’d do:
  1. Get it from the official site only.
  2. Use the portable version when possible.
  3. Turn off usage sharing in the privacy settings.
  4. Save recovered files somewhere else.
  5. Don’t expect miracles on damaged or formatted drives.
If the scan finds nothing useful, or the files come back broken, stop writing to the drive. Don’t keep poking at it for hours out of frustration. Switch tools. On tougher cases, Recuva feels more like a quick test than a full recovery plan.
So yeah, safe to install, yes. Safe to trust with important recovery jobs, only in the easy cases. That’s the clean answer.
Yes, Recuva is safe if you use it the right way. The bigger risk is your next move, not the app itself.
My take is a bit different from @mikeappsreviewer. I think people overstate the danger of running Recuva on a USB stick. Scanning does not overwrite deleted files by itself. Writing does. So the main rule is simple. Stop using the USB drive now. Do not copy anything to it. Do not open files from it. Do not let Windows ‘fix’ it.
Best practice for your case:
  1. Plug in the USB.
  2. Install Recuva on your PC drive, not the USB.
  3. Recover files to your PC drive or another external drive, never back to the same USB.
  4. If Recuva finds the files, recover the most important ones first.
If the USB is failing, slow, disconnecting, or asks to format, skip Recuva as your first try. Use Disk Drill instead. It does better on damaged USB drives and ugly file system issues. For tougher cases, this list of top data recovery tools is worth a look:
best data recovery software for USB drives and deleted files
One more thing people miss. If TRIM is involved, recovery odds drop fast, but most plain USB flash drives do not use TRIM the same way SSDs do. So deleted files on a USB stick often still have a shot. Act fast tho.
Recuva is generally safe for USB file recovery, yeah. The thing I’d push back on a little from @mikeappsreviewer is that portable is nice, but not mandatory for a USB-stick case. @ombrasilente is closer there. The real danger is not the scan, it’s any write to that same USB.
A few practical notes people forget:
  • some antivirus tools will poke the USB in the background
  • Windows indexing can also touch removable media
  • if the stick is physically dying, repeated rescans are what can make things worse
So if the files matter, mount the USB, scan once, preview what you can, and recover to your PC or another drive only. If Recuva sees filenames but the files come back busted, don’t keep hammering the stick for hours.
Also, if the USB suddenly shows RAW, asks to format, or disconnects randomly, I would skip wasting time and move straight to Disk Drill. It’s just better for messy recovery cases and image-based work.
If you want a quick background on the tool itself, this page on Recuva file recovery software for deleted USB files is decent.
Short version: safe app, unsafe if you use it carelessly. That’s the whole game, realy.
Recuva itself is usually safe. I slightly disagree with the “portable first” idea though. For a USB-delete case, the bigger safety move is not where Recuva runs from, but making sure nothing writes back to that USB.
One thing not mentioned enough by @ombrasilente, @nachtschatten, and @mikeappsreviewer: if the files are truly important, make a full image of the USB first if you can. That gives you one frozen copy to work from. This is where Disk Drill has a real advantage.
Disk Drill pros
  • can create a byte-for-byte image
  • better with RAW/corrupted USB sticks
  • cleaner interface for previews
Disk Drill cons
  • not the lightest tool
  • free recovery limits depend on platform/version
  • deeper scans can take a while
My take:
  • healthy USB, simple accidental delete: Recuva is fine
  • flaky USB, format prompt, missing partition: skip straight to Disk Drill
  • if the drive clicks, disconnects, or gets hot: stop DIY and consider pro recovery
So yes, Recuva is safe. The risk is the USB’s condition and what gets written after deletion, not the scan itself.
